Zipato mini keypad and Zwave Lock Manager
marketability
Re: Zipato mini keypad and Zwave Lock Manager
Post by marketability »
Hi
Followed your instructions above but having real problems storing an RFID Tag code
Can set a manual code OK
but the RFID... no joy
any suggestions?
howartp
Post by howartp »
mat wrote:Has anyone got the beep working? ie beep for 30 seconds before the alarm arms when away is set?
Sorry Mat, missed your post.
I'll have a look; I presume this is described in the manual?
marketability wrote:Can set a manual code OK
Could you elaborate?
Are you getting errors?
Trying and not getting response?
Trying and getting response but not working?
marketability
Thanks for the fast response
just this second worked out that if read things written by clever people... SLOWLY.... AND CAREFULLY... and at leastTWICE
I can get things to work!!!
sorry to bother you
howartp
Post by howartp »
marketability wrote:Thanks for the fast response
Excellent :)
Ok, I've read up on this and can do it.
When you edit your Zipato's devices, has Matt exposed parameter 2 and 3 in the UI for you? (Notification timer/timeout and acknowledgment timer/timeout)
I still need to code in the actual commands to sound the alarm, but I need to know whether to provide a UI for the above parameters or not.
Peter
mat
Post by mat »
This is what I have. Is that what your after? :? Thanks for looking at this :)
Screen Shot 2017-08-27 at 23.14.23.png (77.19 KiB) Viewed 6181 times
Late 2018 mini 10.14
howartp
Post by howartp »
Yep, that's good.
Will get this sorted.
mat
Post by mat »
Thanks, thats great - enjoy the BH weekend though - weather should be good tomorrow
stuartcolman
Post by stuartcolman »
Peter,
Did you get the beeps working? If so how do you set it etc?
Stuart
krissh
Post by krissh »
I partly got it working. However, it wasn’t stable and drained a lot of battery, at least the way I wanted to use it. So I disabled it
Eagleye
Post by Eagleye »
I have had a Zipato minneolas keypad for a number of years now, and I have read the manual provided, forums replies on this portable, and I still have no idea in how to set user codes and make this device work correctly :? . I would love to hear from someone that have managed to configure and great this device to work. I'm particular looking for step by step instructions with some screenshots.
howartp
Post by howartp »
Can you link the manual for it?
Eagleye
Post by Eagleye »
