- Added support for Hue Outdoor Motion Sensor.
- Added support for another GLEDOPTO color LED light strip controller.
Hue Lights - Free Philips Hue Plugin
Re: Hue Lights - Free Philips Hue Plugin
Version 1.6.29 Posted
Version 1.7.0 Posted
- Added support for the Hue Tap and Hue Dimmer Switches.
- Changed all references to the "Hue hub" to "Hue bridge".
Version 1.7.1 Posted
- Added support for the Run Less Wire switch.
- Fixed a bug that would prevent Hue Tap switches from appearing in the device selection list.
Version 1.7.2 Posted
- Fixed a bug with Run Less Wire switch support that would not allow you to select a Run Less Wire switch device in the device selection dialog.
- Fixed a bug with Run Less Wire switch support that returned numerous errors when the plugin attempted to update the online state of the switch which has no online state.
- Fixed a bug with Run Less Wire switch support that would not update switch states during initial plugin load.
Version 1.7.3 Posted
- Added support for the Hue Signe Floor light.
- Added button hold states for the Run Less Wire switch device. Note that this feature is still experimental.
- Fixed issue where Run Less Wire switch button ON states may not be saved.
Version 1.7.4 Posted
- Shortened sensor update interval to 1 second instead of 2 seconds.
- Shortened lights and groups update interval to 5 seconds instead of 10.
- Added support for the Innr RS-228T GU10 color temperature light.
Version 1.7.5 Posted
- Added support for the Hue White PAR-38 flood light.
Version 1.7.6 Posted
- Fixed bug that would cause errors if a motion sensor was disabled in the Hue bridge. The plugin will now show a "disabled" error state for sensors that are turned off on the Hue bridge.
Version 1.7.7 Posted
- * Added support for the Hue Outdoor Lucca light.
* Added support for the Hue Smart Plug as a new On/Off device type.
Version 1.7.8 Posted
- Fixed a bug that would cause the Hue Smart Plug device states to never update.
Version 1.7.9 Posted
- Fixed a bug with Hue Group devices that prevented the Set Brightness with Ramp Rate action from working correctly.
Version 1.7.10 Posted
- Fixed a bug with the Hue Smart Plug where current on/off state would not update.
- Fixed a bug where using the Indigo's built-in Toggle On/Off action failed with dimmable Hue devices.
- Added support for a new version of Hue color lamp.
Version 1.7.11 Posted
- Added support for the Hue White PAR38 Outdoor light.
- Added support for another Hue White Ambiance BR30 bulb.
- Added support for another Feibit Inc. LED strip controller, branded as the 3A NUE ZigBee RGBW Light.
Version 1.7.12 Posted
- Added support for an Ikea dimmable 806 lumen E27 and dimmable 400 lumen E14 light.
Version 1.7.13 Posted
- Added support for 2 new Hue dimming only GU10 lights.
