Enphase Envoy-S Solar Power Plugin (with Panel Monitoring)
Re: Enphase Envoy-S Solar Power Plugin (with Panel Monitorin
The plugins log settings are set to high. I restarted Indigo and ran it for a bit, but log looks the same.
Ok- troubleshooting now.shmigator wrote:The plugins log settings are set to high. I restarted Indigo and ran it for a bit, but log looks the same.
Check - are you running 0.1.3?
Seems like you are running a really old version - given the logging.
Have checked - your version is logging things that shouldn't exist in version 0.1.3 and have checked github - the uptodate version is there.
Suspect you are running version 0.0.5 - which is the file library version.
See first page of thread:
Or here:
https://github.com/Ghawken/IndigoEnphaseEnvoy/releases
Update - as per the thread - think that will fix issues.
Haven't ruled out a Indigo6 -> Indigo7 change - but let me know if still issues.
Glenn
Yes !! not sure how I ended up on an older version,.
It all seems to be working now. Thank you.
Now to just figure out a cool way to show it on a control page ....
- Its Alive
- enphaseProperties.png (87.71 KiB) Viewed 14870 times
Great to hear.shmigator wrote: Now to just figure out a cool way to show it on a control page ....
This is my control page - which also turns on/off pool heating depending on power production/usage.
(as essentially no point exporting power back to grid as no $)
Glenn
- Solar.jpg (186.31 KiB) Viewed 14798 times
That looks great.
I was thinking something similar but with colors kinda like a heat map.
Like the picture attached fore now, hoping I can figure something out with a much wider range of colors.
- Legeng
- Legend.png (9.7 KiB) Viewed 14804 times
Great plugin thanks Glenn!
Just commissioned an 11 panel system and integrated with Indigo V7.1.1 using your plugin V0.1.6 which was quite straightforward. - thanks!!
However, having developed a control page for the system I am a bit puzzled by the results.
Referring to the attachment, I have displayed the output of each panel using the control panel custom state "Power Generated Watts" and the Envoy output using the "Power Production (watts)" custom states. You will note that the individual panel outputs reported by each of the IQ7 micro inverters do not sum to the production figure reported by the Envoy-S. The discrepancy seems higher than losses and metering errors that might occur.
On delving into the Custom States and other aspects of the plugin, there are also a few more queries:
- The Custom States listed for each of the panel devices do not correlate to the states presented when editing a control panel. Is this a plugin, Indigo or operator issue? For example, when designing the control panel I have selected the "Power Generated" device state although the Custom State on the panel device is "watts".
- The Custom States for the Envoy-S also do not correlate directly with the device states for the Envoy device on the control page. I am also a little confused by the states for daily figures. For example am I correct in assuming that the device states such as "Power Production Today (watts)" is actually in watthours and not watts?
- If I "Refresh Data Now" from the Plugin menu I get the following error for each panel device (just one is listed here, but all 11 panels generate the same error):
and need to reload the plugin to restore communications with the panels.
- If I check for plugin updates, I get the following error:
Any suggestions on one (or all!) of the issues raised above would be of great help!!
mclass
Enphase Envoy Plugin Error connecting to Device:Enphase SolarPanel 9Error is:key sourceXML not found in dict
Error device "Enphase SolarPanel 9" state key powerStatus not defined (ignoring update request)
Enphase Envoy Plugin Error Error in plugin execution MenuAction:
File "plugin.py", line 208, in checkForUpdates
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Server Plugin/ghpu.py", line 86, in checkForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Server Plugin/ghpu.py", line 178, in _prepareForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Server Plugin/ghpu.py", line 95, in getUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Server Plugin/ghpu.py", line 120, in getLatestRelease
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Server Plugin/ghpu.py", line 148, in _GET
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
mclass
- Solar Control Page.jpg (171.2 KiB) Viewed 13494 times
Welcome!mclass wrote:Great plugin thanks Glenn!
mclass
Thanks for the feedback.
Working through your issues:
The panels can only be updated every 10 minutes or so, whereas the consumption/production is updated much more frequently (?60 seconds)You will note that the individual panel outputs reported by each of the IQ7 micro inverters do not sum to the production figure reported by the Envoy-S. The discrepancy seems higher than losses and metering errors that might occur.
So there is often a difference depending on shading and what changes you might be experiencing in that time.
If you enabled debugging - you will see when the large panel data is pulled and can check then.
Should equal each other.
By design.- The Custom States listed for each of the panel devices do not correlate to the states presented when editing a control panel. Is this a plugin, Indigo or operator issue? For example, when designing the control panel I have selected the "Power Generated" device state although the Custom State on the panel device is "watts".
Perhaps could be clearer.
But the control panel/trigger can have different longer explanations rather than just the states
But yes state watts = Power Generated
Oops!- If I "Refresh Data Now" from the Plugin menu I get the following error for each panel device (just one is listed here, but all 11 panels generate the same error):
That is an error - which will get on and fix.
The update error is an known issue - have a fix which have added to other plugins and will add to enphase plugin as well.
Glenn
Below should fix those issues.
Plugin is probably due for a complete overhaul and bring up to Indigo 7 type logging... perhaps another day...
Let me know if any other issues/additions which would seem to make sense.
Cheers
Glenn
New Release
0.1.8
In Plugin Store and github.
https://www.indigodomo.com/pluginstore/105/
0.1.8
Fix for updating code. Add option to open Pluginstore
(checks against github releases)
Fix for Refresh Devices manually via menu
(Warning - cannot refresh envoy to frequently -- if hammer envoy will timeout and freeze; typically takes an hour or two to come back to life; worse case need to restart)
0.1.7
Add Last Communication state from Panel to Panel Device
(this is reported time by Panel to Envoy-S - not related to Plugin communication)
Can be used to check if micro-inverter issues
Cheers
Glenn
New Release
0.1.8
0.1.8
0.1.7
Wow! That was quick, thanks.
I’m away from mr computer but will check ASAP.
Re the daily production, am I correct in assuming that this is watthr and not watts?
Thanks again!
mclass
Thanks again!
mclass
No rush!mclass wrote:Wow! That was quick, thanks.
Thanks again!
mclass
Yes I believe everything except immediate/Now usage is in watthours.
So today’s production, 7days production, today’s consumption , 7 days consumption in watt hours
Will update the trigger / control page descriptions next time
Glenn
Thanks Glen! New version loaded & seems just fine.
And you’ve educated the Enphase Noobie as well
mclass
mclass
Hi Glenn,
As per my previous post, your plugin and the control pages I have created are running well.
I am also running a Fronius system, that has the feature of being able to enter the "buy" electricity tariff and the export tariff, so you can report on the financial benefits of the pv system.
Have you/would you consider adding this feature to your Enphase plugin ie create a new custom state in $'s, based on tariffs entered in the Envoy device config menu?
Alternatively is there a simple way (other than writing a script) to perform arithmetic using Indigo custom device states and variables eg multiply the production today custom state from the Envoy by the tariff stored in a variable and place in another variable for display on a control page.
Thought I'd ask before applying my very limited Python skills to arrive at a more complex solution that might otherwise be more readily solved
mclass
mclass
Okay.
Let me think on that one. Probably more complicated than first glance with different time of day (peak, off-peak, shoulder..) so probably needs to be calculated as happens which might be problematic/not sure have that data.
Also a few scripts I have turning pool heating/pump on/off depending on solar generation/exporting power. They work well. But would be a bit more accessible as a plugin device that might consider as well..
Glenn
Glenn
My use case is relatively straightforward, as I don’t have a time of day tariff, but I understand that others may do.
Happy (and productive!) thinking
mclass
mclass
No problem.mclass wrote:Thanks!
mclass
Will probably add an separate enphase cost device and allow user definable variable for cost per kWh. Then this device can report $ and kWh for all states reported. Think todaykWh, 7dayskWh.
Anything more like time of use tariff, monthly, etc would require the plugin to constantly store the data and calculate this itself. Not impossible by any means but certainly adding a level of complexity that is probably outside day-day usage.
Glenn
