Extension: URL Toggle Device
Colorado4Wheeler
Re: New Extension: URL Toggle Device
Post by Colorado4Wheeler »
I had considered adding some authentication methods in but was trying to keep it a really small addition to the plugin and figured most folks could use the http://name:password@ method on their URL but I'll see about adding this method in as well.
Colorado4Wheeler
PeteVis wrote:This would be a super useful plugin if you could make it a little more flexible...
I've put up a pre-release of 1.6 if you want to download it and try out the new functionality added to the URL toggle. The username and password are obvious, but the URL may be confusing. In the three URL fields you will put in the command itself, i.e., "irMode=3", and in the command URL you put the query URL of "http://10.0.1.50/eng/admin/adv_audiovideo.cgi".
Please let me know how it goes, I'm working on a few other things in that plugin as well so once I'm sure your tests work fine I can publish the update.
PeteVis
Post by PeteVis »
It works very nicely :D
The camera has actually both an on and off command : irMode=2 == off and irMode=3 ==on, so putting those in the respective on and off fields makes it act as an actual IR switch for this camera.
I'm very happy with this, now I can remove my actions and variables, this is so much more elegant.
Thanks !
Colorado4Wheeler
Fantastic! Thanks for letting me know :).
