Basic Installation
jgb
Re: Basic Installation
Post by jgb »
Works perfectly now. Thanks.
blysik
Post by blysik »
I started getting the login error after months of it working fine. I upgraded to most recent version, but I'm still getting this:
MyQ Error                       Error in plugin execution runConcurrentThread:
  File "plugin.py", line 94, in runConcurrentThread
  File "plugin.py", line 335, in getDevices
  File "plugin.py", line 315, in myqLogin
UnboundLocalError: local variable 'err' referenced before assignment
   MyQ Error                       plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Any suggestion?
Turn on debug logging. There should be a couple of log entries just before you get that error.
blysik
Post by blysik »
It's tricky, because it won't let me save the config with debug. However, It will if I stay on that panel:
MyQ Debug                       myqLogin request url = https://myqexternal.myqdevice.com/api/user/validate?username=EMAIL&password=PASS&appId=LONGAPPID
   MyQ Debug                       myqLogin response = <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[5442595389213767696]</body></html>
That's all I can get out of debug.
blysik
Post by blysik »
No crazy characters in email or password. Just letters and numbers.
Did you edit that url line in the log output?
blysik
Post by blysik »
Yes, I should have been clear. I anonymized my email, password, and appid.
The appID is coded into the plugin, depending on the opener brand. it's not user specific.
The following line says that your login is being rejected. Are you sure the login info and brand selected are correct?
blysik
Post by blysik »
100%. I've verified via the myliftmaster.com site. The weird thing to me is that it was working fine forever, and then just today I noticed the error in the logs.
How often are you polling for status?
Hmm. Just checked. Mine is failing as well. I think MyQ broke the reverse engineered API we were using.
Need to do some research.
blysik
Post by blysik »
Ok, good to know it's not just me. :) I was polling every 9 minutes. I'll hold tight while we figure out what happened.
bkmar1192
Post by bkmar1192 »
mine seemed to have stopped working as well.
jgb
Post by jgb »
same issue after working fine for several day with 7.1.5 now this error message about a million times in the last 2 days due to attempt every 10 seconds.
Have disabled and re-enabled and also cannot reconfigure plug-in. Getting the error message in the login fields as before, when attempting to get debugging messages.
MyQ Debug myqLogin request url = https://myqexternal.myqdevice.com/api/u ... HKwTmDzHOu
MyQ Debug myqLogin response = <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[5442595389242462761]</body></html>
It's broken. Just stop using it until I resolve the API issues.
Locked
Return to “MyQ”
