Basic Installation
GBear
Basic Installation
Post by GBear »
Hi - having problem after install of 7.1.3 - this is my first time working with this plugin
I tried to run configure - but it would not accept a save
getting this in log:
File "plugin.py", line 93, in runConcurrentThread
File "plugin.py", line 328, in getDevices
File "plugin.py", line 285, in myqLogin
KeyError: 'key myqLogin not found in dict'
MyQ Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
What am I missing???
Thanks in advance
Re: Basic Installation
You need to put your MyQ login info in the plugin config panel. If it's not accepting the save, then it means there's something wrong with those values.
It's almost certainly a bug that's it's trying to connect to the MyQ servers before that info is validated.
Enabling debug logging might give more info, but the first thing to do is make sure you have the correct MyQ login info and controller brand specified.
GBear
Post by GBear »
Yes, it logs these errors right after enable of the plugin
I entered the correct information (verified login at MyQ site)
After hitting SAVE - it says error validating fields - no red field labels
Is there something else which has to be installed ?
GBear
Post by GBear »
Reverted to 7.0.2
Login appears successful ?
Enabling plugin "MyQ 7.0.2"
Starting plugin "MyQ 7.0.2" (pid 2262)
MyQ Debug logLevel = 10
Started plugin "MyQ 7.0.2"
MyQ Starting MyQ
MyQ Debug updateFrequency = 86400.0
MyQ Debug statusFrequency = 600.0
MyQ Debug Barn Door: Device Version is up to date
MyQ Debug House Door: Device Version is up to date
MyQ Checking for updates...
MyQ Debug Plugin version detected: 7.0.2
MyQ Debug Current version is: 7.0.2
MyQ Debug Getting latest release from FlyingDiver/Indigo-MyQ...
MyQ Debug GET /repos/FlyingDiver/Indigo-MyQ/releases/latest
MyQ Debug HTTP 200 OK
MyQ Debug Latest release is: 7.0.2
MyQ No updates are available
MyQ Debug myqLogin: {"UserId":0,"SecurityToken":"3fd4ec66-4c03-4e24-8f02-08950f803dea","ReturnCode":"0","ErrorMessage":"","BrandId":2,"BrandName":"Chamberlain","RegionId":1}
MyQ Debug myqLogin: Success
MyQ Debug getDevices: 3 Devices
MyQ Debug getDevices: MyQDeviceTypeId = 1, MyQDeviceTypeName = Gateway, DeviceId = 335xxxxx
MyQ Debug "online" = "True"
MyQ Debug "enumeraterequired" = "0"
MyQ Debug "learnmodestate" = "0"
MyQ Debug "addedtime" = "2014-11-28 17:22:56"
MyQ Debug "devices" = "234906855,234906846"
MyQ Debug "numdevices" = "2"
MyQ Debug "desc" = "House"
MyQ Debug "fwver" = "4.2"
MyQ Debug "name" = "............"
MyQ Debug "deviceName" = "............"
MyQ Debug "customerName" = "............"
MyQ Debug "ishomekitcapable" = "False"
MyQ Debug "ishomekitactive" = "False"
MyQ Debug "IsFirmwareCurrent" = "True"
MyQ Debug getDevices: MyQDeviceTypeId = 2, MyQDeviceTypeName = GarageDoorOpener, DeviceId = 234906855
MyQ Debug "gatewayID" = "335xxxxx"
MyQ Debug "desc" = "House Garage Door"
MyQ Debug "doorstate" = "2"
MyQ Debug "addedtime" = "1417217089207"
MyQ Debug "isunattendedopenallowed" = "1"
MyQ Debug "isunattendedcloseallowed" = "1"
MyQ GarageDoorOpener House Garage Door is Closed
MyQ Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 87, in runConcurrentThread
File "plugin.py", line 296, in getDevices
NameError: global name 'myqID' is not defined
Disabling plugin "MyQ 7.0.2"
Stopping plugin "MyQ 7.0.2" (pid 2262)
MyQ Shutting down MyQ
Is the any help ??
GBear
Post by GBear »
Decided to Enter "DeviceId" in Edit Device Settings/MyQ Device Number for both doors
Seems to work now
jgb
Post by jgb »
using most recent version 7.1.4
As another has posted, I get the following error messages right after the plugin has been enabled. Enter login for LiftMaster and verified it was correct by logging onto web site. Cannot save when configuring plugin.
File "plugin.py", line 94, in runConcurrentThread
Exactly which website are you logging into? What's the URL? And what do you have selected for "Brand" in the plugin config dialog?
jgb
Post by jgb »
website: https://www.myliftmaster.com
brand: LiftMaster
The KeyError is a fail in my error checking. I'll fix that eventually. What I don't understand is why it's failing to save the config data if it's the right login information.
But since you can't validate the configuration info, you can't change the debug level to get it to log debug statements. Yikes. I need to rethink that code.
Can you edit the com.flyingdiver.indigoplugin.myq.indiPref file in the Indigo 7/Preferences/Plugins directory? Set logLevel to 10. Then try to configure the plugin again and see if you get the debug statements.
jgb
Post by jgb »
What application should I use to open and edit that file?
TextEdit should be fine. TextWrangler would be better, if you have it.
Also, does your email address or password have any special characters in it? Other than the . and @ in the email, of course. The library I'm using is supposed to URL encode those fields, but I'm wondering if it doesn't do it the way the MyQ website is expecting it.
jgb
Post by jgb »
this is what I see when I open the file with textedit:
<Prefs type="dict">
</Prefs>
So I don't see how to make the edit you ask for; replace the 8 with 10?
My email has an _ in it. The password is only alpha with lowercase and uppercase and numerals, no special characters.
jgb wrote:this is what I see when I open the file with textedit:
<Prefs type="dict">
</Prefs>
OK, so it's never been able to save any preferences, which makes this harder. I have no clue why your login isn't working. I'll try to put together something that might give us a clue.
I think I've figured out what the issue is with new installs. It's going to take a bit of rewriting to fix, but I should have a new version up later today or tomorrow.
7.1.5 released with fix for this issue.
Locked
Return to “MyQ”
