Set manually the "address" device property
Forum rules
Juju
Post by Juju »
Hello,
My device property UI allow to choose a house code and a device code using popup menus. They define the device properties "houseCode" and "deviceCode".
I would like to set the device property "address" (houseCode+deviceCode) manually, when the device settings UI is closed. This will allow (I think) to display the device address in the corresponding column.
I don't know where and how to do this ...
I tried in validateDeviceConfigUi with something like :
deviceCode = valuesDict["houseCode"] + valuesDict["deviceCode"]
dev.pluginProps.update({"address":deviceCode})
dev.replacePluginPropsOnServer(dev.pluginProps)
but it seems that's not the right way ...
jay (support)
Re: Set manually the "address" device property
Post by jay (support) »
The valuesDict that you get in validate*ConfigUi() can contain only entries that correspond to fields in the dialog itself. What I do in several plugins is to put in a hidden address field in the <Device> element of the ConfigUI XML:
<Field id="address" type="textfield" hidden="true">
    <Label/>
</Field>
Then in your validation code you could do this:
valuesDict["address"] = valuesDict["houseCode"] + valuesDict["deviceCode"]
Juju
Post by Juju »
Perfect Jay :P
Thanks.
Locked
Return to “Extending Indigo with Plugins and Python”
