Weird error message
jmdraper
Weird error message
Post by jmdraper »
I have a super conditions action set up that appears to be functioning properly but every time it runs, it produces this error message in the logs. Any ideas what's wrong? Thanks!
   EPS - Super Conditions Error    Exception in conditions.conditionEquals line 520: invalid literal for int() with base 10: ''
							 CODE: devEx = indigo.devices[int(propsDict["device" + str(index)])]
Colorado4Wheeler
Re: Weird error message
Post by Colorado4Wheeler »
I need to give a bit of love to an update for Super Conditions and Powermiser. That being said, from looking at the code block that message refers to it looks like perhaps that device you were once referencing in that condition may no longer exist. Is it possible you changed or removed something the condition was looking to? I need to go through some of these and try to (forgive the phrase) idiot proof the code a bit to look specifically for things like this rather than pop a generic message.
bsp9493
Post by bsp9493 »
I too have recently been getting a strange error message... I'm guessing it is related.
Anything I need to worry about?
See below
 EPS - Super Conditions Error    Exception in plugcache._parsePlist line 585: [Errno 2] No such file or directory: u'/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Info.plist'
							 CODE: plist = open(path + "/Contents/Info.plist")
   EPS - Super Conditions Error    Exception encountered with /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin (this error is NOT critical)
   EPS - Super Conditions Error    Exception in plugcache.refresh line 534: 'key id not found in dict'
							 CODE: if plugInfo["id"] == self.factory.plugin.pluginId:
Thanx
dave
Colorado4Wheeler
That's nothing to worry about, and will only pop up when you start the plugin. Interesting it's bombing on the HKB plugin, I'll have to look into that one.
Return to “Super Conditions (IF-THEN-ELSE)”
