Hue Lights - Free Philips Hue Plugin
nsheldon
Re: Hue Lights - Free Philips Hue Plugin
Post by nsheldon »
Version 1.6.29 Posted
  • Added support for Hue Outdoor Motion Sensor.
  • Added support for another GLEDOPTO color LED light strip controller.
nsheldon
Post by nsheldon »
Version 1.7.0 Posted
  • Added support for the Hue Tap and Hue Dimmer Switches.
  • Changed all references to the "Hue hub" to "Hue bridge".
nsheldon
Post by nsheldon »
Version 1.7.1 Posted
  • Added support for the Run Less Wire switch.
  • Fixed a bug that would prevent Hue Tap switches from appearing in the device selection list.
nsheldon
Post by nsheldon »
Version 1.7.2 Posted
  • Fixed a bug with Run Less Wire switch support that would not allow you to select a Run Less Wire switch device in the device selection dialog.
  • Fixed a bug with Run Less Wire switch support that returned numerous errors when the plugin attempted to update the online state of the switch which has no online state.
  • Fixed a bug with Run Less Wire switch support that would not update switch states during initial plugin load.
nsheldon
Post by nsheldon »
Version 1.7.3 Posted
  • Added support for the Hue Signe Floor light.
  • Added button hold states for the Run Less Wire switch device. Note that this feature is still experimental.
  • Fixed issue where Run Less Wire switch button ON states may not be saved.
nsheldon
Post by nsheldon »
Version 1.7.4 Posted
  • Shortened sensor update interval to 1 second instead of 2 seconds.
  • Shortened lights and groups update interval to 5 seconds instead of 10.
  • Added support for the Innr RS-228T GU10 color temperature light.
nsheldon
Post by nsheldon »
Version 1.7.5 Posted
  • Added support for the Hue White PAR-38 flood light.
nsheldon
Post by nsheldon »
Version 1.7.6 Posted
  • Fixed bug that would cause errors if a motion sensor was disabled in the Hue bridge. The plugin will now show a "disabled" error state for sensors that are turned off on the Hue bridge.
nsheldon
Post by nsheldon »
Version 1.7.7 Posted
  • * Added support for the Hue Outdoor Lucca light.
    * Added support for the Hue Smart Plug as a new On/Off device type.
nsheldon
Post by nsheldon »
Version 1.7.8 Posted
  • Fixed a bug that would cause the Hue Smart Plug device states to never update.
nsheldon
Post by nsheldon »
Version 1.7.9 Posted
  • Fixed a bug with Hue Group devices that prevented the Set Brightness with Ramp Rate action from working correctly.
nsheldon
Post by nsheldon »
Version 1.7.10 Posted
  • Fixed a bug with the Hue Smart Plug where current on/off state would not update.
  • Fixed a bug where using the Indigo's built-in Toggle On/Off action failed with dimmable Hue devices.
  • Added support for a new version of Hue color lamp.
nsheldon
Post by nsheldon »
Version 1.7.11 Posted
  • Added support for the Hue White PAR38 Outdoor light.
  • Added support for another Hue White Ambiance BR30 bulb.
  • Added support for another Feibit Inc. LED strip controller, branded as the 3A NUE ZigBee RGBW Light.
nsheldon
Post by nsheldon »
Version 1.7.12 Posted
  • Added support for an Ikea dimmable 806 lumen E27 and dimmable 400 lumen E14 light.
nsheldon
Post by nsheldon »
Version 1.7.13 Posted
  • Added support for 2 new Hue dimming only GU10 lights.
Locked
Return to “Archives”
