MyQ and door sensors?
- FlyingDiver
How many MyQ users also have sensors on their garage doors? I installed a couple of these last week: http://www.monoprice.com/Product?p_id=11987
Now I'm working on a version of the plugin that uses the sensors to set the door state to eliminate polling (or reduce the frequency, anyway). That part is working fine. Now I need to figure out how to cross-check the sensors against the MyQ reported status after any commanded or detected change. And then I'll need to add some Events to report a mismatch.
If you're interested in testing, let me know.
Re: MyQ and door sensors?
I still have IO Lincs with sensors installed on my doors and can test for you - I was planning to remove them, but can hold off for the cause.
- FlyingDiver
I'm getting this error continuously repeating:
MyQ Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 237, in deviceUpdated
KeyError: key sensor not found in dict
- FlyingDiver
Darn. I thought I fixed that. Do you have sensors linked to the doors? You edit the device to assign them.
I gave that a shot - the IOLincs I used to monitor the door status aren't in the device list. Basically they're a binary input that's open/closed.FlyingDiver wrote:Darn. I thought I fixed that. Do you have sensors linked to the doors? You edit the device to assign them.
- FlyingDiver
So how do they show up in Indigo? Not as sensor devices? I grab all indigo.sensor devices for the list.Bollar wrote:I gave that a shot - the IOLincs I used to monitor the door status aren't in the device list. Basically they're a binary input that's open/closed.
I don't know for sure - I think of them more as relays, since they also have an output.
- Indigo IOLinc.jpeg (141.27 KiB) Viewed 7250 times
- FlyingDiver
OK, that's an iodevice, and adding that would also require that I implement a way to identify the state to monitor. Doable, but not quickly.
Are there any custom states for that device not shown in the standard UI?
I still need to fix the issues when there's no sensor linked.
joe
joe
No, what you see is what you get.FlyingDiver wrote:OK, that's an iodevice, and adding that would also require that I implement a way to identify the state to monitor. Doable, but not quickly.
I'm using the https://www.amazon.com/Ecolink-Intellig ... zwave+tilt and it seems to be working fine. I had a little bit of trouble with errors spawning after I ran the upgrade but figured out it was because I did not have the associated Tilt sensor setup for each of the garage door openers. Once I had those associations made in the plugin it has been running error free.
Jeff
Jeff
- FlyingDiver
Good to hear. I need to roll the changes in 7.0.2 into the sensor version (7.1.x) and fix the errors from no linked sensor. Then I'll put out another test release.polycron wrote:I'm using the https://www.amazon.com/Ecolink-Intellig ... zwave+tilt and it seems to be working fine. I had a little bit of trouble with errors spawning after I ran the upgrade but figured out it was because I did not have the associated Tilt sensor setup for each of the garage door openers. Once I had those associations made in the plugin it has been running error free.
Jeff
I just generated an error when I attempt to configure the plugin:
Jeff
Error (client) runConfigDialog() caught exception: PAXDialogControllerError -- Field ID statusNote was already used. Every <Field> element must have a unique field ID.
- FlyingDiver
Woops. Editing error. I'll fix that in the next test release.polycron wrote:I just generated an error when I attempt to configure the plugin:
JeffCode: Select all
- FlyingDiver
v7.1.2 is available now. This is a pre-release, so the built in updater won't pick it up.
https://github.com/FlyingDiver/Indigo-M ... tag/v7.1.2
This version should handle doors without sensors properly. All other recent bug fixes have also been included.
Still on the to-do list is handling IO devices as sensors.
