self.browserOpen?
Forum rules
bschollnick2
self.browserOpen?
Post by bschollnick2 »
Matt and Jay,
I'm not sure that this is an Indigo 6 issue or not?
I am attempting to use self.browserOpen, and Indigo is not reporting any errors, but safari never launches?
Here's the code...
plugin_name = "test_v2.indigoPlugin"
plugin_manual = "Plugin Manual for Indigo.pdf"
def menu_manual ( self ):
indigo.server.log ("Opening manual")
manual_locale = r"/library/Application Support/Perceptive Automation/Indigo %s/plugins/%s/Contents/Manuals/%s" % (int(indigo.server.version[0]), plugin_name, plugin_manual)
self.browserOpen( manual_locale )
return
Any idea why this would be behaving like this?
- Ben
for v5 - http://bit.ly/T6WBKu
matt (support)
Re: self.browserOpen?
Post by matt (support) »
Try this:
		manual_locale = r"file:///library/Application Support/...
Note 3 slashes after "file:".
bschollnick2
matt (support) wrote:Try this:
Doh! Obvious in hindsight.
But I am a little bit more concerned that there wasn't any feedback regarding this from Indigo?
Any chance of some useful feedback, for example, URL not found?
- Ben
matt (support)
We'll look into it.
bschollnick2
Except the same result is occurring.
I have added the file:/// prefix, and absolutely nothing is happening. Safari isn't opening, and there's no log feedback. (I even tried file:// instead)
Current version of the function
manual_locale = r"file:///Library/Application Support/Perceptive Automation/Indigo 6/Plugins/iAutomate_RFID v2.indigoPlugin/Contents/Manuals/RFID and Plugin Manual for Indigo.pdf"
return
Do we know of any plugins that are using browserOpen? A quick scan, doesn't show any in the standard plugins.
But, browserOpen does work, if I use a http:// reference, everything works fine. For example:
self.browserOpen( "http://www.google.com" )
Any other suggestions?
- Ben
matt (support)
Make sure the path you are passing in is correct. I just tried:
indigo.activePlugin.browserOpen("file:///Users/mattb/Desktop/something.pdf")
And it did open the PDF file that was on my desktop. Note, however, that it opened it in Preview. That API is telling the OS to open the URL using the best application for the URL type, so in this case it opened in Preview and not Safari (which means the API name isn't quite accurate...).
bschollnick2
matt (support) wrote:Make sure the path you are passing in is correct. I just tried:
Well, I worked around this by doing a subprocess to open. But the PDF isn't opening if I use browserOpen. So I don't know if it's a permissions issue (e.g. being in the library folder, etc). Or a filename issue, but using subprocess is working fine.
- Benjamin
Locked
Return to “Extending Indigo with Plugins and Python”
