Referring to property in PluginConfig.xml from Python
Forum rules
HomeAutomationPlugins.com
Post by HomeAutomationPlugins.com »
I'm stuck on a simple question I'm hoping you can help with!
Info.plist
<plist version="1.0">
<dict>
	<key>PluginVersion</key>
	<string>1.0.0</string>
	<key>ServerApiVersion</key>
	<key>IwsApiVersion</key>
	<string>LightwaveRF</string>
	<key>CFBundleIdentifier</key>
	<string>com.perceptiveautomation.indigoplugin.lightwaverf</string>
	<key>CFBundleVersion</key>
	<key>CFBundleURLTypes</key>
	<array>
		<dict>
			<key>CFBundleURLName</key>
			<string>http://www.perceptiveautomation.com/userforum/viewforum.php?f=20</string>
		</dict>
	</array>
</dict>
</plist>
PluginConfig.xml
<?xml version="1.0"?>
<PluginConfig>
	<Field id="wifilinkip" type="textfield" defaultValue="192.168.0.220">
		<Label>Wifilink IP Address:</Label>
	</Field>
</PluginConfig>
Could you let me know how I can refer to the "wifilinkip" property in the PluginConfig.xml from my python script?
I'm currently doing:
indigo.server.log(u"Value is " + com.perceptiveautomation.indigoplugin.lightwaverf.wifilinkip)
But that's resulting in:
File "plugin.py", line 56, in actionControlDimmerRelay
<type 'exceptions.NameError'>: global name 'com' is not defined
matt (support)
Re: Referring to property in PluginConfig.xml from Python
Post by matt (support) »
If you are inside the plugin config UI validate method, validatePrefsConfigUi(), then use:
valuesDict["wifilinkip"]
Otherwise, use:
self.pluginPrefs["wifilinkip"]
Got it!
Thanks again - the support you guys give is awesome by the way!
Locked
Return to “Extending Indigo with Plugins and Python”
