HTTPd Plugin (useful for IFTTT Maker integration)
haavarda
Re: HTTPd Plugin (useful for IFTTT Maker integration)
Post by haavarda »
Hi.
I have gotten a new gadget for my "brewery". This time it is a digital air lock that will count the bobbles and do several estimations based on that. The interesting thing is that this device supports webhooks, so it should be able to interface with Indigo.
The Plaato Airlock will send a POST request with a JSON object to the webhook every 5 minutes as long as it is connected to power and WiFi.
https://plaato.io/apps/help-center#!hc-values
The big question now, is it possible to use the HTTPd Plugin to interface this device?
/Håvard
Håvard
DaveL17
Post by DaveL17 »
I don't use the HTTPd plugin--but if that doesn't work for you--you may be able to use the GhostXML plugin (which also works with JSON payloads).
My Plugins and Scripts
haavarda wrote: The big question now, is it possible to use the HTTPd Plugin to interface this device?
Yes.
Oh, you want to know how? ;)
FIrst, set up the HTTPd plugin. Make sure you fill in the DDNS name field. If the device is on the local LAN, and it's the only device you're using with the plugin, you can use the local address of the Indigo server instead of a DDNS name. Something like "http://<indigoservername>.local/" or "http://192.168.1.101/".
Test that the HTTPd plugin is working properly. Use 'curl' in the Terminal window to test it, don't use a browser.
Something like this with set a variable named http_foo:
curl  http://192.168.1.101:5555/setvar?foo=bar
Once you're sure that's working, create an HTTPd device of type WebProxy. Then create a trigger for HTTPd Events -> Proxy Request Received for that device. Set the action to run a Python script:
httpPlugin = indigo.server.getPlugin("com.flyingdiver.indigoplugin.httpd")
if httpPlugin.isEnabled():
    hook_data = httpPlugin.executeAction("getWebhookData", deviceId=1375148185)
    indigo.server.log("Webhook Payload:\n{}".format(hook_data))
Look at the Web Proxy device custom device states, and get the http state value. Use it to test again, something like:
curl  -d '{"key1":"value1", "key2":"value2"}' -H "Content-Type: application/json" http://192.168.1.101:5555/webhook-1375148185
You should see something like this in the log:
   Script                          Webhook Payload:
Data : (dict)
     payload : (dict)
          key1 : value1 (string)
          key2 : value2 (string)
     request : (dict)
          client : 192.168.1.101 (string)
          command : POST (string)
          headers : (dict)
               accept : */* (string)
               authorization : Basic aG9va191c2VyOmhvb2tQYXNzMTAx (string)
               content-length : 34 (string)
               content-type : application/json (string)
               host : 192.168.1.101:5555 (string)
               user-agent : curl/7.54.0 (string)
          path : /webhook-1375148185 (string)
     vars : (dict)
If you get that, the web hook is working. Now you need to tell your device to use that URL for the webhook. I didn't see anything in the link you posted on how that's done. Maybe it's in the Plaato app.
You'll need to parse the payload part of the webhook data for your data. That's not too hard in Python. Depends on what you want to do with it.
DaveL17 wrote:I don't use the HTTPd plugin--but if that doesn't work for you--you may be able to use the GhostXML plugin (which also works with JSON payloads).
That would probably work if he wants to poll the analyzer, rather than use the webhook capability. Which honestly would seem to make more sense in this application. Webhooks are good for asynchronous event data, but they add a lot of complexity for something that's you just want to monitor on a fixed schedule.
DaveL17
Post by DaveL17 »
An excellent point.
haavarda
Post by haavarda »
Thank you for your reply and input FlyingDiver :) .
I was able to get your tests for work. So just need to sort out the rest. I thought that the communication was direct, but it might be a cloud thing, so then I need to open some ports etc...
But it seams as I do some sort of polling with a get funcion. GET http://plaato.blynk.cc/auth_token/get/pin. And perhaps I can use the GhostXML.
I have requested a token from Plaato, and will start play with it to see what I can make of it.
Thanks again for your support :)
Håvard
Håvard
DrLove
Post by DrLove »
Hi!
I'm trying to use this plugin for IFTTT but the plugin hangs about 1-3 times a day (need to be force quitted).
What could be the problem?
At reload:
   Error                           process (pid 91815) failed to quit after polite request -- forcing it to quit now
   Stopped plugin "HTTPd 1.3.2"
   Starting plugin "HTTPd 1.3.2" (pid 94636)
   Started plugin "HTTPd 1.3.2"
   HTTPd                           Starting HTTPd
   HTTPd Error                     Certificate file missing, unable to start HTTPS server
Best regards, L
Love Kull (yes it's my name)
Blog (in Swedish)
Sweden
DrLove wrote:I'm trying to use this plugin for IFTTT but the plugin hangs about 1-3 times a day (need to be force quitted).
First, how do you know it's hanging? Is it just that IFTTT can't reach it? Have you tried using a local command (curl or similar) to communicate with it?
Second, is there anything in the logs? Try setting debug level logging and see if that shows anything.
Also, I just realized I forgot to push the latest release to the plugin store (It was released on GitHub). Please upgrade to that.
DrLove
Post by DrLove »
IFTTT timeout and using Curl locally does not work until reload.
I'll try the updated version! Thank you for a quick reply!
Best regards, L
Blog (in Swedish)
Sweden
DrLove
Post by DrLove »
Hi.
It ran stable for a few days and then the latest release also crashed :(
Nothing in the log.
Best regards, L
Blog (in Swedish)
Sweden
What port are you using?
DrLove
Post by DrLove »
HTTP 5555.
/L
Blog (in Swedish)
Sweden
DrLove
Post by DrLove »
Update.
Yesterday, after my reply, the plugin did not even want to start at all. It looks like it's running (startup ok in log after force quit as usual) but does not respond to HTTP-requests. Tried different ports to no avail.
This morning after many reloads and disable/enable of the plugin it is running again, but who knows for how long :/
The log (at debug level) does not show anything odd.
//L
Blog (in Swedish)
Sweden
Ok, time to take this off the forums.
Please create a new issue here: https://github.com/FlyingDiver/Indigo-HTTPd/issues
Describe the problem with as much detail as you can (which in this case, might not be much). Then attach the plugin-specific log file and the plugin preferences file. Paths will be something like:
/Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.flyingdiver.indigoplugin.httpd/plugin.log
/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.flyingdiver.indigoplugin.httpd.indiPref
Locked
Return to “Discontinued Plugins”
