Input toggles output in Raspberry
Sam
Re: Input toggles output in Raspberry
Post by Sam »
Here is the result..
The file is from the Indigo Mac.. did a menu send xxxx "all programs .." to the RPIs but no luck
pi@raspberrypi:~/pibeacon $ tail -F temp/messageSend
master:  {"program":"master","i2c":[],"ipAddress":"192.168.10.21","pi":"10","temp":"48.3"}
w capital F
tail: temp/messageSend: filen avhuggen
OUTPUTgpio:      {"outputs":{"OUTPUTgpio-1-ONoff":{"17624462":{"actualGpioValue":"high"}}},"program":"OUTPUTgpio","i        pAddress":"192.168.10.21","pi":"10","ts":{"tz":"CEST","time":1544467141.2}}
^C
pi@raspberrypi:~/pibeacon $ ps -ef | grep .py
nobody     323     1  0 14:05 ?        00:00:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
root     19302     1  0 19:37 pts/0    00:00:00 python master.py
root     19625     1  0 19:37 pts/0    00:00:00 /usr/bin/python /home/pi/pibeacon/copyToTemp.py
root     19698     1  0 19:37 pts/0    00:00:01 /usr/bin/python /home/pi/pibeacon/OUTPUTgpio.py
root     19742     1  0 19:37 pts/0    00:00:00 /usr/bin/python /home/pi/pibeacon/receiveGPIOcommands.py 9999
pi       20758 16846  0 19:40 pts/0    00:00:00 grep --color=auto .py
could you do
0. do a edit RPi and save
1. go to rpi
2. set inverse on indigo
cat parameters, check for "outType": "1" if that changes
if it does not change then the send to RPi is not working
if it does change do
and set output on/off in indigo
then change to inverse
and do
check if it changes
OUTPUTgpio:  {"outputs":{"OUTPUTgpio-1-ONoff":{"1964742022":{"actualGpioValue":"low"}}},"program":"OUTPUTgpio","ipAddress":"192.168.1.198","pi":"0","ts":"tz":"CDT","time":1544467348.85}}
==> actualGpioValue":"low" or "high"
Sam
Post by Sam »
It changes fine..
OUTPUTgpio:      {"outputs":{"OUTPUTgpio-1-ONoff":{"17624462":{"actualGpioValue":"low"}}},"program":"OUTPUTgpio","ipAddress":"192.168.10.21","pi":"10","ts":{"tz":"CEST","time":1544470039.38}}
OUTPUTgpio:      {"outputs":{"OUTPUTgpio-1-ONoff":{"17624462":{"actualGpioValue":"high"}}},"program":"OUTPUTgpio","ipAddress":"192.168.10.21","pi":"10","ts":{"tz":"CEST","time":1544470158.17}}
OUTPUTgpio:      {"outputs":{"OUTPUTgpio-1-ONoff":{"17624462":{"actualGpioValue":"high"}}},"program":"OUTPUTgpio","ipAddress":"192.168.10.21","pi":"10","ts":{"tz":"CEST","time":1544470248.48}}
OUTPUTgpio:      {"outputs":{"OUTPUTgpio-1-ONoff":{"17624462":{"actualGpioValue":"low"}}},"program":"OUTPUTgpio","ipAddress":"192.168.10.21","pi":"10","ts":{"tz":"CEST","time":1544470387.83}}
One question..
The status in Indigos custom states never shows "on" when actualGpioValue is "high" regardless of whether I set the output type as normal or inverse. Is it supposed to work so?
OUTOUT normal
actualGpioValue=high --> status=off
actualGpioValue=low --> status=on
OUTPUT inverse
/Sam
What device type do you use ?
Could you delete and recreate. Not a dimmer but an on/off relay device.
Sam
Post by Sam »
I use OUTPUT-GPIO-1-ON/off . I have tested to delete and recreate it but with the same result.
/Sam
I am now following the up/down high/low through each step and have cleaned up some programming.. many places to look...
this is roughly the flow
action --> get dev defs --> send to RPI -> receive at RPI --> set GPIO --> send "actual value" back to plugin --> receive in plugin --> put into dev/state
will post a new version later today ..
will have this
Screen Shot 2018-12-10 at 17.40.05.png (29.85 KiB) Viewed 6573 times
Sam
could you try this version:
https://www.dropbox.com/s/88hxonsxvzgpo ... 0.zip?dl=1
you need to edit the GPIO device and save it. Then the device states will be populated.
Sam
Post by Sam »
In the new version, everything works perfect. I have tried normal / inverse output and everything looks good.
Thank you so much for all your help and all your work and for a very good plugin.
/Sam
Sam
is now published on the indigo store.
Version # one higher -- only cosmetic changes beyond yours
again thanks for testing
Sam
Post by Sam »
Hi Karl,
I would like some help to send one pulse to an output when an input becomes high (Action for UP). For example, high for 5 seconds.
It is possible?
/Sam
you can insert a sleep xx:
gpio -g write 21 1;sleep 5;gpio -g write 21 0
for gpio21 (still need to add the mode ... stuff infront)
ps
you can do
ssh pi@xxxx
then try any command = play with them, see what works..
gpio -g mode 18  out;gpio -g write 18 1; sleep 3 ; gpio-g write 18 0
if you like it, copy that whole line w/o the new line and paste into the command field action up / down ... in indigo device edit.
psps: here the manual for the gpio commands:
http://wiringpi.com/the-gpio-utility/
Sam
Post by Sam »
Nice.. Thanks a lot!
/Sam
Return to “piBeacon”
