MyQ API down again
Re: MyQ API down again
Is this repeating? Turn on debug logging and post the log next time it happens.
wideglidejrp
Post by wideglidejrp »
Yes, it is repeating continuously. I can't turn debugging on because the dialog says there is an error. There is nothing wrong with my credentials.
Screenshot 2019-10-29 18.35.09.png (218.82 KiB) Viewed 4493 times
John R Patrick
Author of
Home Attitude
If you can't get out of that dialog, then your credentials aren't authenticating.
Have you tried them with the current MyQ app?
wideglidejrp
The credentials work in the app and also the web site.
John R Patrick
Author of
Home Attitude
Well, crap. Looks like MyQ changed something in the API. I've been getting those errors too.
jay (support)
Post by jay (support) »
Yep, here too.
MKuchnic
Post by MKuchnic »
I also tried back loading the previous version (all the way back to 7.3.2) and it's the same error. Defintely looks like an AP change.
Tracking the issue here: https://github.com/arraylabs/pymyq/issues/27
This is where I get the code from that goes into the plugin. Nothing I can do until they have a solution there.
Anyone having this issue should test this version: https://github.com/FlyingDiver/Indigo-M ... /tag/7.4.4
wideglidejrp
7.4.4 solved the problem for me. Thank you, and thanks for your tremendous efforts in developing plugins. Just curious, have you considered including Check for Updates in the plugin menu?
John R Patrick
Author of
Home Attitude
wideglidejrp wrote:Just curious, have you considered including Check for Updates in the plugin menu?
I used to have that, but removed it when the Indigo client started showing the same info. Having the update check in the plugin is redundant now, as long as the plugin is hosted on GitHub and available through the plugin store.
It would not have worked in this case, since 7.4.4 is marked as a pre-release until it gets some testing time. I will probably make it a full release later today, which will make it show up in the Indigo menu as needing an update.
colovin
Post by colovin »
7.4.4 is working for me. I'm not sure if I was having problems with 7.4.3. It worked yesterday morning, I didn't do the usual afternoon routine so it wasn't tried. When I saw 7.4.4 I downloaded it and worked as expected this AM.
Indigo 7.1.1, OS 10.14.6, MacMini .3.2 GHz 6 Intel Core i7, 64 GB ram
gbreeze
Post by gbreeze »
7.4.4. isn't working for me. I'm a new myQ user.
Error from the log (debug level):
MyQ Debug myqLogin failure, request url: https://api.myqdevice.com/api/v5/Login, RequestException: [SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:590)
gbreeze wrote:7.4.4. isn't working for me. I'm a new myQ user.
What OS X version are you running? Needs to be High Sierra or later.
Locked
Return to “MyQ”
