HUE Signe floor light
McJohn
Post by McJohn »
Hi Nathan,
Thanks again for all your work. It's a part of our daily life in the evening :wink:
Do you know if the latest version of the HUE plugin will support the HUE Signe floor light?
https://www2.meethue.com/en-us/p/hue-wh ... /4080248U7
Thanks for your help and kind regards,
John
nsheldon
Re: HUE Signe floor light
Post by nsheldon »
Hi John.
If it's not listed in the Supported Devices of the Hue API yet, then the plugin won't support it, but I can add support after you've paired it with your Hue bridge and provided me with the model ID shown for it in the Hue app.
McJohn
Post by McJohn »
Hi Nathan,
Thanks for your quick answer.
Below our homework :D
Thanks for the great Service!
Kind regards,
John
nsheldon
Post by nsheldon »
Great! Thanks. I’ll work on adding support and let you know when it’s ready.
nsheldon
Post by nsheldon »
Version 1.7.3 Posted
  • Added support for the Hue Signe Floor light.
  • Added button hold states for the Run Less Wire switch device. Note that this feature is still experimental.
  • Fixed issue where Run Less Wire switch button ON states may not be saved.
McJohn
Post by McJohn »
It's working great and clear Nathan!
Thank you so much for your very quick service, this is how fast new updates should be work! :D
gillekes
Post by gillekes »
As I understand the friends of hue switch can be added to the plugin? I have the Niko ones. What would you need for this to happen from my part?
Thanks for this wonderful plugin:)
Enviado do meu iPhone usando o Tapatalk
nsheldon
Post by nsheldon »
Hello.
I'd like to support the Niko switch, but really need one with which to test. The only reason I was able to add the Run Less Wire switch is because another user on the forum was able to test button events and Hue bridge debug console output himself and then provide that output to me. Even so, Run Less Wire support is somewhat experimental since he only had time to do limited testing.
If you're familiar with the Hue bridge debug console and can perform some button event tests and output, I might be able to add limited support. That's a somewhat advanced developer feature though, so if you're not familiar with REST type APIs and JSON output, it may take you some time to get useful information from the Hue bridge. And unfortunately, it seems each of the different switches behave differently, so it's not possible to adapt the Run Less Wire code to work with all Friends of Hue switches.
gillekes wrote:Hi,
Locked
Return to “Archives”
