iRoomba iRobot Plugin
kwijibo007
Re: iRoomba iRobot Plugin
So far so good with the 960 - I think you can put it in the confirmed basket. I haven’t tested everything out yet but will report any issues if I find any.
Boy, it was a challenge getting Roomba to give up its password... I was trying for about 1/2 an hour before it decided work.
Great plugin - thanks very much.
Thanks! Good to know
Also can report that 0.4.0 fixes the binFull not updating! (Took a while to trigger it)
Glenn
Glenn
Yes, it fixes the bugGlennNZ wrote:Thanks! Good to know
Glenn
I just purchased a s9 and a Braava. Anyone confirm if these models work? I'll report back my experience.
So I'm not having much luck. The plugin will not fetch the password from my s9+.vtmikel wrote:I just purchased a s9 and a Braava. Anyone confirm if these models work? I'll report back my experience.
To test, I downloaded the node library that the plugin is based on (https://github.com/NickWaterton/Roomba980-Python) and I was able to get my password. Can you help me force the password I got externally into my device config?
Happy to try to support. Send me some debug logging trying to get password and will see what can do.vtmikel wrote:So I'm not having much luck. The plugin will not fetch the password from my s9+.vtmikel wrote:I just purchased a s9 and a Braava. Anyone confirm if these models work? I'll report back my experience.
Could add password to the config file in user/documents under the up IP address of iRoomba
Glenn
Thanks! Here's the log when I try to get my password.
iRobot-Roomba File should equal:/Users/mike/Documents/Indigo-iRobotRoomba/10.66.0.32-config.ini
iRobot-Roomba found 1 Roombas
iRobot-Roomba Make sure your robot (Roomba) at IP 10.66.0.32 is on the Home Base and powered on (green lights on). Then press and hold the HOME button on your robot until it plays a series of tones (about 2 seconds). Release the button and your robot will flash WIFI light.
iRobot-Roomba Received: {
"robotname": "Roomba",
"sku": "s955020",
"nc": 0,
"ver": "3",
"proto": "mqtt",
"ip": "10.66.0.32",
"hostname": "iRobot-33D775FD973E4FF5B0CAF3BCF558EDC4",
"sw": "soho+1.14.22+soho-releases+105",
"robotid": "33D775FD973E4FF5B0CAF3BCF558EDC4",
"mac": "50:14:79:10:EF:11",
"cap": {
"pmaps": 0,
"carpetBoost": 1,
"pp": 0,
"pose": 1,
"sched": 1,
"log": 2,
"ota": 2,
"dockComm": 1,
"binFullDetect": 1,
"prov": 3,
"area": 1,
"eco": 1,
"svcConf": 1,
"maps": 3,
"edge": 0,
"team": 1,
"multiPass": 2,
"5ghz": 1
iRobot-Roomba
Roomba (Roomba) IP address is: 10.66.0.32
iRobot-Roomba Error getting password. Follow the instructions and try again.
iRobot-Roomba Error Error in send Packet. ? Timeout
Can you try to get a password a few times - it seems to have received data (so must have connected at some point) but on this try there is no reply.
Presume is just the annoying, fiddly nature of pressing iRoomba button and timing of plugin?
Can you do this step a few more times and see how far it gets?
(Have checked the password code and the base library and plugin is pretty much the same...)
(Have pushed version 0.4.1 - download from github
https://github.com/Ghawken/Indigo-iRobotRoomba
Add some logging to this timeout if doesn't get past it with a few goes.)
G
G
Here's the log when I try to get my password on your latest build:
Starting plugin "iRobot-Roomba 0.4.1" (pid 22634)
iRobot-Roomba
iRobot-Roomba ================================================ Initializing New Plugin Session =================================================
iRobot-Roomba Plugin name: iRobot-Roomba
iRobot-Roomba Plugin version: 0.4.1
iRobot-Roomba Plugin ID: com.GlennNZ.indigoplugin.irobot
iRobot-Roomba Indigo version: 7.3.1
iRobot-Roomba Python version: 2.7.10 (default, Feb 22 2019, 21:55:15) [GCC 4.2.1 Compatible Apple LLVM 10.0.1 (clang-1001.0.37.14)]
iRobot-Roomba Python Directory: /System/Library/Frameworks/Python.framework/Versions/2.7
iRobot-Roomba ==================================================================================================================================
Started plugin "iRobot-Roomba 0.4.1"
iRobot-Roomba Starting Roomba
"sku": "s955020",
"nc": 0,
"ver": "3",
"proto": "mqtt",
"ip": "10.66.0.32",
"cap": {
"pmaps": 0,
"carpetBoost": 1,
"pp": 0,
"pose": 1,
"sched": 1,
"log": 2,
"ota": 2,
"dockComm": 1,
"binFullDetect": 1,
"prov": 3,
"area": 1,
"eco": 1,
"svcConf": 1,
"maps": 3,
"edge": 0,
"team": 1,
"multiPass": 2,
"5ghz": 1
iRobot-Roomba
iRobot-Roomba Error Error in send Packet. ? Timeout. Exception:[SSL: SSL_HANDSHAKE_FAILURE] ssl handshake failure (_ssl.c:1647)
Ek - don't like the look of that error...
The SW version is quite different as well - it may be incompatible, but still odd you found the main library could get password...
OK, Question time:
What version MacOS are you running?
Would double check App or another connection isn't connected to the iRoomba (as that can cause issue)
[Probably not that error though]
If have received password with Main Library - probably means issue lies in Python version within Indigo and OpenSSL files used.
(depends on your Mac OSX version) Although I have found can overcome by packaging the whole OpenSSL within the plugin as did with FindFriends
Have updated to 0.42 with a change to SSL if your firmware is found.
G
OK, Question time:
G
Password capture worked! Thanks for the great support.
Here was password capture:
Update, I attempted to trigger a start command:
Also, the plugin is restarting itself:
"sku": "s955020",
"nc": 0,
"ver": "3",
"proto": "mqtt",
"ip": "10.66.0.32",
"cap": {
"pmaps": 0,
"carpetBoost": 1,
"pp": 0,
"pose": 1,
"sched": 1,
"log": 2,
"ota": 2,
"dockComm": 1,
"binFullDetect": 1,
"prov": 3,
"area": 1,
"eco": 1,
"svcConf": 1,
"maps": 3,
"edge": 0,
"team": 1,
"multiPass": 2,
"5ghz": 1
iRobot-Roomba
iRobot-Roomba blid is: 33D775FD973E4FF5B0CAF3BCF558EDC4
iRobot-Roomba Password=> :1:1dd56574e5016:iobO84PQrXenfFef <= Yes, all this string.
iRobot-Roomba Saved Device Config File/Password. Click OK to continue.
Stopped plugin "iRobot-Roomba 0.4.2"
Starting plugin "iRobot-Roomba 0.4.2" (pid 43467)
iRobot-Roomba
iRobot-Roomba Plugin version: 0.4.2
iRobot-Roomba Debug logLevel = 10
Started plugin "iRobot-Roomba 0.4.2"
iRobot-Roomba Debug updateFrequency = 86400.0
iRobot-Roomba Debug statusFrequency = 600.0
iRobot-Roomba Debug deviceStartComm called for Roomba
iRobot-Roomba Debug Continuous ON and not connected..
iRobot-Roomba Debug getRoombaInfo for Roomba
iRobot-Roomba Debug connecting Roomba Device: Roomba
iRobot-Roomba Debug Using config file: /Users/mike/Documents/Indigo-iRobotRoomba/10.66.0.32-config.ini
iRobot-Roomba Debug CONTINUOUS connection
iRobot-Roomba Debug Reading Config File: 10.66.0.32-config.ini
iRobot-Roomba Debug Reading config file... /Users/mike/Documents/Indigo-iRobotRoomba/10.66.0.32-config.ini
iRobot-Roomba Debug reading info from config file /Users/mike/Documents/Indigo-iRobotRoomba/10.66.0.32-config.ini
iRobot-Roomba Debug Sections ['10.66.0.32']
iRobot-Roomba Debug Posting DECODED data
iRobot-Roomba Debug Connecting: Roomba : 10.66.0.32 : :1:ffff:iobO84PQrXenfFef
iRobot-Roomba Debug Connecting Roomba
iRobot-Roomba Debug Seting TLS
iRobot-Roomba Debug MQTT Client Succesfully setup
iRobot-Roomba Debug Client Connect Running now Roomba
iRobot-Roomba Debug Connection Roomba Error: 54
iRobot-Roomba Debug Attempting new Connection# 1
Z-Wave received "Upstairs Hallway Motion Sensor" status update is off
Script auto_lights script for Zone 'Master Bathroom', zone has been changed outside of the auto_lights script. Devices: [Master Bathroom Vanity Lights]. Current State: [False], Previous State: [True], zone is locked for 5 minutes (until 2019-08-16 21:50:31)
iRobot-Roomba Debug Connecting: Roomba : 10.66.0.32 : :1:15657fff45016:iobO84PQrXenfFef
iRobot-Roomba Debug Attempting new Connection# 2
iRobot-Roomba Debug Connecting: Roomba : 10.66.0.32 : :1:15dfd65ss7450v16:iobO84PQrXenfFef
iRobot-Roomba Debug Attempting new Connection# 3
Trigger Start Roomba when no one is home
iRobot-Roomba Debug startRoombaAction for Roomba: Action : start
iRobot-Roomba Debug Connecting: Roomba : 10.66.0.32 : :1:1sdf5ee6574f5fv0v6:iobO84PQrXenfFef
iRobot-Roomba Unable to connect to Roomba
iRobot-Roomba This may because your Roomba has lost charge and network connection.
iRobot-Roomba Restarting Plugin in effort to resolve...
iRobot-Roomba Debug Setting restart switch....
iRobot-Roomba Debug Self.Kill is true, restarting plugin
iRobot-Roomba restart Plugin Called.
Reloading plugin "iRobot-Roomba 0.4.2"
Stopping plugin "iRobot-Roomba 0.4.2" (pid 43467)
Z-Wave received "005 - Basement Motion Sensor" status update battery level 87%
Z-Wave received "Autumns Room Motion Sensor" status update is off
Z-Wave received "Master Bathroom Motion Sensor" status update is off
Error process (pid 43467) failed to quit after polite request -- forcing it to quit now
Starting plugin "iRobot-Roomba 0.4.2" (pid 43745)
That is Great to hear!
But how?
Did the new version work? (could you post log and can finalise code)
But how?
Sorry, I spoke to soon... see updated previous message.
Ok - almost cross replying herevtmikel wrote:Password capture worked! Thanks for the great support.
Stopped plugin "iRobot-Roomba 0.4.2" Starting plugin "iRobot-Roomba 0.4.2" (pid 43467) iRobot-Roomba iRobot-Roomba ================================================ Initializing New Plugin Session ================================================= iRobot-Roomba Plugin name: iRobot-Roomba iRobot-Roomba Plugin version: 0.4.2 iRobot-Roomba Plugin ID: com.GlennNZ.indigoplugin.irobot iRobot-Roomba Indigo version: 7.3.1 iRobot-Roomba Python version: 2.7.10 (default, Feb 22 2019, 21:55:15) [GCC 4.2.1 Compatible Apple LLVM 10.0.1 (clang-1001.0.37.14)] iRobot-Roomba Python Directory: /System/Library/Frameworks/Python.framework/Versions/2.7 iRobot-Roomba ==================================================================================================================================
1. To confirm 0.4.2 version enabled Password to work correctly?
1a. What version of Mac OSX are you running?
2. Error as above - enable Display Roomba Communication and save to log - see what it is like
(the Software 'SW' version of this is completely different to every other version so may not be compatible)
1 - Yes, latest version fixed password capture.
1a - Running 10.14.6
This is the result of a restart of the plugin after turning on the Roomba Communication.
iRobot-Roomba Debug checkALlRoombas called.
iRobot-Roomba Debug self.connected equals:False& self.continuous equals:True
iRobot-Roomba Debug Connecting: Roomba : 10.66.0.32 : :1::
Z-Wave received "Basement Dehumidifier" energy total to 119.203 kWh
Z-Wave received "Basement Dehumidifier" power load to 615.527 W
Aug 16, 2019 at 9:53:33 PM
