GreenIQ - Model B - Irrigation and PiBeacon
AndyVirus
Re: GreenIQ - Model B - Irrigation and PiBeacon
Post by AndyVirus »
Model B rev 2.0 - Revision 000e according to cpuinfo
so a RPI 1?
the only difference between sending direct gpis commands and sprinkler is that the sprinkler sends several commands
1. switch off all relays
2. switch on the new relay(s)
when you do a single gpio command, just one command is send (switch relay on /off)
it looks as if it takes ~ 8 secs between each of the steps receive, exec setgpio.
will look into it
if could do
top
on the rip and check how busy the RPi is
AndyVirus
Post by AndyVirus »
According to here its a rev 2 but yes its an old one. https://www.raspberrypi-spy.co.uk/2012/ ... d-version/
Top shows 9-20% cpu most of the time but when i send a sprinkler action it foes as high as 90% cpu.
If it is because its a old board/slow cpu then I can certainly live with an approx 20 second delay. Its only because im reusing the now defunct greeniq that im even entertaining this pi.. all my others are zerow’s or in some cases pi 3. The header board for the GreenIQ is the small gpio header so dont have many upgrade options even if i wanted to swap it out.
If there is an easy optimisation then great but 20 seconds for what is usually scheduled anyway is fine by me now it turns off :-)
yes it looks as if the rpi1 is backlogged by the tasks..
there are the following tasks running:
1. ONE receiveCommands
1 execommmands for each command received
1 setGPIO or other commands for each command managed by execCommands
that can be 16 temp processes for 8 relays.
it was setup to:
receive commands as fast as possible, launch a management program (exe commands) to take care of execution and not keep receive commands busy
I could incorporate setgGPIO into exe commands, that would cut delay in half. But in setGPIO there are potential waits in teh commands. so before I do that I need to understand all the other consequences.
so if 15 secs delay for the sprinkle is not a problem .. this is then lower priority.
actually it was not so complicated..
Have a version ready that skips setGPIO and does it in execcommands
if you like to test it. it should cut down the delay from 15 to < 8 secs on your RPI1
if you like to try:
https://www.dropbox.com/s/eydnqjyobysau ... n.zip?dl=1
after you test I will publish
changes:
Added features / changes in v7.103.276 @ 2019-05-07
1. moved setGPIO command into execcommands. that reduces delay with older RPI ie RPI1
2. now all pibeacon logfiles on the RPI are in ONE file: /var/log/piBeacon.log
it looks like:
date              module       debuglvl message
20190507-12:56:30 copyToTemp      L:-1= killing copyToTemp.py
20190507-12:56:30 sunDial         L:-2= move  return due to: direction1, inFixBoundaryMode:0 cap switch sens: 0;   switch sensor:0
20190507-12:56:30 sunDial         L:-3= 1100 === 34 1
20190507-12:56:31 master          L:-1=  IP find:::: wifiIP >><<; eth0IP: >>192.168.1.39<<;   hostnameIP >>['192.168.1.39']<<;   ipAddressRead >>192.168.1.39<<
20190507-12:56:31 sunDial         L:-2= move  return due to: direction-1, inFixBoundaryMode:0 cap switch sens: 0;   switch sensor:0
20190507-12:56:31 sunDial         L:-3= 1300 === 85 -1
20190507-12:56:31 master          L:-1=  master can ping indigo server at ip:>>192.168.1.50<<
20190507-12:56:32 installLibs     L:-1=  installLibs starting
20190507-12:56:32 installLibs     L:-1=  installLibs no opsys upgrade requested
20190507-14:59:04 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': True, u'command': u'down', u'pin': u'26'}
20190507-14:59:04 execcommands    L: 1= next cmd: "down"
20190507-14:59:04 execcommands    L: 0= setGPIO pid=16700,  command :{'startAtDateTime': u'1557259144.27', 'values': {}, 'pin': '26', 'debug': 3, 'inverseGPIO': True, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190507-14:59:04 execcommands    L: 0= msg: 156x-6-api_IN_14x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"high"}}},"program":"execcommands","ipAddress":"","pi":"14","ts":{"tz":"CDT","time":1557259144.16}}
20190507-14:59:04 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': True, u'command': u'down', u'pin': u'5'}
20190507-14:59:04 execcommands    L: 0= setGPIO pid=16707,  command :{'startAtDateTime': u'1557259144.36', 'values': {}, 'pin': '5', 'debug': 3, 'inverseGPIO': True, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190507-14:59:04 execcommands    L: 0= msg: 156x-6-api_IN_14x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"high"}}},"program":"execcommands","ipAddress":"","pi":"14","ts":{"tz":"CDT","time":1557259144.29}}
AndyVirus
Post by AndyVirus »
I have installed and tested remotely so assume the valves are doing what they do :-)
20190508-10:21:51 receiveCommands L: 2= len of buffer:409
20190508-10:21:51 receiveCommands L: 2= len of buffer:0
20190508-10:21:51 receiveCommands L: 2= len of package:409
20190508-10:21:51 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "4"}
20190508-10:21:51 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "17"}
20190508-10:21:51 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "27"}
20190508-10:21:51 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "22"}
20190508-10:21:51 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "23"}
20190508-10:21:52 receiveCommands L: 2= len of buffer:235
20190508-10:21:52 receiveCommands L: 2= len of buffer:0
20190508-10:21:52 receiveCommands L: 2= len of package:235
20190508-10:21:52 receiveCommands L: 1=  cmd= {"restoreAfterBoot": "0", "startAtDateTime": 0, "pin": "24", "inverseGPIO": false, "devId": 1128735305, "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 600.0, "nPulses": 0}, "device": "OUTPUTgpio-1", "command": "pulseUp"}
20190508-10:21:52 receiveCommands L: 1=  cmd= {"restoreAfterBoot": "0", "startAtDateTime": 0, "pin": "18", "inverseGPIO": false, "devId": 1128735305, "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 600.0, "nPulses": 0}, "device": "OUTPUTgpio-1", "command": "pulseUp"}
20190508-10:21:58 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'4'}
20190508-10:21:58 execcommands    L: 1= next cmd: "down"
20190508-10:21:58 execcommands    L: 0= setGPIO pid=8819,  command :{'startAtDateTime': u'1557307318.59', 'values': {}, 'pin': '4', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:21:59 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'17'}
20190508-10:21:59 execcommands    L: 1= next cmd: "down"
20190508-10:21:59 execcommands    L: 0= setGPIO pid=8821,  command :{'startAtDateTime': u'1557307319.34', 'values': {}, 'pin': '17', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:21:59 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307318.75}}
20190508-10:21:59 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'27'}
20190508-10:21:59 execcommands    L: 0= setGPIO pid=8823,  command :{'startAtDateTime': u'1557307319.81', 'values': {}, 'pin': '27', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:22:00 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307319.48}}
20190508-10:22:00 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'22'}
20190508-10:22:00 execcommands    L: 1= next cmd: "down"
20190508-10:22:00 execcommands    L: 0= setGPIO pid=8825,  command :{'startAtDateTime': u'1557307320.47', 'values': {}, 'pin': '22', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:22:00 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307319.94}}
20190508-10:22:00 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'23'}
20190508-10:22:00 execcommands    L: 0= setGPIO pid=8827,  command :{'startAtDateTime': u'1557307320.64', 'values': {}, 'pin': '23', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:22:00 execcommands    L:-1= next command: {u'restoreAfterBoot': u'0', u'startAtDateTime': 0, u'pin': u'24', u'inverseGPIO': False, u'devId': 1128735305, u'values': {u'analogValue': 0.0, u'pulseDown': 0.0, u'pulseUp': 600.0, u'nPulses': 0}, u'device': u'OUTPUTgpio-1', u'command': u'pulseUp'}
20190508-10:22:00 execcommands    L: 1= next cmd: "pulseUp"
20190508-10:22:00 execcommands    L: 0= setGPIO pid=8829,  command :{'startAtDateTime': 1557307320.843068, 'values': {u'analogValue': 0.0, u'pulseDown': 0.0, u'pulseUp': 600.0, u'nPulses': 0}, 'pin': '24', 'debug': 3, 'inverseGPIO': False, 'cmd': u'pulseUp', 'devId': 1128735305, 'PWM': 1}
20190508-10:22:00 execcommands    L:-1= next command: {u'restoreAfterBoot': u'0', u'startAtDateTime': 0, u'pin': u'18', u'inverseGPIO': False, u'devId': 1128735305, u'values': {u'analogValue': 0.0, u'pulseDown': 0.0, u'pulseUp': 600.0, u'nPulses': 0}, u'device': u'OUTPUTgpio-1', u'command': u'pulseUp'}
20190508-10:22:01 execcommands    L: 0= setGPIO pid=8831,  command :{'startAtDateTime': 1557307320.998413, 'values': {u'analogValue': 0.0, u'pulseDown': 0.0, u'pulseUp': 600.0, u'nPulses': 0}, 'pin': '18', 'debug': 3, 'inverseGPIO': False, 'cmd': u'pulseUp', 'devId': 1128735305, 'PWM': 1}
20190508-10:22:01 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307320.55}}
20190508-10:22:01 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307320.76}}
20190508-10:22:58 receiveCommands L: 2= len of buffer:573
20190508-10:22:58 receiveCommands L: 2= len of buffer:0
20190508-10:22:58 receiveCommands L: 2= len of package:573
20190508-10:22:58 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "4"}
20190508-10:22:58 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "17"}
20190508-10:22:58 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "18"}
20190508-10:22:58 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "27"}
20190508-10:22:59 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "22"}
20190508-10:22:59 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "23"}
20190508-10:22:59 receiveCommands L: 1=  cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "24"}
20190508-10:23:05 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'4'}
20190508-10:23:05 execcommands    L: 1= next cmd: "down"
20190508-10:23:05 execcommands    L: 0= setGPIO pid=8927,  command :{'startAtDateTime': u'1557307385.61', 'values': {}, 'pin': '4', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:06 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'17'}
20190508-10:23:06 execcommands    L: 1= next cmd: "down"
20190508-10:23:06 execcommands    L: 0= setGPIO pid=8929,  command :{'startAtDateTime': u'1557307386.24', 'values': {}, 'pin': '17', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:06 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307385.75}}
20190508-10:23:06 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'18'}
20190508-10:23:06 execcommands    L: 0= setGPIO pid=8931,  command :{'startAtDateTime': u'1557307386.77', 'values': {}, 'pin': '18', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:06 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307386.37}}
20190508-10:23:06 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'27'}
20190508-10:23:07 execcommands    L: 1= next cmd: "down"
20190508-10:23:07 execcommands    L: 0= setGPIO pid=8933,  command :{'startAtDateTime': u'1557307387.05', 'values': {}, 'pin': '27', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:07 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'22'}
20190508-10:23:07 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307386.89}}
20190508-10:23:07 execcommands    L: 0= setGPIO pid=8935,  command :{'startAtDateTime': u'1557307387.45', 'values': {}, 'pin': '22', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:07 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'23'}
20190508-10:23:07 execcommands    L: 0= setGPIO pid=8937,  command :{'startAtDateTime': u'1557307387.52', 'values': {}, 'pin': '23', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:07 execcommands    L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'24'}
20190508-10:23:07 execcommands    L: 0= setGPIO pid=8939,  command :{'startAtDateTime': u'1557307387.67', 'values': {}, 'pin': '24', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:07 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307387.19}}
20190508-10:23:08 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307387.59}}
20190508-10:23:08 execcommands    L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307387.57}}
20190508-10:23:08 execcommands    L: 0= msg: 153x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307387.8}}
So looks like its down to 8 - 10 seconds on this old Pi! Thanks!
ok thanks
will publish the official version
added: when 2 commands for the same GPIO are send in sequence ( eg pulse up for 600 secs; then indigo/ user sends a down after 30 secs ) , the first one is still active.
Now the second will cancel the first and then execute.
setGPIO did that (cancel itself in previous process) , and now execcommands will do it too.
Return to “piBeacon”
