You could probably improve battery life by not reporting the valve % as frequently, but then the graphing doesnt work so well.
As far as I can tell I only have valve% reporting when a change of 10% or greater occurs.siclark wrote:You could probably improve battery life by not reporting the valve % as frequently, but then the graphing doesnt work so well.
As the TRV Controller appears to only fully open, 100% or close, 0% then the valve% reporting should only occur when the TRV is actually working.
I have not attempted any measurement but would suspect that opening/shutting the valve makes a greater demand on the battery than reporting it over zwave.
Given that I have 3 Heating Schedules per TRV, with the way the TRV controller operates (hopefully @autolog can confirm) that would cause the valve to fully open and shut 4 times a day without any Heating Demand activity, which I suspect, particularly during summer months/holiday modes is where most of the battery drain occurs.
Now I am using rechargeable batteries less of an issue. The Enloop batteries I put in the TRVs went in in June - immediately recording approx 80% battery (because of the voltage difference) but now in September they are reporting 40-45% indicating they would last approximately 6 months in Summer/Holiday mode.
Perhaps there is a way to disable the three existing Schedules and set a 4th that is for the full 24 hours - 10 mins, 5 each side of midnight.
I'll look into that, potentially significantly extending battery life during Summer/Holiday modes.
A question for Autolog....
I am trying to setup a Control Page that indicates which TRV is requesting Heat.
i.e. when the TRV demands heat it, on my setup, changes the Variable HeatingDemand to true.
All well and good but I would like to display which specific TRV is requesting that.
In the Device the fire icon illuminates when Demand is required in the Device Details (but not in the main display)
Which Custom State is that or what attribute is that so I can trap it?
[edit] is it possibly HVACOperationsModeTRV - 1 being Demand True, 0 being Demand False?
You can set a lower threshold, ie report at 1% which is what most use for testing and reporting but uses most battery.Busta999 wrote:As far as I can tell I only have valve% reporting when a change of 10% or greater occurs.siclark wrote:You could probably improve battery life by not reporting the valve % as frequently, but then the graphing doesnt work so well.
It definitely opens at any point between 0 and 100, that's the great thing about these, and it's the valve that handles that, it's temperature Vs the local set point.
Try Heater Equipment State (on or off) - it is a predefined Indigo Thermostat State (about 14 down from the top of the state list) when you select the TRV Thermostat Device (the plugin device not the Spirit) as a device state in the Control Panel.Busta999 wrote:A question for Autolog....
Thx will try it out
I noticed today, while performing the annual bleed radiators, changing a TRV SetPoint in Devices behaved oddly.
Clicking on the Red Up arrow of the Heat Setpoint did not always result in a change in Setpoint, stranger still multiple clicks on it could result in the Setpoint going up or down even though all the clicks were on the Up Arrow.
Also, clicking once did not always result in a Setpoint change, clicking multiple times also no response, followed by a flurry of set point changes often Up but also down.
The logs reflect this
Also this could result in the Device Comms Enabled to become turned off.
not the best way to turn up all the radiators by using the Device control, just wondering if this is expected behaviour?
Not a problem - an easy workaround....
I have now just created an Action Group to turn all the TRVs Setpoint to 27C to force Valves to fully open while I do the radiator bleeds, then set them all back to normal when done.
Z-Wave queued "Thermostat - Molly" change heat setpoint to 16.0° for next awake notification
Z-Wave queued "Thermostat - Molly" change heat setpoint to 17.0° for next awake notification
Z-Wave queued "Thermostat - Molly" change heat setpoint to 15.0° for next awake notification
TRV Error Potential race condition detected for TRV Controller 'TRV - Radiator - Molly' in TRV Plugin [deviceUpdated] - TRV Controller device being disabled!
Ignored device "TRV - Radiator - Molly" action request (communication is disabled)
TRV Stopping 'TRV - Radiator - Molly'
Schedule Current Meter Reading
Hue Lights received "Motion - Study (Hue)" status update is on
Z-Wave received "Thermostat - Hot Water" sensor update to 36.4 °C
Trigger Hot Water - Hit Temp High
Trigger Hot Water in Range Variable Indicator
Trigger Hot Water Hits 36C - Set Heating Available On
Z-Wave sent "Hot Water" off
TRV 'TRV - Radiator - Kitchen' Heat Setpoint set to specified 'Device Start' value i.e. '18.0'
TRV Started 'TRV - Radiator - Kitchen': Controlling TRV 'Radiator - Kitchen'; Remote thermostat 'Thermostat - Kitchen'; No Device Heat Source control required.; Variable Heat Source 'HeatingDemand'
TRV 'TRV - Radiator - Molly' Heat Setpoint set to specified 'Device Start' value i.e. '17.0'
TRV Started 'TRV - Radiator - Molly': Controlling TRV 'Radiator - Molly'; Remote thermostat 'Thermostat - Molly'; No Device Heat Source control required.; Variable Heat Source 'HeatingDemand'
Z-Wave sent "Radiator - Kitchen - Valve" status request
Z-Wave received "Temp: Garage (ZW)" sensor update to 17.4 °C
Z-Wave queued "Thermostat - Kitchen" change heat setpoint to 18.0° for next awake notification
Z-Wave sent "Radiator - Kitchen" change heat setpoint to 8.0°
Z-Wave sent "Radiator - Kitchen" raw command [40 01 1F]
Z-Wave sent "Radiator - Molly - Valve" status request
Z-Wave received "Garage - Humidity" sensor update to 80%
Z-Wave received "Radiator - Molly - Valve" status update is off
Z-Wave sent "Radiator - Kitchen - Valve" raw command [26 01 00]
Z-Wave queued "Thermostat - Molly" change heat setpoint to 18.0° for next awake notification
Z-Wave received "Garage - Luminance" sensor update to 3 lux
Z-Wave received "Garage - Ultraviolet" sensor update to 0
Z-Wave received "Thermostat - Bath" temperature update to 21.7 °C
Hue Lights received "Motion - Study (Hue)" status update is off
TRV Error Re-Enabling TRV Controller 'TRV - Radiator - Kitchen' following potential race condition detection (which as a result the device was disabled).
Z-Wave sent "Radiator - Kitchen - Valve" raw command [26 02]
Z-Wave received "Radiator - Kitchen - Valve" status update is off
Z-Wave sent "Radiator - Kitchen" raw command [40 01 00]
Z-Wave sent "Radiator - Kitchen" mode change to off
Matplotlib [Heat-Water-Motion CSV Engine] CSV data updated successfully.
Matplotlib [Chart - Radiator - Lounge Front] Chart updated successfully.
Matplotlib [Chart - Radiator - Master Bed] Chart updated successfully.
Matplotlib [Chart - Radiator - Molly] Chart updated successfully.
Z-Wave received "Thermostat - Hot Water" sensor update to 36.5 °C
Z-Wave received "Kitchen Freezer Door Temp Sensor" sensor update to 23.68 °C
Z-Wave received "113 - Siren" status update battery level 12%
Z-Wave queued "Thermostat - Molly" change heat setpoint to 19.0° for next awake notification
Z-Wave queued "Thermostat - Molly" change heat setpoint to 20.0° for next awake notification
TRV Error Re-Enabling TRV Controller 'TRV - Radiator - Molly' following potential race condition detection (which as a result the device was disabled).
Z-Wave received "Thermostat - Hot Water" sensor update to 36.6 °C
Trigger Freezer Temp Ok - Just right
Hue Lights received "Luminance - Landing 2 (Hue)" sensor update to 59.5 lux
Z-Wave queued "Thermostat - Molly" change heat setpoint to 21.0° for next awake notification
Hue Lights received "Luminance - Utility (Hue)" sensor update to 173 lux
Z-Wave sent "Radiator - Molly" change heat setpoint to 26.0°
Z-Wave sent "Radiator - Molly" raw command [40 01 1F]
Z-Wave snot the best way to turn up all the radiators by using the Device control, just wondering if this is expected behaviour?
Autolog,
What am I missing ?
BTW - it appears that HVACOperationsModeTRV does reflect Demand as well - or have I completely lost the plot - not out of the question
I am missing something here.. I cannot find Heater Equipment State in the state list - is possibly because my TRV devices call for heat through a variable change rather than directly control a device?[edit] is it possibly HVACOperationsModeTRV - 1 being Demand True, 0 being Demand False?
What am I missing ?
You are looking at the custom states on a device on the Devices page.Busta999 wrote:Autolog,
What am I missing ? ...
I inadvertently cause confusion by referring to a Control Panel - I'll blame auto-correct.
I meant to refer to the state list for a device defined on a Control Page - just checked again, it is there.
If you want to refer to the actual state name then it is heatIsOn which will have a boolean state of True or False
HVACOperationsModeTRV reflects whether the device is in Off or Heat mode. It can be in Heat Mode but not calling for heat if the ambient temperature is less than the Setpoint.
The plugin could handle this better = euphemism for this is probably a bug.Busta999 wrote:I noticed today, while performing the annual bleed radiators, changing a TRV SetPoint in Devices behaved oddly. ...
However, I think what is happening is that you are changing the SetPoint (by clicking the up arrow) and the plugin can see that the mode is OFF i.e. not Heat, so is resetting it to 17.
As the commands are processed via a queue on a background thread, the constant clicking is just overloading the plugin which is trying to set the temperature back to 17 having first actioned your request to increase it. As I say, it could be smarter.
If the plugin detects what it considers to be too many commands then it will flag this up as a race condition (aka out of control) and temporarily disable the TRV Controller device to let everything settle down and then re-enable it again.
autolog wrote:The plugin could handle this better = euphemism for this is probably a bug.Busta999 wrote:I noticed today, while performing the annual bleed radiators, changing a TRV SetPoint in Devices behaved oddly. ...![]()
Not an issue at all thanks for the plugin - very much appreciated
First of all - awesome plugin, using a lot.
With the latest FW (and updated Indigo support) for the floor thermostat you already added (HeatIT TF021), it is not possible to use the plugin anymore.
Per Matt, he had to add some specific "hacks" to show the temperature properly from multiple sensors.
Is it possible to update? I'm using the TRV plugin to control all heating in the house, except the Floor in the conservatory
TRV Error StandardError detected in TRV Plugin [zwaveCommandSent]. Line '655' has error=''zwaveSentCountTrv''
Z-Wave received "Conservatory HeatIT Thermostat" mode is heat
TRV Error StandardError detected in TRV Plugin [zwaveCommandReceived]. Line '498' has error=''zwaveReceivedCountTrv''
Z-Wave received "Conservatory HeatIT Thermostat" heat setpoint is 21.0 °C
Z-Wave received "Conservatory HeatIT Thermostat" cool setpoint is 21.0 °C
Z-Wave received "Conservatory HeatIT Air Sensor" sensor update to 29.2 °C
Z-Wave received "Conservatory HeatIT External Air Sensor" sensor update to 0.0 °C
Z-Wave received "Conservatory HeatIT Floor Sensor" sensor update to 23.1 °C
- Screenshot 2019-10-15 16.57.04.png (98.59 KiB) Viewed 3418 times
- Screenshot 2019-10-15 16.56.59.png (144.6 KiB) Viewed 3418 times
- Screenshot 2019-10-15 16.56.41.png (144.19 KiB) Viewed 3418 times
Looking at the code, I can't see how that error can happen but obviously it can!
I hope I have added a work-around for this error but I don't have a device to test with.
You can access the potential work-around fix here: TRV Controller - Pre-Release Version 1.3.3
Let me know what happens - it may need more work.
OK, now I'm seeing (at the start)
TRV Error StandardError detected in TRV Plugin [deviceStartComm of device 'Conservatory TRV']. Line '3100' has error='list index out of range'
When trying to update the device (virtual TRV) status
TRV Error StandardError detected in TRV Plugin [zwaveCommandSent]. Line '726' has error=''zwavePendingHvac''
Z-Wave sent "Conservatory HeatIT Thermostat" mode status request
TRV Error StandardError detected in TRV Plugin [zwaveCommandReceived]. Line '505' has error=''zwaveWakeupIntervalTrv''
TRV Error StandardError detected in TRV Plugin [zwaveCommandSent]. Line '684' has error=''zwavePendingTrvSetpointFlag''
Z-Wave sent "Conservatory HeatIT Thermostat" heat setpoint status request
Z-Wave sent "Conservatory HeatIT Thermostat" cool setpoint status request
and while trying to update settings
"You must select a TRV device to monitor which is known by the plugin; a 'Thermostat (TF021)' is not a TRV known by the plugin."
Try this version: TRV Controller - Pre-Release Version 1.3.4
I have added in a model definition (which may need to be tweaked) so the plugin knows about the thermostat.
