Need help converting code to 2.5
Forum rules
berkinet
Post by berkinet »
The following (from a Phidgets device driver) is written in Python 2.6 and does not work in 2.5:
        hexArray = c_char*16
        self.__hexLookup = hexArray(b'0', b'1', b'2', b'3', b'4', b'5', b'6', b'7', b'8', b'9', b'A', b'B', b'C', b'D', b'E', b'F')
results in:
SyntaxError: invalid syntax
Here is where it is actually used:
        str = ""
        for i in range(5):
            str += (self.__hexLookup[int(tagValue[i] / 16)]).decode()
            str += (self.__hexLookup[int(tagValue[i] % 16)]).decode()
If I print out the individual values in tagValue (tagValue) I see a set of strings representing ints. Like: 1, 6, 142, 7, 129
But, if I try to print tagValue
itself I get: ctypes.LP_c_ubyte object at 0x4935d0
I am guessing the output is supposed to be a hex string. Unfortunately, the original author is no longer at Phidgets, and no one there is sure what the out pit should look like.
Any help replacing this with 2.5 compatible code would be greatly appreciated.
berkinet
Re: Need help converting code to 2.5
Post by berkinet »
I answered my own question. For those who were interested, this:
  • tag += str("%02x" % tagValue).upper()
accomplishes the same thing as:
  • str += (self.__hexLookup[int(tagValue / 16)]).decode()
    str += (self.__hexLookup[int(tagValue % 16)]).decode()
and I just dropped the array declaration altogether.
jay (support)
Post by jay (support) »
I think you can just remove the "b" on each argument. According to the Python docs on string literals:
A prefix of 'b' or 'B' is ignored in Python 2
Clearly it's not ignored in Python 2.5 since it thinks it's a syntax error.
berkinet
Post by berkinet »
jay wrote:I think you can just remove the "b" on each argument.
Thanks Jay, you and I were posting at the same time. BTW, Your suggestion also worked. :)
Locked
Return to “Extending Indigo with Plugins and Python”
