EPS - Super Conditions Error Exception in conditions.conditionEquals line 520: invalid literal for int() with base 10: ''
CODE: devEx = indigo.devices[int(propsDict["device" + str(index)])]Code: Select all
EPS - Super Conditions Error Exception in plugcache._parsePlist line 585: [Errno 2] No such file or directory: u'/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Info.plist'
CODE: plist = open(path + "/Contents/Info.plist")
EPS - Super Conditions Error Exception encountered with /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin (this error is NOT critical)
EPS - Super Conditions Error Exception in plugcache.refresh line 534: 'key id not found in dict'
CODE: if plugInfo["id"] == self.factory.plugin.pluginId:
