Sending UDP packet to 255.255.255.255 using Python
Forum rules
HomeAutomationPlugins.com
Post by HomeAutomationPlugins.com »
I'm hoping someone who's better at Python than me (not hard!) can help with this.
I want to send a packet to the broadcast address 255.255.255.255, but am getting this error:
LightwaveRF Error               Error in plugin execution ExecuteAction:
  File "plugin.py", line 118, in actionControlDimmerRelay
  File "plugin.py", line 42, in sendMessageToDevice
  File "plugin.py", line 50, in sendMessage
<class 'socket.error'>: (13, 'Permission denied')
The same code works fine when I specify an actual IP address, here's the code that's sending the packet:
sock = socket.socket(socket.AF_INET,socket.SOCK_DGRAM)
sock.sendto(msg, ("255.255.255.255", 9760))
Many thanks!
Re: Sending UDP packet to 255.255.255.255 using Python
Figured it out!
Just needed the add the following line to allow broadcast:
sock.setsockopt(socket.SOL_SOCKET, socket.SO_BROADCAST, 1)
so the complete code block is:
		sock.sendto(msg, (self.pluginPrefs["wifilinkip"], self.lightwaveRfUdpPort))
Locked
Return to “Extending Indigo with Plugins and Python”
