plugin updating
Forum rules
gregjsmith
plugin updating
Post by gregjsmith »
I think there needs to be a auto updating function for plugins. It's hard to keep track of when they have been updated or whats new. For that matter Indigo's updating could be improved.
It's also hard to tell where to get info about plugins, Is it in the"User Contributions" forum, the "Extending Indigo with Plugins and Python" forum or the "3rd party developers" forum?
jay (support)
Re: plugin updating
Post by jay (support) »
It's up to the 3rd party developer to advertise how to get support - we've provided forums for any developer that requests it the 3rd Party Developer section and that's where we recommend that they provide support, documentation, and upgrade notifications. We can't force them to do it though. And, for the moment, we're encouraging 3rd parties to put their plugins in the File Library - that should be the first place to look for plugins.
We're working on several things to help with finding and downloading plugins and getting notification when a new version of a plugin is available. Auto updating isn't in the cards though, at least in the short/medium term, for either Indigo or plugins - it's an extremely non-trivial exercise.
berkinet
Re: plugin updating
Post by berkinet »
jay wrote:I...We're working on several things to help with finding and downloading plugins and getting notification when a new version of a plugin is available. Auto updating isn't in the cards though, at least in the short/medium term, for either Indigo or plugins - it's an extremely non-trivial exercise.
Agreed with auto-updating, and good to hear version checking is being planned. In the meantime, the @gregjsmith's request seemed to be a good idea so I cooked up this snippet of portable code to let a plugin check its version number. I used my own server, but if there is general interest I could host other plugin's versions as well - until Matt and Jay do something official.
Other than entering a value for versionServer, the code should be completely portable. BTW, the "html" file contains one line only, with the version number. No actual html code.
from urllib2 import urlopen
import urllib2
import socket
	def versionCheck(self):
		self.debugLog(u"versionCheck() called")
		sp = re.split('\.', self.pluginId)
		myName = sp[2]
		myVersion = str(self.pluginVersion)
		socket.setdefaulttimeout(3)
		versionServer = 'http://yikes.com/plugins/'
		theUrl = versionServer + myName + '.html'
			f = urlopen(theUrl)
			latestVersion = str(f.read()).rstrip('\n')
			if myVersion < latestVersion:
				self.errorLog(u"You are running v%s. A newer version, v%s is available." % (myVersion, latestVersion))
				indigo.server.log(u"Your plugin version, v" + myVersion + " is current", type=self.pluginDisplayName)
		except:
			self.errorLog(u"Unable to reach the version server.")
EDIT: I added a timeout and exception handler. BTW, I called this from startup().
bschollnick2
Re: plugin updating
Post by bschollnick2 »
import urllib2
import socket
		myName = sp[2]
			f = urlopen(theUrl)
		except:
Please keep in mind, that I already created and implemented a full solution for version checking...
See http://www.perceptiveautomation.com/use ... com#p44355
Simply add an import line....
import versioncheck
Your plugin ID...
plugin_id = "com.schollnick.indigoplugin.External_IP"
And the actual version check code:
version_found, update_url, plugin_name = versioncheck.VersionCheck ( plugin_id )
self.debugLog ("Version Check Server reports %s is available." % version_found)
if version_found == None:
indigo.server.log ("Update Check failed. Please contact the Author of the Plugin.", isError=True)
elif float(version_found) > float(self.pluginVersion):
indigo.server.log ( "A New Version of %s v.%s is available. You can download the upgrade from %s" % (self.pluginDisplayName, version_found, update_url), type="Upgrade", isError=True )
The web site is all setup.... and online, for use....
http://www.indigo-plugins.com
for v5 - http://bit.ly/T6WBKu
Locked
Return to “Extending Indigo with Plugins and Python”
