I have Four Raspberry pi setup with pibeacon, and I am trying to add a ble temp sensor.
I have a MYBlue T ble temp sensor and I am having trouble getting it to send back any temp data .
It shows the beacon Mac address and that always updates
but when I edited to add ble sensor it won't update
not sure what logs to add
thanks
Bob
Ble Temp Sensor
Ble Temp Sensor
- temp 3.jpeg (209.04 KiB) Viewed 2431 times
- temp 2.jpeg (112.39 KiB) Viewed 2431 times
- temp 1.jpeg (38.65 KiB) Viewed 2431 times
Re: Ble Temp Sensor
A.) check if on RPI
~/parameters has entries for BLEsensor .. something like this:
if yes .. I need to dig deeper
if no:
1. check if connection works fine
2. push config to RPI # x in menu
but it should update on its own .. need to check the code
B)
are you sure the MAC tuber is correct? they only show the first 4 and last 4 letters..
use the BLEscan tool on the rpi to figure out the MAC #
"sensors": {
"BLEsensor": {
"862350368": {
"mac": "C5:7D:B7:58:B4:22",
"multTemp": "1",
"multiplyTemp": "1.",
"offsetTemp": "0.",
"type": "myBLUEt",
"updateIndigoTiming": "0"
if no:
B)
Re: Ble Temp Sensor
Here is the section from the pi ~/pibeacon/parameters
Does that sensor send more than one Mac address?
I'm fairly new to this
thanks
Bob
thanks
Bob
- pi_sensor.jpeg (125.53 KiB) Viewed 2398 times
Re: Ble Temp Sensor
parameter file looks good
the sensor sends every 60-90 secs a simple BLE package
just how did you get the mac number? .. it shows it backwards in the phone scanning tools
in menu you can select BLE report .. that will do most of the scanning for you and print a report to the indigo logfile .. (it will need to reboot the RPI after the scan)
Re: Ble Temp Sensor
this will do the scanning on the RPi (thats what the menu option does):
then find your reverse BLEsensor MAC# (first 2 and last 2 digits) and copy the WHOLE number to the indigo device
output looks like:
sudo hciconfig hci0 down; sudo hciconfig hci0 up ; sudo timeout -s SIGINT 100s hcitool lescan
output looks like:
LE Scan ...
33:9E:60:AA:C8:6B (unknown)
79:BB:9F:B1:B1:39 (unknown)
2C:E6:96:AE:59:96 (unknown)
40:CB:C0:D0:FF:C2 (unknown)
C5:7D:B7:58:B4:22 224BD75C <<<<< this is my BLEtemp sensor MAC # C5:7D:B7:58:B4:22
D0:D2:B0:88:7B:76 (unknown)
00:EA:23:11:2B:E4 (unknown)
00:EA:23:11:2B:E4 XY-2BE4-59
00:EA:24:02:EC:04 (unknown)
00:EA:24:02:EC:04 XY-EC04-5E
DRe: Ble Temp Sensor
I did have an incorrect Mac address,
thank you for your help
Bob
Bob
Re: Ble Temp Sensor
Works now?
