Using all the time.
Much appreciated
Mike
No problem at all - thanks for posting... glad to hear there are some happy users out there!Just wanted to say a big thank you.
Hey Rob... Those are all exposed as Device States - so you need only set the control page element as:One question though. It's not clear to me how I can pull back the following variables so that I can keep my control pages updated:
Current Input (Main)
Current Input (Zone 2)
Mute Status (Main)
Mute Status (Zone 2)
Listening Mode
NetworkPlay Album
NetworkPlay Artist
NetworkPlay Title
Tuner Frequency
Enabling plugin "Onkyo Network Remote Plugin 2.0.0"
Starting plugin "Onkyo Network Remote Plugin 2.0.0" (pid 34157)
Started plugin "Onkyo Network Remote Plugin 2.0.0"
Aug 1, 2016 9:15:55 AM
Onkyo Network Remote Plugin Error Connection failed for device 300788196: [Errno 60] Operation timed out
Onkyo Network Remote Plugin Error Connection failed for device 367370760: [Errno 60] Operation timed out
Onkyo Network Remote Plugin Debug Plugin preferences updated
Onkyo Network Remote Plugin Debug Establishing connection to XXX.XX.XX.XX
Onkyo Network Remote Plugin Debug Connection established
Onkyo Network Remote Plugin Debug Received direct tune action to 092.30
Onkyo Network Remote Plugin Debug Sending tune command for 09230
Aug 1, 2016 9:16:27 AM
Onkyo Network Remote Plugin Debug Received direct tune action to 094.90
Onkyo Network Remote Plugin Debug Sending tune command for 09490
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZ2B
Onkyo Network Remote Plugin Debug Attempting reconnection to device 300788196
Onkyo Network Remote Plugin Debug Establishing connection to 10.0.1.63
Onkyo Network Remote Plugin Debug Attempting reconnection to device 367370760
Onkyo Network Remote Plugin Debug Create connection command de-queued
Onkyo Network Remote Plugin Debug Executing full status update request...
Onkyo Network Remote Plugin Debug Sending eISCP Command: PWRQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: MVLQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: AMTQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: HAOQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLIQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SPAQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SPBQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLPQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: HDOQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: RESQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: VWMQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: VPMQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: LMDQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLAQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: TUNQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NATQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NALQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NTIQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NSTQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: ZPWQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: ZVLQSTN
Aug 1, 2016 9:17:08 AM
Onkyo Network Remote Plugin Debug Scheduling reconnection attempt...
Onkyo Network Remote Plugin Debug Reconnection attempt scheduled for 30 seconds
Onkyo Network Remote Plugin Debug Closing connection to device
Aug 1, 2016 9:17:36 AM
You have one setup as a Receiver device and one as a Virtual Volume Controller or both setup as full Receiver devices? I have mine setup as a virtual volume device and as far as I can tell works just fine... not sure that two simultaneous connections are supported if you have two full receiver devices. But I guess if it has been working, so be it!In any case the plugin seems to be working fine now. I set it up with two devices, one for Main and the other for Zone 2. Maybe I didn't dig hard enough, but it seemed like the functionality was better with two devices. So far, with the exception of this one hiccough, it has worked well. Will report back as needed.
No problem at all... let me know if your issues return and we need to look into it further!Thanks again for a GREAT plugin!
Honestly, I have no idea whatsoever... however, I just looked at the command dump and there is an "Internet Radio Preset Command" that accepts a number which is presumably the preset. If you have a preset defined, try entering these into the "Send Arbitrary Command" option (from the Plugins menu) and see if it changes to the preset (not 100% sure the format, if one works, no need to send another):One thing I can't figure out is how to set up and select a pandora station via the plugin. Is that possible? Does it use the web interface list? If not, is it possible to set up the actual Onkyo app so that it can open from a URL call in Indigo, like the apple remote app can?
Onkyo Network Remote Plugin Debug Command queue has 1 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: NPR01
Onkyo Network Remote Plugin Debug Send command completed.
Onkyo Network Remote Plugin Debug Failed to parse eISCP message, message ignored: !1NLT0122000000000001000100
Onkyo Network Remote Plugin Debug Received w/o Command: !1NLT0122000000000001000100
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-list-info', 'C-P')
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-jacket-art', 'n-')
Onkyo Network Remote Plugin Debug Failed to parse eISCP message, message ignored: !1NLTF33200000001000000FF00Playback error
Onkyo Network Remote Plugin Debug Received w/o Command: !1NLTF33200000001000000FF00Playback error
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-list-info', 'C0P')
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-list-info', 'U0-Popup cannot be supported')
Onkyo Network Remote Plugin Debug Failed to parse eISCP message, message ignored: !1NCPX<?xml version="1.0" encoding="utf-8"?><popup title="Playback error" align="center" type="custom" time="0" uri="resource:///popup" ><label title="" align="center" total="1" uri="resource:///popup/label:0" ><line text="Connection Error. · The server connection could not be established or was terminated early. Please try again later." align="left" uri="resource:///popup/label:0/line:0" order="0" /></label><buttongroup title="" align="center" total="1" uri="resource:///popup/buttongroup:0" ><button text="Back" align="center" uri="resource:///popup/buttongroup:0/button:0" selected="false" index="0" order="1" /></buttongroup></popup>
Onkyo Network Remote Plugin Debug Received w/o Command: !1NCPX<?xml version="1.0" encoding="utf-8"?><popup title="Playback error" align="center" type="custom" time="0" uri="resource:///popup" ><label title="" align="center" total="1" uri="resource:///popup/label:0" ><line text="Connection Error. · The server connection could not be established or was terminated early. Please try again later." align="left" uri="resource:///popup/label:0/line:0" order="0" /></label><buttongroup title="" align="center" total="1" uri="resource:///popup/buttongroup:0" ><button text="Back" align="center" uri="resource:///popup/buttongroup:0/button:0" selected="false" index="0" order="1" /></buttongroup></popup>
Onkyo Network Remote Plugin Debug Sending eISCP Command: NPR02
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-artist-name-info', '---')
Onkyo Network Remote Plugin Debug Found response match: streamingArtistQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayArtist" to "---"
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-album-name-info', '---')
Onkyo Network Remote Plugin Debug Found response match: streamingAlbumQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayAlbum" to "---"
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-title-name', '1898301078810978435')
Onkyo Network Remote Plugin Debug Found response match: streamingTitleQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayTitle" to "1898301078810978435"
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-track-info', '----/----')
