That isn't a known/valid option according to my documentation.I turned on debug logging and I can see it get's an command for input-selector 18, but I guess that's not mapping to anything?
Adam
Onkyo Network Remote Plugin Threaddebug Command queue has 1 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLI12
Onkyo Network Remote Plugin Threaddebug Send command completed.
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('input-selector', 18)
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('listening-mode', 'theater-dimensional')
Onkyo Network Remote Plugin Threaddebug Found response match: listeningModeQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "listeningMode" to "theater-dimensional"
Because it was built by hardware engineers alone...mbordas wrote:That's confusing, why would it call it input-selector 18, but the command is 12?
Sounds like something a software engineer would say..jay (support) wrote:Because it was built by hardware engineers alone...mbordas wrote:That's confusing, why would it call it input-selector 18, but the command is 12?
Yep, because we always know better than those nerds...durosity wrote:Sounds like something a software engineer would say..
All the trash talk notwithstanding, you do realize that 18 decimal = 12 hex?mbordas wrote:That's confusing, why would it call it input-selector 18, but the command is 12?
So this is interesting... as others have pointed out, all numbers in the Onkyo protocol use hexadecimal; that isn't the interesting part, what is interesting is that normally they come back in hex too, so it is returning a standard integer in base 10 but requiring it to be sent in base 16. This is completely different than their other messages but hey we can work with it. I'll add it to the plugin - this is considered a TV input or is that a label you gave it?That's confusing, why would it call it input-selector 18, but the command is 12?
Okay, so the docs on this are horrible, but I found a couple of other possibilities... Give these a try via the Send Arbitrary Command feature:I tried both those commands and could not initiate an Internet radio stream. For the more, I upgraded to the new plug-in version and now my FM/a.m. radio selection no longer works. Any thoughts? Also, regarding the Internet radio thing, the plug-in has source selection etc.… Is it possible to add “play“ and “pause” functions so that Internet radio streams can be started and paused?
This will be available in the next version... I double checked and it is not listed as a valid input number in any of the open source repos out there that use the eISCP commands - is this a newer receiver or something?I turned on debug logging and I can see it get's an command for input-selector 18, but I guess that's not mapping to anything?
Onkyo Network Remote Plugin Debug enabled (on Low) by user
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZ26
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZ25
Onkyo Network Remote Plugin Debug Effect execution: Calling function zone2SelectorQueryReceived
Onkyo Network Remote Plugin Debug Updating zone 2 input number/label: 25 / AM
Onkyo Network Remote Plugin Debug Received direct tune action to 089.30
Onkyo Network Remote Plugin Debug Sending tune command for 08930
Onkyo Network Remote Plugin Debug Updating zone 2 input number/label: 24 / FM
Onkyo Network Remote Plugin Debug Received direct tune action to 092.30
Onkyo Network Remote Plugin Debug Sending tune command for 09230
Onkyo Network Remote Plugin Debug Received direct tune action to 97.5
Onkyo Network Remote Plugin Debug Sending tune command for 09750
Onkyo Network Remote Plugin Debug Executing full status update request...
Onkyo Network Remote Plugin Debug Sending eISCP Command: PWRQSTN
Onkyo Network Remote Plugin Debug Effect execution: Update state "isPoweredOn" to "True" with UIValue "On"
Onkyo Network Remote Plugin Debug Effect execution: Calling function updateVirtualMasterVolume
Onkyo Network Remote Plugin Debug Sending eISCP Command: MVLQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: AMTQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: HAOQSTN
Onkyo Network Remote Plugin Debug Effect execution: Update state "masterVolumeLevel" to "81"
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLIQSTN
Onkyo Network Remote Plugin Debug Effect execution: Update state "isMuted" to "False"
Onkyo Network Remote Plugin Debug Sending eISCP Command: SPAQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SPBQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLPQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: HDOQSTN
Onkyo Network Remote Plugin Debug Effect execution: Update state "hdmiAudioOut" to "False"
Onkyo Network Remote Plugin Debug Sending eISCP Command: RESQSTN
Received INSTEON "Thermostat MBR" temperature changed to 69.0
Onkyo Network Remote Plugin Debug Sending eISCP Command: VWMQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: VPMQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: LMDQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLAQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: TUNQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NATQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NALQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NTIQSTN
Onkyo Network Remote Plugin Debug Effect execution: Update state "listeningMode" to "stereo"
Onkyo Network Remote Plugin Debug Sending eISCP Command: NSTQSTN
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayArtist" to "BBC World Service News"
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayAlbum" to "London, United Kingdom"
Onkyo Network Remote Plugin Debug Sending eISCP Command: ZPWQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZQSTN
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayTitle" to "World News"
Onkyo Network Remote Plugin Debug Sending eISCP Command: ZVLQSTN
Onkyo Network Remote Plugin Debug Effect execution: Update state "videoOutputResolution" to "through"
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayStatus" to "Pxx"
Onkyo Network Remote Plugin Debug Effect execution: Calling function inputSelectorQueryReceived
Onkyo Network Remote Plugin Debug Updating current input number/label: 2B / NETWORK, NET
Onkyo Network Remote Plugin Debug Effect execution: Update state "speakerAPower" to "False"
Onkyo Network Remote Plugin Debug Effect execution: Update state "speakerBPower" to "False"
Onkyo Network Remote Plugin Debug Effect execution: Update state "videoWideScreenMode" to "auto"
Onkyo Network Remote Plugin Debug Effect execution: Update state "zone2PoweredOn" to "True" with UIValue "On"
Onkyo Network Remote Plugin Debug Effect execution: Update state "zone2VolumeLevel" to "0"
Onkyo Network Remote Plugin Debug Effect execution: Calling function updateVirtualZone2Volume
******************************* some errors...
Onkyo Network Remote Plugin Debug Sending eISCP Command: PWR00
Onkyo Network Remote Plugin Debug Failed to parse eISCP message, message ignored: !1NLT0E22000000000001000E00
Onkyo Network Remote Plugin Debug Effect execution: Update state "isPoweredOn" to "False" with UIValue "Standby"
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayStatus" to "Sxx"
Onkyo Network Remote Plugin Debug Sending eISCP Command: PWR01
Onkyo Network Remote Plugin Debug Failed to parse eISCP message, message ignored: !1NMSMxxxxx20E
It is possible an update broke the parsing expression or something... we will need to see the actual data being received back from the device whenever the plugin queries for the frequency. You can either turn the debugging up to full ( above what you posted, I believe) and search for it OR that data should already available in the plugin's log file; should be at:Plugin is working fine except the tuner frequency does not update. The plugin will switch AM, FM and tune channels as seen on the unit itself, but will not update the tuner frequency in the little dialog box at the bottom of the Indigo device page. As such it does not update on the control page either. Used to work....
Sep 21, 2018, 7:08:06 PM
Onkyo Network Remote Plugin Debug Plugin preferences updated
Onkyo Network Remote Plugin Debugging enabled... remember to turn off when done!
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:01/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:02/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:03/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:04/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:05/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:06/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:07/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:08/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:09/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:10/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:11/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:12/--:--:--')
Onkyo Network Remote Plugin Threaddebug Execute condition failed, skipping execution for command: directTune
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('tuning', 35120)
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:13/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:14/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:15/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:16/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:17/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received: ('net-usb-time-info', '00:01:18/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:18/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('tuning', 37424)
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:19/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:20/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:21/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:22/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:23/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:24/--:--:--')
Onkyo Network Remote Plugin Debug Received direct tune action to 090.10
Onkyo Network Remote Plugin Debug Sending tune command for 09010
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:25/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('tuning', 36880)
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:26/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:27/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:28/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:29/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:30/--:--:--')
Onkyo Network Remote Plugin Debug Received direct tune action to 091.10
Onkyo Network Remote Plugin Debug Sending tune command for 09110
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('tuning', 37136)
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:31/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:32/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:33/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:34/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:35/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:36/--:--:--')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:37/--:--:--')
