PLugin SDK
Forum rules
jd10884
PLugin SDK
Post by jd10884 »
Good day,
I'm starting to look at attempting my first plugin, the Indigo Plugin SDK for Indigo 6, that is available for downloading, will work for Indigo 5? If not where an older version can be downloaded for Indigo 5?
Thanks in advance
Jeff
jay (support)
Re: PLugin SDK
Post by jay (support) »
The current SDK contains Indigo 6 specific features (like <DeviceFactory>). Some of it may still work on Indigo 5, but we highly recommend developing against Indigo 6. The beta is very stable. Check out the release notes for v1.4 of the API.
However, I've modified the links in the Technical Docs section of the Indigo 5 docs to point to the Indigo 5 SDK so you can download it from there if you really want to stick with it.
jd10884
Re: PLugin SDK
Post by jd10884 »
Jay,
Thank you for you assistance in this matter greatly appreciated.
Jeff
Locked
Return to “Extending Indigo with Plugins and Python”
