HTTPd Plugin (useful for IFTTT Maker integration)
geoffsharris
Re: HTTPd Plugin (useful for IFTTT Maker integration)
Great concept for a plug in. I'm doing the following with user and pword substituted in the real test :
curl "http://user:pword@localhost:5555/setvar?variable=1"
<html>
<head><title>Indigo HTTPd Plugin</title></head>
<body>
<p>Updated variable httpd_1027260896 to '1'</p>
</body>
</html>
In indigo I get the following:
AuthHandler: GET from 127.0.0.1:62345 for /setvar?variable=1
HTTPd Debug AuthHandler: Request has correct Authorization header
HTTPd Debug AuthHandler: setting variable httpd_variable to '1'
The value of "variable"is unchanged in indigo. I've tried all sorts of other tests like using the id number for the variable, etc. and I can't get this to actually update any variable in indigo even though I am getting authorization and a success message.
Any ideas would be great. Running Indigo 7.2 on OS Mojave.
-Geoff
<html>
<body>
</body>
</html>
-Geoff
geoffsharris
For those smarter than me, this will be obvious, but hopefully it will save someone some time. The app creates a folder called HTTPd and the variable passed like "foo" are listed as httpd_foo in this folder. I didn't see this and kept wondering why my "foo" variable I had set up in indigo was not updating. Hope this helps someone.
-Geoff
-Geoff
- FlyingDiver
I'll update the README on GitHub so this is described better. It's in the first post of this thread, but if you get the plugin from the Store you might not see that.
- FlyingDiver
Release 1.3.0 is now available:
Starting with release 1.3.0, the plugin supports both GET and POST methods. When a POST call is processed, the payload of the POST request is broadcast:
This allows other plugins (or background Python scripts) to use the HTTPd plugin to receive HTTP requests.
See the "Broadcast and subscribe interprocess communication" section of viewtopic.php?f=2&t=17039#p126067 for more info.
indigo.server.broadcastToSubscribers(u"httpd_post_payload", payload)See the "Broadcast and subscribe interprocess communication" section of viewtopic.php?f=2&t=17039#p126067 for more info.
This is great! One small suggestion:
Currently I have my Netatmo webhook url set to my Indigo public IP address and a selected port, with '/netatmo' appended. This causes a debug message in HTTPd:
AuthHandler: Unknown request: /netatmo
Since it is possible that webhook messages are arriving from more than one source, one solution would be for HTTPd to pass the path as well as the message, so that subscribers to the broadcast could quickly determine if this was a relevant message for them.
- FlyingDiver
This is why I should not do coding when suffering from jet lag.
Release 1.3.1 now available. The broadcast functionality has changed. Read the README on GitHub. This fixes the "unknown request" error. Also, the broadcast data is now a dictionary so that additional information can be included.
Jet lag clearly in remission! Thumbs up from North Yorkshire
philipbasile
I have the plugin installed and I'm trying to test.
two questions...
1. the user name and password configured in the plugin have nothing to do with my indigo username and password correct ?
2. why am I getting a prompt for the user name and password even though I'm including it in the url call per the example for the plugin ?
thanks
philip
two questions...
thanks
philip
- FlyingDiver
1. Correct. The username/password you configure in the plugin is ONLY used for the HTTP calls back to the plugin.philipbasile wrote: 1. the user name and password configured in the plugin have nothing to do with my indigo username and password correct ?
2. Where are you seeing that? The plugin can't prompt anywhere (except for the config dialog).
What plugin action are you trying to use?
philipbasile
I'm using geohopper to trigger a pushover message with the following embedded URL (sanitized)
http://username:password@myddns:9085/se ... geOpen=Yes
But I just past it into my safari browser for testing...
Even if I past this into my browser I get a username and password prompt from safari to log in like I would for a secure website.
Thoughts ?
Philip
Thoughts ?
Philip
- FlyingDiver
Try doing this in a Terminal window, with the real host name.philipbasile wrote:I'm using geohopper to trigger a pushover message with the following embedded URL (sanitized)
Thoughts ?
Philip
curl http://username:password@myddns:9085/setvar?ActionGarageOpen=Yesjoe (aka FlyingDiver)
philipbasile
Joe,
So if I paste this into the browser on my mac
http://admin:[email protected]:9085/setvar?test=2
I get the following in my browser
Safari can’t open the page “192.168.2.11:9085/setvar?test=2” because the server unexpectedly dropped the connection.
This sometimes occurs when the server is busy. Wait for a few minutes, and then try again.
But I get this in the event log with debug turned on
HTTPd Debug AuthHandler: GET from 192.168.2.145:54610 for /setvar?test=2
HTTPd Debug AuthHandler: setting variable httpd_test to '2'
HTTPd Debug AuthHandler: GET from 192.168.2.145:54611 for /setvar?test=2
HTTPd Debug AuthHandler: GET from 192.168.2.145:54612 for /setvar?test=2
the variable does get set.
when I do the SAME THING on my iPhone (where I really want this to work) even while Im on the local network I get a login prompt (image attached)
why do you think that happens ?
Philip
Philip
- httpdtest.png (62.06 KiB) Viewed 5107 times
- FlyingDiver
Testing the plugin using a browser is not recommended. Use curl in a terminal window.
In any case, are you using the latest version of the plugin, which was released 4 days ago? I fixed a bug that was causing it to not return a complete web page. Which curl doesn't care about, but browsers do. But then, Webhooks like IFTTT don't care either.
What are you trying to do in your iPhone browser with the plugin?
philipbasile
Thanks for replying SOOOO fast !
Ok so I want indigo to be more interactive so here is what I'm trying to do.
I'm on the way home, and I get a message from indigo saying...
Hi, it looks like your on the way home would you like me to open the garage door ?
I response yes and indigo opens the garage door.
Heres how.
I'm using the Beacon plugin with Geohopper for geolocation and the pushover plugin for issuing popup messages on my iPhone.
When I cross a geofence 2 blocks from my house the geohopper app on my iPhone sends a webhook to the beacon plugin running on indigo
The beacon plugin fires a trigger turning on the outside house lights if its dark out and issues a pushover alert.
The pushover plugin alert can include a URL Link with a title
it shows up in the pushover alert as a nice underlined YES link just like on a web page.
title is YES
the link is http://admin:password@MyDDNSaddress:908 ... arage=TRUE
Your HTTPd plugin sets the OpenGarage variable in indigo to TRUE
An on variable change trigger in indigo checks the OpenGarage variable and opens the garage door.
Once this all works there are so many ways to leverage this for interactive communication between indigo and my iPhone.
Heres how.
title is YES
- FlyingDiver
So, are you using the latest version of the plugin?
Also, the screen shot you show doesn't have the login info in the URL. If you put it there but either Pushover or Safari stripped it out, then you've got a problem.
