Mac Apps plugin
Mac Apps plugin
This is another very simple plugin (like my others), that I nevertheless find useful and hope some others will as well.
Mac Apps just presents applications/helpers/daemons as Indigo relay devices and reports some statistics about them.
This is a half-replacement for the Mac System plugin, which unfortunately has not been updated in a while. A separate plugin replaces the other functionality of Mac System.
(I used, and relied on, Mac System but it stopped working with some applications, and I got infrequent but persistent "ServerCommunication" errors that I could never quite track down. So I decided to take the basic concept and rewrite it from scratch.)
Details: https://github.com/kmarkley/Indigo-Mac- ... /README.md
Download: https://github.com/kmarkley/Indigo-Mac- ... ses/latest
- jay (support)
- Site Admin
- Contact:
Re: Mac Apps plugin
Excellent, thanks for the contribution. I'll add it into the #new4indigo queue on social media.
Re: Mac Apps plugin
New version 0.0.4 released:
• fix Indigo server API version
• get cores count from `sysctl`
• refactor for efficiency
• GitHubPluginUpdater
• tweaks and bug fixes
- durosity
Re: Mac Apps plugin
Thanks for building this plugin.. I also used the old Mac System plugin until it was abandoned.. this one is much more stable!
Re: Mac Apps plugin
this is a very cool plugin
I have tested some apps
there is one app which I can not turn on but I can close it which is most important
is it the app not allowing it or something like that ?
Re: Mac Apps plugin
Hi koberg. That is a little unusual.
First, check if the application has a ".app" extension (possibly hidden). If you don't see it in the Finder, choose File>Get Info from the menu, and disclose the Name & Extension section.
If the application does not have a ".app" extension, use the Helper type plugin device in Indigo.
If that doesn't fix it, I'll need some more information. Like the name and full path to the application.
Re: Mac Apps plugin
one question is it because it is located like this?
applications / Cisco / Cisco AnyConnect Secure Mobility Client.app
in a folder ?
I can still quit it when it is launched but it say error quitting but it quits
and also say error launching but do not launch in the event log.
in a folder ?
Re: Mac Apps plugin
all right I got it running it was the folder I forgot sorry.
I can now start and quit it I use the command "other process name" to quit
and it is working now but still got this error
but quit and launch is working.
Mac Apps Error failed to quit application "Cisco/Cisco AnyConnect Secure Mobility Client"Re: Mac Apps plugin
You may still have the folders wrong. I think the first part should look like this.
- Screen Shot 2018-01-14 at 9.00.05 AM.png (73.14 KiB) Viewed 6764 times
Re: Mac Apps plugin
yes that is also working did that thanks
still got this error in the log
but still quit
Mac Apps Error failed to quit application "Cisco AnyConnect Secure Mobility Client"Re: Mac Apps plugin
Turn on debug logging for the plugin and try again. That should provide more information on the error.
I suspect you may be better off with using the forced quit method. Try it and see if there are any adverse effects.
Re: Mac Apps plugin
here is what the log says
whiteout force quit
The force quit is not working as good I have to hit off twice before it is working but in normal mode it is working first time. but also with the error.
force quit.
whiteout force quit
Mac Apps Debug updating states on device "NewsHosting VPN":
Mac Apps Debug elapsed_secs: 1606
Mac Apps Debug elapsed_time: 26:46
Mac Apps Debug percent_cpu: 0.025
Mac Apps Debug actionControlDimmerRelay: cisco vpn
Mac Apps launching application "Cisco AnyConnect Secure Mobility Client"
Mac Apps "cisco vpn" on
Mac Apps Debug updating states on device "cisco vpn":
Mac Apps Debug elapsed_time: 00:00
Mac Apps Debug last_start: 2018-01-14 17:12:17
Mac Apps Debug onOffState: True
Mac Apps Debug percent_cpu: 5.7875
Mac Apps Debug percent_mem: 0.1
Mac Apps Debug process_id: 5079
Mac Apps Debug process_status: running
Mac Apps Debug 62:66: execution error: Cisco AnyConnect Secure Mobility Client modtog en fejl: Bruger annullerede. (-128)
Mac Apps "cisco vpn" off
Mac Apps Debug onOffState: False
Mac Apps Debug percent_mem: 0.0
Mac Apps Debug process_status: off
force quit.
Mac Apps Debug elapsed_secs: 1727
Mac Apps Debug elapsed_time: 28:47
Mac Apps Debug percent_cpu: 0.0375
Mac Apps Debug validateDeviceConfigUi: application
Mac Apps Debug deviceStopComm: cisco vpn
Mac Apps Debug deviceStartComm: cisco vpn
Mac Apps Debug elapsed_time: 00:01
Mac Apps Debug last_start: 2018-01-14 17:14:31
Mac Apps Debug percent_cpu: 5.5625
Mac Apps Debug process_id: 5147
Mac Apps Debug command not available
Mac Apps Debug elapsed_secs: 5
Mac Apps Debug elapsed_time: 00:05
Mac Apps Debug percent_mem: 0.2
Mac Apps quitting application "Cisco AnyConnect Secure Mobility Client"
Mac Apps Debug elapsed_secs: 0
Re: Mac Apps plugin
Looks like your application isn't playing nice with System Events, which is why you get a "user cancelled" error. Not much I can do about this beyond suggesting you use the force option.
The force error looks like you just tried it too soon. There is a short delay before the force command will work. I see now how I can improve the plugin and eliminate the delay. But in the meantime if you wait 10sec or so before turning off the device, it should work.
Re: Mac Apps plugin
New version 0.0.6 posted to plugin store (also available via plugin update menu item):
• Fixed bug where force off (kill) command was not available until device had completed a full update cycle.
• Fixed rare (split-second timing) bug when ps data changed just prior to device update method being called.
• Split device types into sub-classes for readability improvement
