MyQ Plugin - BETA
MyQ Plugin - BETA
First beta test release is available now at https://github.com/FlyingDiver/Indigo-MyQ/releases
It does pretty much what you would expect it to do. Reports status of the doors, and allows you to open or close them.
One unusual aspect of this plugin - it auto-creates the Indigo devices after entering your MyQ login information. It was either do that, or cache the device information so users can pick specific openers to create devices for. Right now, it will always create devices for all openers that MyQ knows about.
If people really don't like the way it works now, I'll change it.
I don't have any MyQ enabled devices other than openers. If you have other devices you would like access to, let me know what they are and what you want to do to them. I'll add the additional device types.
Requires the requests module:
 sudo pip2.6 install requests
gregjsmith
Re: MyQ Plugin - BETA
Post by gregjsmith »
No matter what I put in this field it turns red.
Screen SharingScreenSnapz002.jpg (368.23 KiB) Viewed 7146 times
Oops. I'm highlighting the wrong field. It's actually complaining about the field above that, the minimum is 5 minutes for status updates. This is on the recommendation of the developer of the original code, as we're using an unofficial API and very frequent updates might cause the API to get restricted.
I'll fix the highlighting in the next release.
gregjsmith
Even if I leave frequency to the default 10 it complains and won't let me save.
I've gotta figure out a more bullet proof way to do initial startup before the config window is completed.
Grab v.0.03.
roquej
Post by roquej »
Getting when doing "Update Door Status"
MyQ Error Error in plugin execution MenuAction:
File "plugin.py", line 266, in getDoors
File "plugin.py", line 246, in myqLogin
The login is correct, as I have it working with the scripts.
Any suggestions?
JP
roquej wrote:Getting when doing "Update Door Status"
Any suggestions?
JP
Turn on debugging and do it again. Post log segment.
Does it show the correct status on startup? And after a timed update? Is this just an error when doing the update via the menu?
gregjsmith
After installing .3 indigo thinks it's .2. Anyway there seems to be no change, I can't change anything in the dialog.
gregjsmith wrote:After installing .3 indigo thinks it's .2. Anyway there seems to be no change, I can't change anything in the dialog.
Disable the plugin you have, delete the preference file for the plugin, get the new one from the link above (I fixed the version number), then reinstall.
gregjsmith
When creating a new device, it asks for a MyQ device number. What is this and where do I find this info?
Also the MyQ device allows the control of lights. My be another device type to add.
gregjsmith wrote:When creating a new device, it asks for a MyQ device number. What is this and where do I find this info?
You should not need to create any devices, the plugin creates them for you. See the first post in the thread. The device numbers are written to the log if you have debug enabled.
Please enable debug and restart the plugin. Post the section of the log that looks like:
  MyQ Debug                       myqLogin: Success, Brand = Liftmaster, SecurityToken = 65c16e0a-09ed-48ba-8bdf-25619b87975f
  MyQ Debug                       getDoors: 3 Devices
  MyQ Debug                       getDoors: MyQDeviceTypeId = 1, DeviceId = 1700492096
  MyQ Debug                       getDoors: MyQDeviceTypeId = 2, DeviceId = 1700492105
  MyQ Debug                       getDoors: Large Garage Door (1700492105), state = 1
  MyQ Debug                       getDoors: MyQDeviceTypeId = 2, DeviceId = 1700492104
  MyQ Debug                       getDoors: Small Garage Door (1700492104), state = 1
FYI All -
The current version has a race condition on initial configuration. After you close the plugin config dialog, just restart the plugin. The error will be fixed in the next release.
gskarp
Post by gskarp »
It doesn't load for me. I keep getting the following log message as an infinite loop:
MyQ Error
Error in plugin execution InitializeMain:
  File "plugin.py", line 33, in <module>
<type 'exceptions.ImportError'>: No module named requests
Error                           plugin "MyQ 0.0.3" (pid 59685) failed to start -- restarting in 5 seconds
Is there a module I need to install?
Oh, yeah. The requests module.
gskarp
Post by gskarp »
I have Python 2.7.2 running. Do I need to install 2.6.2 to have this worK or is this an addon?
Locked
Return to “MyQ”
