MyQ API down again
- FlyingDiver
Re: MyQ API down again
Is this repeating? Turn on debug logging and post the log next time it happens.
- wideglidejrp
- Contact:
Yes, it is repeating continuously. I can't turn debugging on because the dialog says there is an error. There is nothing wrong with my credentials.
- Screenshot 2019-10-29 18.35.09.png (218.82 KiB) Viewed 4484 times
John R Patrick
Author of Home Attitude
- FlyingDiver
If you can't get out of that dialog, then your credentials aren't authenticating.
Have you tried them with the current MyQ app?
- wideglidejrp
- Contact:
The credentials work in the app and also the web site.
John R Patrick
- FlyingDiver
Well, crap. Looks like MyQ changed something in the API. I've been getting those errors too.
- jay (support)
- Site Admin
- Contact:
I also tried back loading the previous version (all the way back to 7.3.2) and it's the same error. Defintely looks like an AP change.
- FlyingDiver
Tracking the issue here: https://github.com/arraylabs/pymyq/issues/27
This is where I get the code from that goes into the plugin. Nothing I can do until they have a solution there.
- FlyingDiver
- FlyingDiver
Anyone having this issue should test this version: https://github.com/FlyingDiver/Indigo-M ... /tag/7.4.4
- wideglidejrp
- Contact:
7.4.4 solved the problem for me. Thank you, and thanks for your tremendous efforts in developing plugins. Just curious, have you considered including Check for Updates in the plugin menu?
John R Patrick
- FlyingDiver
I used to have that, but removed it when the Indigo client started showing the same info. Having the update check in the plugin is redundant now, as long as the plugin is hosted on GitHub and available through the plugin store.wideglidejrp wrote:Just curious, have you considered including Check for Updates in the plugin menu?
It would not have worked in this case, since 7.4.4 is marked as a pre-release until it gets some testing time. I will probably make it a full release later today, which will make it show up in the Indigo menu as needing an update.
7.4.4 is working for me. I'm not sure if I was having problems with 7.4.3. It worked yesterday morning, I didn't do the usual afternoon routine so it wasn't tried. When I saw 7.4.4 I downloaded it and worked as expected this AM.
Indigo 7.1.1, OS 10.14.6, MacMini .3.2 GHz 6 Intel Core i7, 64 GB ram
7.4.4. isn't working for me. I'm a new myQ user.
Error from the log (debug level):
MyQ Debug myqLogin failure, request url: https://api.myqdevice.com/api/v5/Login, RequestException: [SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:590)
- FlyingDiver
What OS X version are you running? Needs to be High Sierra or later.gbreeze wrote:7.4.4. isn't working for me. I'm a new myQ user.
Error from the log (debug level):MyQ Debug myqLogin failure, request url: https://api.myqdevice.com/api/v5/Login, RequestException: [SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:590)
