Not able to set up a new Pi
yassi
Post by yassi »
After not using the plugin since a very long time - in general, in 2017/2018 I had not too much time for Indigo :cry: , I wanted to start from scratch with it and mostly connect sensors (first of all a CO sensor).
But I'm not able to setup up the Pi via the Plugin, can't do the initial setup.
For sure I'm doing something wrong, or I forgot something, so, I'm asking for help :oops:
What I've done:
1 . installed Pi (has another IP-address now as the last Pi), is accessible via Wlan, can connect via ssh, everything done on the image (expanded, changed pwd., etc.). Using the latest image.
2. deleted the old PiBeacon folder from Documents
2. installed the latest plugin
4. configured the plugin
5. now I'm stuck at the initial setup, where I have to select a Pi, not shown there with the ip-adress.
What do I have to select? 0? or Only sensor? Nothing is shown, as far as I know, it should show it, or I have to specify it
Yassi
Bildschirmfoto 2019-01-05 um 19.49.23.png (71.92 KiB) Viewed 2325 times
Bildschirmfoto 2019-01-05 um 19.45.27.png (102.6 KiB) Viewed 2325 times
Bildschirmfoto 2019-01-05 um 19.45.16.png (88.52 KiB) Viewed 2325 times
Re: Not able to set up a new Pi
1. select the rpi# ( eg 0 )
2. click on confirm (first)
3. enter the params
- ip, id, password ...
4. click on confirm (second)
then rpi0 should come back with all field populated.
as for sensor / beacon, that depend on which one you like to use. sensor does NOT have ibeacon support. only RPI 0-9 have that. that is due to the fact that the states in the ibeacon and RPI devices are static ie distance _0 .. distance_9, other wise there would be 6 times more states for each additional RPi (distance_11.. signal_11,....etc)
as for msg from plugin: there you will se OK or error .... once you click on confirm
hope that helps
yassi
Post by yassi »
Hi Karl,
ok, thanks, that the way I'm trying to add it.
But as I click on "Confirm" an error message appears in the log, so I am not able to enter the rest.
Which password is here used?
Ok, about the sensors, got it. I will use 0-9 so I can have the beacons too.
Yassi
Bildschirmfoto 2019-01-06 um 09.31.32.png (152.71 KiB) Viewed 2278 times
questions:
1. which version?
2. could you send ~/documents/indigo/pibeacon/RPIconfig an email to karlwachs at me com -- it contains your rpi userid and passwords , don't post
yassi
Post by yassi »
Hi Karl,
the plugin has the version number 7.99.262. downloaded yesterday.
Check your email please, you should have the file. From: yasminkeller at mac com
But unfortunately, I don't have the piBeacon folder under ~/documents/indigo/pibeacon/ but under ~/indigo/pibeacon/, see screenshot here.
Yassi
Bildschirmfoto 2019-01-06 um 13.57.00.png (44.9 KiB) Viewed 2260 times
yassi
Post by yassi »
Ok, thanks to Karl, I was able to get it working.
Had to delete the RPIconf file, then restart plugin.
Return to “piBeacon”
