Can this plugin work with another RGBW device
I have a couple of the ZIPATO RGBW bulbs installed.
Could this plugin work with this devices also?
Håvard
Re: Can this plugin work with another RGBW device
It depends on how indigo supports them. The plugin manages up to 4 channels for rgbw or three for rgbw. Depending on how indigo managers those channels it could work. Do you change zwave parameters to control each channel? If so it could be modified to get its source and send output to a different place easily enough. I'd be happy to try but I couldn't testhaavarda wrote:Hi,
Mike
I change the color by typically using an action group --> Z-wave actions --> set RGB levels. There is also a std slider to control the level.
Håvard
Ok I see - I didn't know about thathaavarda wrote:I change the color by typically using an action group --> Z-wave actions --> set RGB levels. There is also a std slider to control the level.
If so - I'd need to understand the properties of the device - but I can write a small piece of code to let us know that...
Let me look at using a plugin to manage the action dialog
Mike
Also what is the range of the RGBW parameters? 0-100 or 0-255 or something else?haavarda wrote:I change the color by typically using an action group --> Z-wave actions --> set RGB levels. There is also a std slider to control the level.
Regards
Mike
Hi Mike.
The range is 0-100.
If you see the screenshots you can see how device UI appears. The two different sliders is a bit confusing as it seams as if the first controling the rgb and the second is controlling the withe led.
Thanks for looking at this
The range is 0-100.
- Skjermbilde 2015-10-13 kl. 20.39.24.png (31.01 KiB) Viewed 6278 times
- Skjermbilde 2015-10-13 kl. 20.39.13.png (31.06 KiB) Viewed 6278 times
- Skjermbilde 2015-10-13 kl. 20.38.49.png (59.62 KiB) Viewed 6278 times
Håvard
HI all
I've updated the plugin to allow for the use of single device LEDs like the Ziparo and AeoTech devices. When you install the plugin and create a new device you have the option to select a Fibaro type device type or not. If you select Fibaro you'll have access to multiple devices that support the Fibaro like dimmer. If this box is unchecked you can define a Single device type like the Zipato or Aeotech.
I don't actually have any of these devices to test against so I'd be grateful if someone else can install the plugin and test it and then let me know the issues/results.
Ta
Mike
Ta
Mike
Excellent Mike!
I tried it with teamviewer on my phone just to try it before I get home, and I think this really has potential. I did run in to an error when configuring the device and was not able to click "Save". It says "Error validating fields. Hover over the red filed labels above to see the error reason".
But I dont see any red fields... That is about the fault finding I can do with team viewer and an iPhone..
But I can look more in to it later today. Just let me know what you need.
The Zipato bulb is a bit strange when it comes to operating it. But we can look at that when the device is up and running.
Thanks for your effort Mike
Håvard
This is the error I am getting when trying to save a new device:
19. okt. 2015, 18.17.57
Fibaro Light Manager Colour of LED RGBW CONTROLL HALL is now Yellow green
Fibaro Light Manager Error Error in plugin execution UiValidate:
File "plugin.py", line 484, in validateDeviceConfigUi
File "plugin.py", line 121, in changeDeviceColours
<class 'Boost.Python.ArgumentError'>: Python argument types in
PluginInfo.executeAction(PluginInfo, str)
did not match C++ signature:
executeAction(CPlugin {lvalue}, CCString actionTypeId, unsigned long deviceId=0, boost::python::api::object props=None, bool waitUntilDone=True)
Håvard
haavarda wrote:This is the error I am getting when trying to save a new device:
19. okt. 2015, 18.17.57 Fibaro Light Manager Colour of LED RGBW CONTROLL HALL is now Yellow green Fibaro Light Manager Error Error in plugin execution UiValidate: Traceback (most recent call last): File "plugin.py", line 484, in validateDeviceConfigUi File "plugin.py", line 121, in changeDeviceColours <class 'Boost.Python.ArgumentError'>: Python argument types in PluginInfo.executeAction(PluginInfo, str) did not match C++ signature: executeAction(CPlugin {lvalue}, CCString actionTypeId, unsigned long deviceId=0, boost::python::api::object props=None, bool waitUntilDone=True)
Thanks...
I found a way to test so I've updated the plugin this afternoon. I think I've got it now so you should see an improved system in about 30 mins (18:00 UK time)
Let me know how that one goes... it works for me anyway
Regards
Mike
Hi Mike.
I have been able to play a bit with this, and I think this is going to be perfect. It just needs some tweaking because the Zipato bulb is a bit strange...
With my Zipato bulb I dont see what the Master intensity is doing? What is this actually controlling?
Since the bulb is showing as 2 different switches my experience is that I have to turn off the second of them to be able to see the rgb color. If not it seams like the white light is to dominant or disables posibility to set rgb. Could there be an option to turn off bulb2 before setting rgb levels?
There is a possibility to adjust color temperature with parameter 1 on this device, and somehow this adjustment is just shown when using the second of the multilevel switches.
As you can see this is not easy to understand, at least I am struggling to see any logic in it. But thank you for implementing this bulb in your plugin. I think this can make it a lot easier to use.
Håvard
haavarda wrote:Hi Mike.
Havard
I can't actually test the device in real life so I'm guessing most of the time. The Master Intensity is used by some devices as an overall control for brightness across all channels. I suspect it has absolutely no effect on the Ziparto operation so can be safely ignored. I might need to write a 'driver' specific for the Ziparto device let's see. In the meantime just ignore it.
Now onto the two devices. I understood from your screen shots that this was the case.
So it looks as if there are two devices operating here - let's call them White and RGB.
Knowing Matt & Jays approach they have two different device numbers but the same address - is that right? The White Device will have one code and the RGB Device will have another. The logic would work like this I think:
White Light
if I want to show a white light I don't use the second device I use the White Device therefore the RGB Device should be switched off, White Device should be switched on, User should be able to set a colour temperature (do you know the parameter name/number?)
RGB Light
If I want to use RGB functionality the White device must be off therefore the White Device should be turned off, The RGB levels set on the second device, The RGB Device switched on.
Off
To ensure that light is fully off there are two devices White and RGB that need to be switched off
I appreciate that's a lot of words for a simple premise but I need to understand the mechanism so I can code it.
So can you let me know:
- Are there two separate devices?
Are the addresses the same?
Are the device codes different?
What is the model description for the devices (so I can search for bulbs in the devices list for the dropdowns)?
What is the parameter that needs to be set on the White device and what is the possible range?
What is the name of the parameter (or parameter number)?
Regards
Mike
Hi Mike.
I am just happy that you are looking at this
Hope this answers your questions...
Yes. It is displayed as a Device group in Indigo. One master and one slave. If I edit the master I can adjust parameter 1 (Color temp). The slave only shows information. Address, name and manufacturer. The Master controls the dimming of the RGB (0-100) and the slave controls the dimming of the white (0-100).Are there two separate devices?
Yes. So in my case they both have adress 72Are the addresses the same?
Not sure what you codes are, but if you are thinking of device ID this is different for the two devices.Are the device codes different?
Multilevel Switch - RGBW LED BulbWhat is the model description for the devices (so I can search for bulbs in the devices list for the dropdowns)?
Parameter 1, ragne 1-100What is the parameter that needs to be set on the White device and what is the possible range?
Color temperatureWhat is the name of the parameter (or parameter number)?
Håvard
Perfect answers - yes I can make that device work with the pluginhaavarda wrote:Hi Mike.
Mike
Just one more thing. I need to know how Matt & Jay have configured each device so I need to have the properties.haavarda wrote:Hi Mike.
It's easy enough.
1. Write down the ID code for each device
2. Create an Action and select Server Actions, Execute Script
It should look like this:
Enter some code in the embedded python box...
import indigo
dev1 = indigo.devices[ID of the Master Device] # Master
dev2 = indigo.devices[ID of the Slave Device] # Slave
indigo.server.log(str(dev1))
indigo.server.log(str(dev2))3. Click on Run
4. Look at the log and you'll have a dump of all the configuration information that Matt & Jay have created for your device.
Mine looks like this:
Now I'd like you to cut and paste all of the information in the log and send it to me
If you find that there is too much information (because there is a lot of it) i suggest that you run the code twice once for each device.
i.e.
import indigo
dev1 = indigo.devices[407727969] # Master
import indigo
dev2 = indigo.devices[407727969] # Master
indigo.server.log(str(dev2))Once I've got that information it's a fairly simple exercise to create a new device type for your Ziparto Bulbs... Then I might buy some
I'll need you to test it when you have the chance but I don't think it'll take too long.
Mike
