I can access that AndroidHelper status page both locally and then remotely using my reflector.
Here are my server settings:
Domotics Pad Mobile Client Your plugin version, v1.1.19, is current.
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
WebServer loaded plugin "Android Client Helper Plugin"
I removed the plugin and tried to reinstall it. Entered my username & pwd during the install, immediately see this in the logs:
Installing and enabling plugin "Domotics Pad Mobile Client" v1.1.19
Loading plugin "Domotics Pad Mobile Client 1.1.19"
Starting plugin "Domotics Pad Mobile Client 1.1.19" (pid 32918)
Started plugin "Domotics Pad Mobile Client 1.1.19"
Domotics Pad Mobile Client Performing update of DomoPads IWS plugin...
Domotics Pad Mobile Client Source IWS directory: /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DomoPad Mobile Client.indigoPlugin/Contents/Server Plugin/AndroidClientHelper
Domotics Pad Mobile Client Target IWS directory: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/plugins/AndroidClientHelper
Domotics Pad Mobile Client AndroidClientHelper successfully installed/updated. Restarting Indigo IWS server to complete install.
Mar 31, 2016, 6:51:59 AM
Domotics Pad Mobile Client DebugPlugin preferences updated
Domotics Pad Mobile Client DebugFailed to retrieve current IWS plugin version:
Domotics Pad Mobile Client ErrorError in plugin execution:
File "plugin.py", line 255, in getIWSPluginVersion
responseToQuery = opener.open(u'http://localhost:' + self.pluginPrefs.get(u'indigoPort') + u'/AndroidClientHelper/getVersionInfo')
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 391, in open
response = self._open(req, data)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 409, in _open
'_open', req)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 369, in _call_chain
result = func(*args)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 1181, in http_open
return self.do_open(httplib.HTTPConnection, req)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 1156, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 61] Connection refused>
Domotics Pad Mobile Client DebugCurrent IWS Plugin: v0.0
Domotics Pad Mobile Client DebugIncluded IWS Plugin: v1.2
When back into config and then took my username/pwd out an releoaded...same error
Mar 31, 2016, 6:55:14 AM
Reloading plugin "Domotics Pad Mobile Client 1.1.19"
Stopping plugin "Domotics Pad Mobile Client 1.1.19" (pid 32918)
Stopped plugin "Domotics Pad Mobile Client 1.1.19"
Starting plugin "Domotics Pad Mobile Client 1.1.19" (pid 32923)
Domotics Pad Mobile Client Initializing RPFrameworkPlugin
Domotics Pad Mobile Client Beginning processing of RPFrameworkConfig.xml file
Domotics Pad Mobile Client Found plugin param: indigoPort
Domotics Pad Mobile Client Found plugin setting: remoteCommandPort=9176
Domotics Pad Mobile Client Found plugin setting: pluginCommandQueueIdleSleep=3
Domotics Pad Mobile Client Found device mapping; id: domoPadAndroidClient to class: DomoPadAndroidClient
Domotics Pad Mobile Client Found device mapping; id: domoPadVideoFeed to class: VideoCameraFeed
Domotics Pad Mobile Client Created device parameter for managed device "domoPadVideoFeed": videoFeedUrl
Domotics Pad Mobile Client Found managed action: sendPushNotification
Domotics Pad Mobile Client Processing 2 params for action
Domotics Pad Mobile Client Created parameter for managed action "sendPushNotification": message
Domotics Pad Mobile Client Created parameter for managed action "sendPushNotification": importanceLevel
Domotics Pad Mobile Client Successfully completed processing of RPFrameworkConfig.xml file
Domotics Pad Mobile Client Customizing MenuItems.xml
Domotics Pad Mobile Client Returning default GUIConfigValue for plugin:showUPnPDebug
Domotics Pad Mobile Client DebugReturning default GUIConfigValue for plugin:databaseConnectionEnabled
Domotics Pad Mobile Client DebugDatabase access enabled:
Domotics Pad Mobile Client DebugDatabase access has been disabled, skipping connection
'_open', req)
raise URLError(err)
Domotics Pad Mobile Client DebugStarting up connection listener
Domotics Pad Mobile Client DebugVersion check initiated
Domotics Pad Mobile Client DebugVersion File Url:http://www.duncanware.com/Downloads/IndigoHomeAutomation/Plugins/DomoPadMobileClient/DomoPadMobileClientVersionInfo.html
