If you notice an Indigo related process taking up a lot of CPU resources in the Activity Monitor, then get info on that process and copy/paste the contents of the Open Files and Ports tab. Each Indigo plugin runs in its own process, but by looking at the open file info you can figure out which plugin it is.Asconasny wrote:I will check the activity monitor if I'm nearby the server when/if it happens again.
Another possible culprit would be any AppleScripts you might have Indigo executing. If those are run embedded in the Indigo Server then they can block other requests resulting in the timeous you've seen.
