itunes plugin help
Forum rules
thedon
itunes plugin help
Post by thedon »
I still have some plugins that randomly loose connection like this itunes plugin and I can't reconnect.
Would this be do to some bad apple scripts possibly?
1. I tried reloading of course
2. Restarted iTunes
3. Restarted computer
4. About 10 min after restarting computer the plugin reloaded, but not after getting multiple failures before hand. I included these errors as well.
Nov 19, 2012 2:38:54 AM
Reloading plugin "iTunes 1.0.14"
Stopping plugin "iTunes 1.0.14" (pid 202)
Plugin "iTunes" disconnected
Starting plugin "iTunes 1.0.14" (pid 464)
Plugin "iTunes" connected
Plugin "iTunes 1.0.14" started
Nov 19, 2012 2:39:28 AM
Stopping plugin "iTunes 1.0.14" (pid 464)
Starting plugin "iTunes 1.0.14" (pid 465)
iTunes Debug logging disabled
Indigo Cocoa client disconnected
Indigo Cocoa client connected
Nov 19, 2012 2:40:14 AM
Stopping plugin "iTunes 1.0.14" (pid 465)
Starting plugin "iTunes 1.0.14" (pid 470)
Nov 19, 2012 2:40:39 AM
Stopping plugin "iTunes 1.0.14" (pid 470)
Starting plugin "iTunes 1.0.14" (pid 474)
Nov 19, 2012 2:51:53 AM
Stopping plugin "iTunes 1.0.14" (pid 227)
Starting plugin "iTunes 1.0.14" (pid 232)
Stopping plugin "iTunes 1.0.14" (pid 232)
Starting plugin "iTunes 1.0.14" (pid 233)
jay (support)
Re: itunes plugin help
Post by jay (support) »
Unfortunately, there are no errors in the log section you provided - those are just normal messages from the plugin when starting/stopping/restarting.
A reboot (assuming both iTunes and the Indigo server are on the same machine) should clear any problems, so I really don't know what's going on. You might try turning on debugging in the iTunes config settings - it's going to spew a lot of stuff into the log but it might show more.
However, if you have other plugins that are also losing network connectivity then it seems much more likely that you have some systemic issue - your Mac OS installation may have become unstable.
Locked
Return to “Extending Indigo with Plugins and Python”
