Sure. Trigger is Roomba Device, NotReady state change (becomes not equal to "0"), then the action is to send the message getting the text from the Roomba Devices's NotReady or ErrorText states.Bollar wrote: Maybe I'm misunderstanding you, or we're misunderstanding each other. What I want is to be able to send the specific error or not ready message to Pushover without having to create a trigger for each type of event that the plugin can report. That's what I currently do with my script.
Roomba Plugin - Discontinued
- FlyingDiver
Re: Roomba Plugin - beta tests
I like it! Its great. Thanks for building this plugin. With the homebridge connection, I can now ask Siri to start my Roomba.
Ditto, testing here - all going well
Thanks a lot
Glenn
Thanks a lot
Glenn
Sure, I'd like that - especially if I can get that into Pushover. BTW, I came across another not ready state: 15: Low Battery (probably)FlyingDiver wrote:Sure. Trigger is Roomba Device, NotReady state change (becomes not equal to "0"), then the action is to send the message getting the text from the Roomba Devices's NotReady or ErrorText states.Bollar wrote: Maybe I'm misunderstanding you, or we're misunderstanding each other. What I want is to be able to send the specific error or not ready message to Pushover without having to create a trigger for each type of event that the plugin can report. That's what I currently do with my script.
- FlyingDiver
You should be able to do all that now.Bollar wrote:Sure, I'd like that - especially if I can get that into Pushover. BTW, I came across another not ready state: 15: Low Battery (probably)FlyingDiver wrote:Sure. Trigger is Roomba Device, NotReady state change (becomes not equal to "0"), then the action is to send the message getting the text from the Roomba Devices's NotReady or ErrorText states.Bollar wrote: Maybe I'm misunderstanding you, or we're misunderstanding each other. What I want is to be able to send the specific error or not ready message to Pushover without having to create a trigger for each type of event that the plugin can report. That's what I currently do with my script.
I'll add that new value to the plugin in the next release.
- FlyingDiver
v0.0.3 is now available
Removed state specific trigger events
added generic NotReady and HasError triggers
added NotReadyText device state
added device Info polling and menu action
You'll need to edit your Roomba devices to pick up the state changes. If you used the specific notReady event triggers, you'll need to edit those as well.
Nice, and thanks for the help on Pushover. Aside from a daily firmware check, I've moved my triggers to your plugin. You have Get System & Get Date/Time available as an action, but I can't figure out how to access the results.
And the SQLLogger Error still exists.
- FlyingDiver
The error should fix itself if you edit the device and save it. If not, you might have to delete it and recreate it. Beta code, you know.Bollar wrote:Nice, and thanks for the help on Pushover. Aside from a daily firmware check, I've moved my triggers to your plugin. You have Get System & Get Date/Time available as an action, but I can't figure out how to access the results.
The results of both of those actions are updated state variables. So if you run the action, you can then access the updated variables. That's about all you can do when using standard Indigo constructs. If you wanted to call the actions from a Python script, then I might be able to do something different.
Got it. I don't think the results of sys info are making it into the device state, though.FlyingDiver wrote:The error should fix itself if you edit the device and save it. If not, you might have to delete it and recreate it. Beta code, you know.Bollar wrote:Nice, and thanks for the help on Pushover. Aside from a daily firmware check, I've moved my triggers to your plugin. You have Get System & Get Date/Time available as an action, but I can't figure out how to access the results.
{"ok":{"umi":4,"pid":2,"blid":[xx],"sw":"v1.6.6","cfg":0,"boot":3580,"main":5008,"wifi":10724,"nav":"01.09.08","ui":4582,"audio":31,"bat":"lith","hw":0},"id":1}Insteon / Z-Wave / Bryant Evolution Connex /Tesla / Roomba / Elk M1 / SiteSage / Enphase Enlighten / NOAA Alerts
- FlyingDiver
What call generated those results? I must have missed one from your scripts. Or is that all from the credentials call, and I'm only getting the blid? Is that all static for the machine or does it change over time?Bollar wrote: Got it. I don't think the results of sys info are making it into the device state, though.I don't know that I need any of the other info, but I am curious to known when sw (and maybe nav) are updated.Code: Select all
I don't timestamp the last getInfo or GetTime call. Are you looking for a timestamp when they were last updated?
It is the same call as to get blid in credentials ("sys") - I call it once a day. The numbers don't appear to be static - I have assumed they are system diagnostic codes. the only one I track now is "sw" and if the variable I save it to changes,, I send a notification.FlyingDiver wrote:What call generated those results? I must have missed one from your scripts. Or is that all from the credentials call, and I'm only getting the blid? Is that all static for the machine or does it change over time?Bollar wrote: Got it. I don't think the results of sys info are making it into the device state, though.I don't know that I need any of the other info, but I am curious to known when sw (and maybe nav) are updated.Code: Select all
- FlyingDiver
Got it. I should have that change by tomorrow at the latest. Got a MyQ plugin issue to look at first, and I think I'm going to be setting up a Christmas tree this afternoon.Bollar wrote: It is the same call as to get blid in credentials ("sys") - I call it once a day. The numbers don't appear to be static - I have assumed they are system diagnostic codes. the only one I track now is 'sw" and if the variable I save it to changes,, I send a notification.
- FlyingDiver
The MyQ issue is more complicated to solve and will take a while. And the tree isn't here yet, so I had some time.
v0.0.4 available now.
Added more states
moved blid from device parameter to state
renamed and added some actions
Specifically, what was "Get Credentials" is now "Get Password". I thought the "blid" was part of the authentication credentials, but it's not. Only the password needs to be retained. So blid is now just another state variable.
Also, what was "Get Info" is now "Get Status", and is the immediate status of the roomba. "Get Info" has been added to retrieve the more static information which was missing (other than blid).
You need to edit and save the device to get the new states added.
I have no idea what most of those states actually represent. Bollar is the expert on those.
Added more states
Here's what I know about the Time and Mission states:
There are other codes that are missing from the Mission states currently being returned in the plugin:
From the sys command, the only ones I know about are sw and nav.
Day: Day of week, sun-sat
Time: Time of day
Flags: A decimal representation of binary preference settings. I haven't tried to decode yet - it usually is 3,4 or 5 when running for me.
Cycle: What the robot is currently doing. I have found it returns 'none' or 'clean'
Phase: What part of the Mission the robot is completing. Returns 'charge', 'stuck' or 'run'. If stuck, there will be an error code.
Theta: The direction the robot is pointing.
X: Robot's polar coordinate
Y: Robot's polar coordinate
DBatPctate: (Don't know - typo?)
MssnM: Elapsed Mission duration in minutes.
SqFt: SqFt cleaned.
ErrorCode: Error number from 1 to 18
ErrorText: Error text as documented by iRobot
NotReady: Codes are not documented anywhere - I have discovered 7: Bin Missing, 15: Low Battery, 16: Bin Full
NotReadyText: Text representation of those codes
ID: Always returns 1 for me.Code: Select all
batPct: Battery % remaining.
expireM: Minutes remaining to clear a stuck, pause, not ready, or error event before Mission is cancelled.
rechrgM: Minutes to complete recharging the batteryInsteon / Z-Wave / Bryant Evolution Connex /Tesla / Roomba / Elk M1 / SiteSage / Enphase Enlighten / NOAA Alerts
- FlyingDiver
I get mostly the same, except mine is currently showing Cycle=quick. Mine is set for single pass. Is yours single or double?
The version I'm running (0.0.4) is showing batPct, ExpireM, and RechrgM. Do you need to stretch the window?
- Screen Shot 2016-12-02 at 5.05.59 PM 12-2.png (95.52 KiB) Viewed 4479 times
