Zipato mini keypad and Zwave Lock Manager
- marketability
Re: Zipato mini keypad and Zwave Lock Manager
Hi
Followed your instructions above but having real problems storing an RFID Tag code
Can set a manual code OK
but the RFID... no joy
any suggestions?
any suggestions?
Sorry Mat, missed your post.mat wrote:Has anyone got the beep working? ie beep for 30 seconds before the alarm arms when away is set?
I'll have a look; I presume this is described in the manual?
Could you elaborate?marketability wrote:Can set a manual code OK
Are you getting errors?
Trying and not getting response?
Trying and getting response but not working?
- marketability
Thanks for the fast response
just this second worked out that if read things written by clever people... SLOWLY.... AND CAREFULLY... and at leastTWICE
I can get things to work!!!
sorry to bother you
sorry to bother you
Excellentmarketability wrote:Thanks for the fast response
Ok, I've read up on this and can do it.mat wrote:Has anyone got the beep working? ie beep for 30 seconds before the alarm arms when away is set?
When you edit your Zipato's devices, has Matt exposed parameter 2 and 3 in the UI for you? (Notification timer/timeout and acknowledgment timer/timeout)
I still need to code in the actual commands to sound the alarm, but I need to know whether to provide a UI for the above parameters or not.
Peter
This is what I have. Is that what your after?
Thanks for looking at this
- Screen Shot 2017-08-27 at 23.14.23.png (77.19 KiB) Viewed 6187 times
Late 2018 mini 10.14
Yep, that's good.
Will get this sorted.
Thanks, thats great - enjoy the BH weekend though - weather should be good tomorrow
stuartcolman
Peter,
Did you get the beeps working? If so how do you set it etc?
Stuart
Stuart
I partly got it working. However, it wasn’t stable and drained a lot of battery, at least the way I wanted to use it. So I disabled it
I have had a Zipato minneolas keypad for a number of years now, and I have read the manual provided, forums replies on this portable, and I still have no idea in how to set user codes and make this device work correctly
. I would love to hear from someone that have managed to configure and great this device to work. I'm particular looking for step by step instructions with some screenshots.
Can you link the manual for it?
