Startup error on v2.0.4 (in the plugin store)
jay (support)
Post by jay (support) »
FYI, I just installed 2.0.4 from the plugin store and get this when the plugin starts up:
   EPS - Device Extensions Error   Exception in plugcache._parsePlist line 596: [Errno 2] No such file or directory: u'/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Example Device - Speed Control.indigoPlugin/Contents/Info.plist'
							 CODE: plist = open(path + "/Contents/Info.plist")
   EPS - Device Extensions Error   Exception encountered with /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Example Device - Speed Control.indigoPlugin (this error is NOT critical)
   EPS - Device Extensions Error   Exception in plugcache.refresh line 539: 'key id not found in dict'
							 CODE: if plugInfo["id"] == self.factory.plugin.pluginId:
Colorado4Wheeler
Re: Startup error on v2.0.4 (in the plugin store)
Post by Colorado4Wheeler »
Hmmm. Download the one on Git, it's been updated and has some experimental stuff in there but the stuff that was already in place should be fine. I'm, quite literally, writing a massive update for DE right now.
Colorado4Wheeler
Ahh, it's your example device - it cannot read the info.plist on Example Device - Speed Control.indigoPlugin. Still a bit of a bug (and one that I'm working on in this next release, dealing with oddities in the XML and plist files) but you should be 100% operational regardless of that error because it will move on to the next plugin.
There are, so far, like 3-4 plugins that bomb out there - I've blocked the others already.
jay (support)
Are you using Python's built in plistlib library? I've never had it choke on a valid plist before.
Colorado4Wheeler
jay (support) wrote:Are you using Python's built in plistlib library? I've never had it choke on a valid plist before.
Not in the release that is published because it was sort of on-the-fly, but the new one does. DE was my first 'big' plugin and so there has been much learned since then ;).
Colorado4Wheeler
I'd be lying if I didn't admit that it's kind of cool that one of the devs has use for one of my plugins :D.
jay (support)
Colorado4Wheeler wrote:I'd be lying if I didn't admit that it's kind of cool that one of the devs has use for one of my plugins :D.
We both use quite a few plugins by you guys (I think I use about 15 or so on my production system). At some point, I hope to spend some time with HomeKit Bridge - but time is not something I have a lot of recently.
Keep cranking them out!
Korey
Post by Korey »
I'm getting a similar error as well:
Just 1 device trying to convert ºC to ºF
I have tried a device and a variable, and trashing the plugin prefs.
Mar 20, 2019, 7:44:27 AM
   EPS - Device Extensions Error   Exception in plug.formFieldChanged line 1179: 'ascii' codec can't encode character u'\xba' in position 4: ordinal not in range(128)
							 CODE: self.logger.debug ("Plugin device '{0}' configuration field changed".format(indigo.devices[devId].name))
   EPS - Device Extensions Error   Exception in plug.validateDeviceConfigUi line 560: 'ascii' codec can't encode character u'\xba' in position 4: ordinal not in range(128)
							 CODE: self.logger.threaddebug ("Validating configuration on '{0}'".format(dev.name))
   EPS - Device Extensions Error   Exception in plug.closedDeviceConfigUi line 602: 'ascii' codec can't encode character u'\xba' in position 4: ordinal not in range(128)
							 CODE: self.logger.threaddebug ("Plugin device '{0}' configuration dialog closed".format(dev.name))
Mar 20, 2019, 7:44:58 AM
   Reloading plugin "EPS - Device Extensions 2.0.4"
   Stopping plugin "EPS - Device Extensions 2.0.4" (pid 53964)
   EPS - Device Extensions Error   Exception in plug.deviceStopComm line 513: 'ascii' codec can't encode character u'\xba' in position 4: ordinal not in range(128)
							 CODE: self.logger.threaddebug ("Plugin device '{0}' stopped communication".format(dev.name))
   Stopped plugin "EPS - Device Extensions 2.0.4"
   Starting plugin "EPS - Device Extensions 2.0.4" (pid 54363)
   Started plugin "EPS - Device Extensions 2.0.4"
   EPS - Device Extensions Warning Upgrading plugin from version 1.53 or earlier
   EPS - Device Extensions Error   Exception in plug.deviceStartComm line 275: 'ascii' codec can't encode character u'\xba' in position 4: ordinal not in range(128)
							 CODE: self.logger.threaddebug ("Starting communications on '{0}'".format(dev.name))
Screen Shot 2019-03-20 at 10.50.16 AM.png (432.08 KiB) Viewed 3822 times
Korey
