Input toggles output in Raspberry
I would like an input (pushbutton) in Raspberry Pi to toggle an output each time input becomes high. How do you get that feature?
I would also like the output to show status (ON or OFF) in Indigo state at that time of operation. Is it possible?
Of course, you can create this via a trigger in Indigo, but I would like the feature to be in RBpi.
Thanks in advance!
/Sam
Thanks in advance!
/Sam
- 01.JPG (101.7 KiB) Viewed 6321 times
Re: Input toggles output in Raspberry
Yes, after thanksgiving.
Great! Thanks.
/Sam
/Sam
the string for the GPIO should work as you show it..
I guess you want to have the indigo device/state status to show ON/Off the the output gpio? .. the is not implemented as you circumvent the indigo part..
But you could use the GPIO in for that?
just a question.. how do you set it to OFF? with the down button, or another button?
Sorry,
What i meant was... i want the same pushbutton (normally open) connected to the input, to change the status of the output by an pulse on the input. The first pulse - sets the output to 1, the next pulse sets the output to 0 etc, if possible?
/Sam
/Sam
this should set gpio18 to 1 if current 0 and to 0 if currently 1 == toggle
if (gpio -g read 18 | grep 1 ); then gpio -g write 18 0; else gpio -g write 18 1 ; fiRe: Input toggles output in Raspberry
Works perfect!
Thanks Karl!
/Sam
Thanks Karl!
/Sam
Cool. Thanks for feedback.
Will add this to device edit menu as an example.
I have installed the latest version 7.98.255 and have some problems with the OUTPUT-GPIO-1-ON/off.
The Indigo state of that output shows ”off” when my relay is activated and ”on” when its deactivated.
I tried to inverse the OUTPUT type but do not get it right anyway.
Is there any setting for reverse that function that I have missed?
Another question..
I have a couple of RPi's that I only use for GPIO's and displays. Is there any easy way to turn off the beacon function in these Pi:s and only use the sensors, input, output and displays?
/Sam
Another question..
/Sam
A). the inverse option in device edit should do what you want ..
the device states show 3 states:
1.OUTPUT_00 = command send to raspberry * inversion factor
2. actual GpoiValue = is the physical output high/ low
3. Status = output_00
status and output are the same, just historical . In devices with many outputs 00-24 you could select which output is used for status.
I have stopped supporting multiple output sper indigo device.
so play with inverses/normal in device edit that SHOULD do it.
B) use non beacon RPI
1. delete RPI in initial setup
2. wait 1 minute, may be reload plugin, to clear everything
3. make new RPI with sensor only (# 10..19) in initial setup.
In my previous version (7.94.244), the control of the output worked well, but now I can not get Indigo state to show "on" when the physical relay is active, regardless of whether I set the output type as normal or inverse.
/Sam
/Sam
could you post parameters file from the RPi (is also on you indigo mac ~/indigo/pibeacon/parameters.x)
remove pwd ..
remove pwd ..
Is this the correct file?
/Sam
"BLEserial": "sequential",
"GPIOpwm": "1",
"IPnumberOfRPI": "192.168.10.21",
"IndigoOrSocket": "indigo",
"acceptJunkBeacons": "0",
"acceptNewiBeacons": -999,
"addNewOneWireSensors": "0",
"authentication": "digest",
"bluetoothONoff": "on",
"debugRPI": {
"debugRPIBEACON": 0,
"debugRPIBLE": 0,
"debugRPICALL": 0,
"debugRPIOUTPUT": 0,
"debugRPISENSOR": 0,
"debugRPImystuff": 0
"deleteHistoryAfterSeconds": 86400,
"deltaChangedSensor": "5",
"distanceUnits": "1.0",
"enableMuxI2C": "0",
"enableRebootCheck": "restartLoop,-",
"enableiBeacons": "0",
"indigoInputPORT": 12087,
"ipOfServer": "192.168.10.11",
"minPinActiveTimeForShutdown": 60,
"myPiNumber": "10",
"networkType": "fullIndigo",
"output": {
"OUTPUTgpio-1-ONoff": {
"17624462": [
"gpio": "21",
"initialValue": "-",
"outType": "0"
"passwordOfServer": "XXXXX",
"portOfServer": "8176",
"pressureUnits": "bar",
"rPiCommandPORT": "9999",
"rPiRestartCommand": "master",
"rebootCommand": "sudo killall -9 python; sleep 2;sudo reboot",
"rebootHour": 1,
"rebootWatchDogTime": "-1",
"restartBLEifNoConnect": false,
"sendAfterSeconds": "60",
"sendFullUUID": "0",
"sendToIndigoSecs": 90,
"sensorList": "",
"sensorRefreshSecs": 20.0,
"sensors": {},
"shutDownPinInput": -1,
"shutDownPinOutput": -1,
"tempUnits": "Celsius",
"timeStamp": "2018-12-10-18:15:25",
"useRTC": "0",
"useRamDiskForLogfiles": "0",
"userIdOfServer": "Indigo",
"wifiOFF": "off"
}Re: Input toggles output in Raspberry
yes looks good...
could you go into the rpi and do:
cd pibeacon
sudo python master.py
tail -F temp/messageSend
w capital F
it should show any messages and also error messages
you should see something like this:
and some other lines
and do ps -ef | grep .py
should show:
cd pibeacon
w capital F
OUTPUTgpio: {"outputs":{"OUTPUTgpio-1-ONoff":{"1964742022":{"actualGpioValue":"low"}}},"program":"OUTPUTgpio","ipAddress":"192.168.1.198","pi":"0"}
should show:
pi@raspberrypi:~/pibeacon $ ps -ef | grep .py
nobody 288 1 0 02:00 ? 00:00:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
pi 3044 2631 0 12:25 pts/0 00:00:00 grep --color=auto .py
root 30898 1 0 11:07 ? 00:00:06 /usr/bin/python /home/pi/pibeacon/master.py
root 31355 1 0 11:07 ? 00:00:02 /usr/bin/python /home/pi/pibeacon/copyToTemp.py
root 31482 1 0 11:07 ? 00:00:34 /usr/bin/python /home/pi/pibeacon/OUTPUTgpio.py <<<<<=== this must run
root 31519 1 0 11:07 ? 00:00:22 /usr/bin/python /home/pi/pibeacon/INPUTgpio.py
root 31582 1 0 11:07 ? 00:00:10 /usr/bin/python /home/pi/pibeacon/tmp006.py
root 31588 1 0 11:07 ? 00:00:01 /usr/bin/python /home/pi/pibeacon/receiveGPIOcommands.py 9999
root 31821 1 4 11:07 ? 00:03:34 /usr/bin/python /home/pi/pibeacon/beaconloop.py
root 31972 1 0 11:07 ? 00:00:02 /usr/bin/python /home/pi/pibeacon/BLEconnect.py
the line
"outType": "1"
should flip when you do normal/inverse.
and did you post the file from the RPI or from the indigo MAC.ie are the files updated?
do a menu send xxxx "all programs .." to the RPIs
"outType": "1"
