TRV TRV Controller has calculated the number of seconds until Schedules restated as 8314
TRV 'TRV Controller' initialization complete
TRV 'Conservatory TRV' Heat Setpoint set to device minimum value i.e. '5.0' TRV Error StandardError detected in TRV Plugin [deviceStartComm of device 'Conservatory TRV']. Line '3100' has error='list index out of range'
TRV 'Kitchen TRV' Heat Setpoint set to device minimum value i.e. '8.0'
TRV Started 'Kitchen TRV': Controlling TRV 'Kitchen Heated Floor Thermostat'; Remote thermostat 'Kitchen Wall Thermostat'; Device Heat Source 'Global Heating Control'; No Variable Heat Source control required.
Z-Wave sent "Global Heating Control" mode change to off
TRV 'Master Bedroom TRV' Heat Setpoint set to device minimum value i.e. '4.0'
TRV Started 'Master Bedroom TRV': Controlling TRV 'Master Bedroom Danfoss Radiator Thermostat'; Remote thermostat 'Master Bedroom Wall Thermostat'; Device Heat Source 'Global Heating Control'; No Variable Heat Source control required.
TRV 'Office TRV' Heat Setpoint set to device minimum value i.e. '4.0'
TRV Started 'Office TRV': Controlling TRV 'Office Danfoss Radiator Thermostat'; Remote thermostat 'Office Wall Thermostat'; Device Heat Source 'Global Heating Control'; No Variable Heat Source control required.
Device status update attempt:
TRV Error StandardError detected in TRV Plugin [zwaveCommandSent]. Line '726' has error=''zwavePendingHvac''
Z-Wave sent "Conservatory HeatIT Thermostat" mode status request
Z-Wave received "Conservatory HeatIT Thermostat" mode is heat
TRV Error StandardError detected in TRV Plugin [zwaveCommandReceived]. Line '505' has error=''zwaveWakeupIntervalTrv''
TRV Error StandardError detected in TRV Plugin [zwaveCommandSent]. Line '684' has error=''zwavePendingTrvSetpointFlag''
Z-Wave sent "Conservatory HeatIT Thermostat" heat setpoint status request
Z-Wave received "Conservatory HeatIT Thermostat" heat setpoint is 21.0 °C
Z-Wave sent "Conservatory HeatIT Thermostat" cool setpoint status request
Z-Wave received "Conservatory HeatIT Thermostat" cool setpoint is 21.0 °C
Hi Jon, quick question. Just checking everything is all good with all plugins after Catalina upgrade. What mode should the plugin devices be in, ie the TRV controller? I thought they were always on, and the actual Spirit devices went from Off to Heat, but now all my TRV controllers are showing as Off, and some schedules are not getting picked up even when restarting the plugin.
shapa wrote:OK, not complaining regarding TF21 anymore ...
OK - I will take a look at this and see what I can figure out - I am a bit tied up for the next few days, so there will be a slight delay until the next pre-release version.
siclark wrote:Hi Jon, quick question. Just checking everything is all good with all plugins after Catalina upgrade. What mode should the plugin devices be in, ie the TRV controller? I thought they were always on, and the actual Spirit devices went from Off to Heat, but now all my TRV controllers are showing as Off, and some schedules are not getting picked up even when restarting the plugin.
I am running on Catalina OK and my schedules are working OK.
All my TRV Controllers are showing off when not scheduled to be ON. So that should be OK.
I do have the setting TRV ON/OFF set in the TRV Controller's device settings.
If you have debug logging turned on, is anything happening when a schedule is meant to fire and doesn't?
shapa wrote:.... TRV Error StandardError detected in TRV Plugin [deviceStartComm of device 'Conservatory TRV']. Line '3100' has error='list index out of range' ...
We are getting closer.
I need to see a device definition print.
Can you execute the following command from the Indigo Scripting Shell (see bottom of the Indigo plugin menu):
where 12345678 is the Indigo device Id of your real HeatIT device i.e. not the TRV Thermostat Controller. The output is written to the Indigo log if you could copy and paste it in a reply.
Looks like TRV is not reading the temperature from the thermostat as its a "subdevice" ("Conservatory HeatIT Air Sensor").
Could not select the subdevice in the "Remote Stat" either - not shown, only the root device (Conservatory HeatIT Thermostat)
Possibly, the easiest is to allow to select one of the Air sensors (it could be internal or external, not simultaneously) in the "remote stat". As I could understand it will fix the issue.
TRV Error StandardError detected in TRV Plugin [deviceUpdated] for device 'Conservatory HeatIT Thermostat']. Line '922' has error=''key id 141224139 not found in database''
Z-Wave received "Conservatory HeatIT Thermostat" heat setpoint is 24.0 °C
TRV 'new device 2' Heat Setpoint set to device minimum value i.e. '5.0'
TRV Error TRV Controller can't control TRV 'new device 2' as the TRV doesn't report temperature and there is no Remote Stat defined!
The "remote stat" is technically a child device to the TF021 - in the latest FW they made all sensors available as "sub-devices", The print from the built-in TF021 Air sensor (used by me) is below
Hi John
I’m having some weird issues where the remote thermostat is updating to the temp being sent to the Trv and when I try to change it it goes back to the trv setpoint (2.5 above the original setpoint on the thermostat). I was using your old plugin with the same set up with no issues. Any ideas?
Thanks in advance for your help.
Ksullivan wrote:I’m having some weird issues where the remote thermostat is updating to the temp being sent to the Trv and when I try to change it it goes back to the trv setpoint (2.5 above the original setpoint on the thermostat).
What TRVs and remote thermostats are you using?
When you say "when I try to change it it", what are you changing and where?
