GreenIQ - Model B - Irrigation and PiBeacon
Re: GreenIQ - Model B - Irrigation and PiBeacon
the new release (.276) should add the option to set RELAYS on if gpio ==0 or ==1
set in sprinkler device edit
Thanks! Will give it a go Friday when im home to check.
Yep that works. Thanks!.
I was using GPIO-ON/OFF devices to trigger the zone valves and a variable that changed when any one was turned on or off and a trigger on that variable to turn the pump on and off in the interim. Worked well.
The Sprinkler device seems to take about 60 seconds to turn on my valves and they never seem to obey their limit. Will keep playing, must being doing something silly but the new version with the box unchecked works perfectly for 0=off and 1=on.
"The Sprinkler device seems to take about 60 seconds to turn on my valves and they never seem to obey their limit. "
to better understand: could you post or send the sprinkler device config? and the sprinkler action.
OK the time limit think may be me being dumb. I was just selecting the zone from the Indigo gui and assuming that it would obey the maximum times set.
It does seem that it takes so long to send the command that using the Action "Run Schedule" does nothing as the amount of time I run each zone for is less than the time it must take to actually action the command on the Pi.
I can see the action sequentially triggering each zone according to the scedule but nothing actually happens. Valves to not get triggered and master pump does not get turned on.
If i turn on the zone from indigo gui, it will eventually start the pump and open the valve but it does take many mins. If i do the same via OUTPUY-GPIO-1-On/Off then it takes seconds to turn the GPIO on or Off.
So this is my config of the Sprinkle And Schedule Action:
- Schedule Action
- Screenshot 2019-05-06 at 16.58.33.png (47.11 KiB) Viewed 3281 times
- Config
- Screenshot 2019-05-06 at 16.37.00.png (51.43 KiB) Viewed 3281 times
first do not use "one wire pin" and also the "DHT pin" can act up.. But if your hardware is "hardwired" make sure that unwire protocol is disabled (in sudo raps-config, .. interfaces).
here my dev config and my action ...
don't see anything wrong. if you "manually" run a zone in the sprinkler device (run schedule or next zone). how long does it take.. mine takes < 1 secs to start.
could you enable debug "output" and check when the command gets send - ie time stamp .. in the logfile. (or just double click the logfile ) (in ... indigo 7 x/Logs/pibeacon../plugin.log if you use one of the latest versions .
Ps one of my temp sensor is bad (-228F)
have not run anything in the last weeks as we had plenty of rain > 15 cm, but I tried to run just now and it works fine ..
- Screen Shot 2019-05-06 at 11.11.43.png (128.63 KiB) Viewed 3310 times
- Screen Shot 2019-05-06 at 11.07.45.png (105.34 KiB) Viewed 3310 times
- Screen Shot 2019-05-06 at 11.08.34.png (32.47 KiB) Viewed 3310 times
OK so it takes about 80-120 seconds to start a zone manually. To stop all zones, about 20 seconds. If i do the commands directly via OUTPUT-GPIO-1-On/Off it takes about 3 seconds...(this is an old pi B)
I had already disabled onewire but double checked/answered "no" to enabling onewire in interfaces.
This is from the plugin log:
17:50.08 is when i sent the command... 17.51.52 is a few seconds after the pump actually turns on and i turn it off by using all zones off.
Really odd.
06 17:50:07 sendGPIOCommand-s-: [{"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "17"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "18"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "27"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "22"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "23"}]
06 17:50:07 sendtoRPI sending to 192.168.124.7; command-string=[{"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "17"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "18"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "27"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "22"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "23"}]; calledFrom:sendGPIOCommand
06 17:50:07
##=======use this as a python script in an action group action :=====
plug.executeAction("setPins" , props ={u
"outputDev":"Sprinkler"
,"device":"OUTPUTgpio-1"
,"restoreAfterBoot":0
,"startAtDateTime":"0"
,"cmd":"pulseUp"
,"pulseUp":"60.0"
,"pulseDown":"0.0"
,"rampTime":"0.0"
,"analogValue":"0.0"
,"GPIOpin":"24"})
##======= end =====
06 17:50:07 sendGPIOCommand: [{"restoreAfterBoot": "0", "startAtDateTime": 0, "command": "pulseUp", "pin": "24", "device": "OUTPUTgpio-1", "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 60.0, "nPulses": 0}, "inverseGPIO": true, "devId": 1128735305}]
06 17:50:07 sendtoRPI sending to 192.168.124.7; command-string=[{"restoreAfterBoot": "0", "startAtDateTime": 0, "command": "pulseUp", "pin": "24", "device": "OUTPUTgpio-1", "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 60.0, "nPulses": 0}, "inverseGPIO": true, "devId": 1128735305}]; calledFrom:sendGPIOCommand
06 17:50:08
,"cmd":"pulseUp"
,"pulseUp":"60.0"
,"pulseDown":"0.0"
,"rampTime":"0.0"
,"GPIOpin":"4"})
##======= end =====
06 17:50:08 sendGPIOCommand: [{"restoreAfterBoot": "0", "startAtDateTime": 0, "command": "pulseUp", "pin": "4", "device": "OUTPUTgpio-1", "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 60.0, "nPulses": 0}, "inverseGPIO": true, "devId": 1128735305}]
06 17:50:08 sendtoRPI sending to 192.168.124.7; command-string=[{"restoreAfterBoot": "0", "startAtDateTime": 0, "command": "pulseUp", "pin": "4", "device": "OUTPUTgpio-1", "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 60.0, "nPulses": 0}, "inverseGPIO": true, "devId": 1128735305}]; calledFrom:sendGPIOCommand
06 17:51:52 sendGPIOCommand-s-: [{"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "4"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "17"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "18"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "27"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "22"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "23"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "24"}]
06 17:51:52 sendtoRPI sending to 192.168.124.7; command-string=[{"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "4"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "17"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "18"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "27"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "22"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "23"}, {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "24"}]; calledFrom:sendGPIOCommand
Really odd.
I guess i have a double negative:
cancels each other it should be
"pulseUp": 60.0, "nPulses": 0}, "inverseGPIO": false
that should be say to fix.
so for you right now the sprinkler starts when it should goe off and stays on
that explains the behaviors.
could you try this one:
https://www.dropbox.com/s/eydnqjyobysau ... n.zip?dl=1
SHOULD do it correctly
Quick test before bed confirms that it now takes about 20 seconds to turn on zone and pump which us a huge improvement. Turning all off seemed slower but only about 30 seconds.
Will dig out the logs in the morning as i have an early start. Thanks for all your help so far!
So it goes on and off as setup, just with 20 sec delay?
That could be the rpi clock
Could you check
Ssh pi@....
date
And check if the rpi has the right time.
Could you check
Ssh pi@....
date
Yes. Now goes on and off with only 20 seconds delay. Time is exactly the same on the Pi as it is on the Mac Mini running indigo viewed using "date" command on both.
Will try schedules again to see if that makes any difference to doing it from the gui. Not back again now till thursday or friday but can access remote just not listen out for the pump remote (well i can but camera in the garden is laggy).
you can follow the action remotely on the RPI:
in config set debug RPI output to max
wait ~ 1 minute to get the par meter file send too the rpis and read
ssh pi@192..
cd pibeacon
sudo python master.py
tail -F /run/user/1000/pibeacon/receiveGPIOcommands.log
#should show you the commands received
tail -F /run/user/1000/pibeacon/execcommands.log
#should show you the commands managed
tail -F /run/user/1000/pibeacon/setGPIO.log
#should show you the GPIO commands executed
recieveGPIOcimmnds.log shows instant recive of the commands from indigo
execcommands.log shows at that time:
setGPIO.log shows
It takes about 15 seconds for anything to appear in the setgpio.log while it takes less that 1 second to hit the recieveGPIOcommands.log.
20190507-15:40:06 len of buffer:409
20190507-15:40:06 len of buffer:0
20190507-15:40:06 len of package:409
20190507-15:40:06 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "4"}
20190507-15:40:06 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "17"}
20190507-15:40:07 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "27"}
20190507-15:40:07 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "22"}
20190507-15:40:07 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "23"}
20190507-15:40:07 len of buffer:235
20190507-15:40:08 len of buffer:0
20190507-15:40:08 len of package:235
20190507-15:40:08 cmd= {"restoreAfterBoot": "0", "startAtDateTime": 0, "pin": "24", "inverseGPIO": false, "devId": 1128735305, "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 600.0, "nPulses": 0}, "device": "OUTPUTgpio-1", "command": "pulseUp"}
20190507-15:40:08 len of buffer:235
20190507-15:40:08 cmd= {"restoreAfterBoot": "0", "startAtDateTime": 0, "pin": "18", "inverseGPIO": false, "devId": 1128735305, "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 600.0, "nPulses": 0}, "device": "OUTPUTgpio-1", "command": "pulseUp"}
20190507-15:40:21 len of buffer:573
20190507-15:40:21 len of buffer:0
20190507-15:40:21 len of package:573
20190507-15:40:21 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "4"}
20190507-15:40:22 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "17"}
20190507-15:40:22 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "18"}
20190507-15:40:22 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "27"}
20190507-15:40:22 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "22"}
20190507-15:40:22 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "23"}
20190507-15:40:23 cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "24"}Code: Select all
20190507-15:40:14 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'4'}
20190507-15:40:14 next cmd: "down"
20190507-15:40:14 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240014.34", "values": {}, "pin": "4", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:14 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'17'}
20190507-15:40:14 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240014.73", "values": {}, "pin": "17", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:15 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'27'}
20190507-15:40:15 next cmd: "down"
20190507-15:40:15 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240015.44", "values": {}, "pin": "27", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:15 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'22'}
20190507-15:40:15 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240015.52", "values": {}, "pin": "22", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:15 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'23'}
20190507-15:40:15 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240015.99", "values": {}, "pin": "23", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:16 next command: {u'restoreAfterBoot': u'0', u'startAtDateTime': 0, u'pin': u'24', u'inverseGPIO': False, u'devId': 1128735305, u'values': {u'analogValue': 0.0, u'pulseDown': 0.0, u'pulseUp': 600.0, u'nPulses': 0}, u'device': u'OUTPUTgpio-1', u'command': u'pulseUp'}
20190507-15:40:16 next cmd: "pulseUp"
20190507-15:40:16 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": 1557240016.95966, "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 600.0, "nPulses": 0}, "pin": "24", "debug": 3, "inverseGPIO": false, "cmd": "pulseUp", "devId": 1128735305, "PWM": 1}' &
20190507-15:40:17 next command: {u'restoreAfterBoot': u'0', u'startAtDateTime': 0, u'pin': u'18', u'inverseGPIO': False, u'devId': 1128735305, u'values': {u'analogValue': 0.0, u'pulseDown': 0.0, u'pulseUp': 600.0, u'nPulses': 0}, u'device': u'OUTPUTgpio-1', u'command': u'pulseUp'}
20190507-15:40:17 next cmd: "pulseUp"
20190507-15:40:17 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": 1557240017.396226, "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 600.0, "nPulses": 0}, "pin": "18", "debug": 3, "inverseGPIO": false, "cmd": "pulseUp", "devId": 1128735305, "PWM": 1}' &
20190507-15:40:35 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'4'}
20190507-15:40:35 next cmd: "down"
20190507-15:40:35 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240035.26", "values": {}, "pin": "4", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:35 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'17'}
20190507-15:40:35 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240035.5", "values": {}, "pin": "17", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:35 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'18'}
20190507-15:40:35 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240035.61", "values": {}, "pin": "18", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:35 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'27'}
20190507-15:40:35 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240035.79", "values": {}, "pin": "27", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:36 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'22'}
20190507-15:40:36 next cmd: "down"
20190507-15:40:36 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240036.26", "values": {}, "pin": "22", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:36 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'23'}
20190507-15:40:36 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240036.28", "values": {}, "pin": "23", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &
20190507-15:40:36 next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'24'}
20190507-15:40:36 cmd= python /home/pi/pibeacon/setGPIO.py '{"startAtDateTime": "1557240036.64", "values": {}, "pin": "24", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}' &Code: Select all
20190507-15:40:23 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240014.34", "values": {}, "pin": "4", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:24 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240014.73", "values": {}, "pin": "17", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:24 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240015.52", "values": {}, "pin": "22", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:24 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240015.44", "values": {}, "pin": "27", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:25 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240015.99", "values": {}, "pin": "23", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:27 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": 1557240016.95966, "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 600.0, "nPulses": 0}, "pin": "24", "debug": 3, "inverseGPIO": false, "cmd": "pulseUp", "devId": 1128735305, "PWM": 1}']
20190507-15:40:27 msg: 161x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240026.8}}
20190507-15:40:28 msg: 162x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240027.34}}
20190507-15:40:28 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": 1557240017.396226, "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 600.0, "nPulses": 0}, "pin": "18", "debug": 3, "inverseGPIO": false, "cmd": "pulseUp", "devId": 1128735305, "PWM": 1}']
20190507-15:40:29 msg: 162x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240028.19}}
20190507-15:40:29 msg: 161x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240028.3}}
20190507-15:40:30 msg: 162x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240029.23}}
20190507-15:40:44 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240035.26", "values": {}, "pin": "4", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:45 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240035.61", "values": {}, "pin": "18", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:45 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240035.5", "values": {}, "pin": "17", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:45 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240035.79", "values": {}, "pin": "27", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:45 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240036.28", "values": {}, "pin": "23", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:46 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240036.64", "values": {}, "pin": "24", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:46 setGPIO command :['/home/pi/pibeacon/setGPIO.py', '{"startAtDateTime": "1557240036.26", "values": {}, "pin": "22", "debug": 3, "inverseGPIO": false, "cmd": "down", "devId": 0, "PWM": 1}']
20190507-15:40:47 killing setGPIO.py "pin": "18",
20190507-15:40:47 msg: 162x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240046.99}}
20190507-15:40:47 killing setGPIO.py "pin": "24",
20190507-15:40:47 msg: 162x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240047.36}}
20190507-15:40:47 msg: 161x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240047.3}}
20190507-15:40:48 msg: 162x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240047.56}}
20190507-15:40:48 msg: 162x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240047.73}}
20190507-15:40:48 msg: 162x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240048.03}}
20190507-15:40:48 msg: 162x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"setGPIO","ipAddress":"192.168.124.7","pi":"4","ts":{"tz":"BST","time":1557240048.09}}GreenIQ - Model B - Irrigation and PiBeacon
Good info, I can trace that
Again what kind of rpi?
