Excellent !!!
Progress - thanks. Uninstalled, re-installed 1.9.2 - re-paired.
Sending a message to Speak is very cool and works.
Still running into some issues.
1. Request Device Status results in:-
Domotics Pad Mobile Client DebugPlugin preferences updated
Domotics Pad Mobile Client Debugging enabled... remember to turn off when done!
Domotics Pad Mobile Client DebugCurrent IWS Plugin: v1.3
Domotics Pad Mobile Client DebugIncluded IWS Plugin: v1.3
Action Group Lounge Tablet - Test Action
Domotics Pad Mobile Client ErrorError in plugin execution ExecuteAction:
File "plugin.py", line 322, in processRequestDeviceStatusNotification
NameError: global name 'requestDeviceStatusNotification' is not defined
2. Send Notification - with button actions
Domotics Pad Mobile Client Threaddebug Call to validate action: sendPushNotification
Domotics Pad Mobile Client Threaddebug Queuing push notification command for 97002777
Domotics Pad Mobile Client Threaddebug Plugin Command queue has 1 command(s) waiting
Domotics Pad Mobile Client Threaddebug Push Notification Send Command: DevicePairID=s8KAAQcpoouubzmbanZ4; Type=normal; Message=test test
Domotics Pad Mobile Client Threaddebug Push Notification Send Action 1: Lounge Lights On => 376660060
Domotics Pad Mobile Client Threaddebug Push Notification Send Action 2: Lounge Lights Off => 546891607
Domotics Pad Mobile Client Threaddebug Push Notification Payload=action2Name=Lounge+Lights+Off&action2Group=546891607¬ificationType=ActionAlert&priority=normal&action1Group=376660060&action1Name=Lounge+Lights+On&devicePairingId=s8KAAQcpoouubzmbanZ4&message=test+test
Domotics Pad Mobile Client Threaddebug Push notification Response: [204]
Domotics Pad Mobile Client DebugPush notification sent successfully
This is probably because I don't understand how this should operate/does Fire Tablet Support - i.e. I'll keep playing with it, but in the tests I have done Notifications sometimes just don't get through or have a very significant delay (5 or more mins) also when two buttons are shown in the notification only the second one performs the action even if you press the 1st .
- Indigo - Domopad - Notification.jpeg (183.1 KiB) Viewed 7689 times
Not an issue at all and most probably user error
3. Send Control Page
Domotics Pad Mobile Client Threaddebug Queuing control page display request notification command for 97002777
Domotics Pad Mobile Client Threaddebug Control Page Display Notification Send Command: DevicePairID=s8KAAQcpoouubzmbanZ4; Page=441807091
Domotics Pad Mobile Client Threaddebug Push Notification Payload=pageName=Heating%2FHot+Water+%26+Radiator+Demand&pageRequested=441807091&devicePairingId=s8KAAQcpoouubzmbanZ4
Domotics Pad Mobile Client Threaddebug Control page display notification response: [204]
Domotics Pad Mobile Client DebugControl page display notification sent successfully
Domotics Pad Mobile Client Process command: updateMobileDeviceStates
Nothing changed on the Fire8 tablet it did not change Control Page
None of which are issues I can't work around and are most likely User Error
