Xbox Plugin
siclark
Xbox Plugin
Post by siclark »
A new plugin that uses the Microsoft API to pull stats on your, and in my case, my children's gamertags so I can monitor the use. It was actually something I used on Home Assistant but as I use that less and less, I asked Fable to build one for Indigo.
This is deliberately read only, no control of the device but I can add if required.
It also ships with some help pages that you can view locally, or if you move to the web assets folder, you can view with dom.io.
https://www.indigodomo.com/pluginstore/339/
any issues, as usual please let me know.
durosity
Re: Xbox Plugin
Post by durosity »
I’m curious as to what control functionality can be added?
siclark
Xbox Plugin
Post by siclark »
Actually I’m wrong. No control on that api. There is a dev version if you put Xbox into developer mode and have a lot of control but I’m not looking at a that.
Return to “Simon’s Plug-ins”
