Glenn,
Happily using your HomeKitLink Siri plugin, as well as your iMessage plugin, I was delighted to see your Cyberpower UPS plugin.
However, after installing the Cyberpower Panel for Mac, v2.7.1.1, I could not use the web-interface or port 3052 with netcat.
Could it be that this new software, for macOS 15/26, has lost some functionality that your plugin uses?
Unfortunately, older version of the Cyberpower Panel cannot be downloaded...
Thanks for any advice on testing stuff...
Kind regards, Gerrit Jan
Cyberpower UPS Panel & PowerPanel Personal for Mac v2.7.1.1
Yeah interesting
Seems they changed completely product lines
Install PowerPanel business instead
Free - hopefully?
And has the needed rest endpoint
Free - hopefully?
Re: Cyberpower UPS Panel & PowerPanel Personal for Mac v2.7.1.1
Have updated info - it may have been my mistake all along
See 1.1.3
In github now
https://github.com/Ghawken/CyberPowerUP ... n/releases
See 1.1.3
In github now
Hi Glenn,
Thanks for that...
However, now that I have uninstalled Personal and installed the 'Business - Local' variant of the PowerPanel software, I still encounter an error.
A lot seems to go okay, authentication, the software returns correct values to the plugin. The plugin seems to trip on parsing or interpreting the returned values. I have used your latest 1.1.3 version of the plugin.
If you have some time, could you please look into this, or provide me with some advice on things to try?
Thanks in advance for your efforts.
Please see the debug log:
Thanks for that...
24 Jul 2026 at 22:32:57
Cyberpower UPS Panel UPS device starting: Cyberpower UPS 1600
Cyberpower UPS Panel Debug Cyberpower UPS 1600: token missing or expired — re-authenticating
Cyberpower UPS Panel Debug Cyberpower UPS 1600: authenticating at http://127.0.0.1:3052/local/rest/v1/login/verify as 'admin'
Cyberpower UPS Panel Debug Cyberpower UPS 1600: login raw response: '"Bearer XXX"'
Cyberpower UPS Panel Cyberpower UPS 1600: authenticated successfully
Cyberpower UPS Panel Debug Cyberpower UPS 1600: fetching status from http://127.0.0.1:3052/local/rest/v1/ups/status
Cyberpower UPS Panel Debug Cyberpower UPS 1600: raw API response:
"communicationAvaiable": true,
"deviceId": 0,
"onlyPhaseArch": false,
"input": {
"state": 0,
"stateText": "Normal",
"voltages": [
"238.0 V"
"currents": null,
"frequencies": null,
"powerFactors": null,
"available": true
"output": {
"state": 0,
"ncls": null,
"voltages": [
"238.0 V"
"currents": null,
"loads": [
"10 %"
"watts": [],
"vas": [],
"activePowers": null,
"apparentPowers": null,
"reactivePowers": null,
"available": true
"battery": {
"state": 0,
"stateText": "Normal, Fully Charged",
"voltage": "26.8 V",
"capacity": "100 %",
"remainingRunTimeInSecs": 4830,
"remainingRunTimeFormated": "1hr. 20min.",
"remainingRuntimeInsufficient": false,
"modularUpsRuntimeZero": false,
"chargeTimeInSecs": null,
"chargeTimeFormated": null,
"temperatureCelsius": null,
"highVoltage": null,
"lowVoltage": null,
"highCurrent": null,
"lowCurrent": null,
"bhi": null,
"available": true
"bypass": {
"available": false,
"state": null,
"stateText": null,
"voltages": null,
"currents": null,
"system": {
"available": false,
"hardwareFaultAvailable": false,
"hardwareCodeAvailable": false,
"eventCodeAvailable": false,
"state": null,
"stateText": null,
"maintenanceBreak": null,
"temperatureFormated": null,
"temperatureFahrenheit": null,
"originalHardwareFaultCode": null,
"modules": null
Cyberpower UPS Panel Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 179, in deviceUpdated
File "/Library/Application Support/Perceptive Automation/Indigo 2025.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/plugin_base.py", line 1471, in device_updated
File "/Library/Application Support/Perceptive Automation/Indigo 2025.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/plugin_base.py", line 1407, in _dispatch_device_start_comm
File "plugin.py", line 152, in deviceStartComm
File "plugin.py", line 664, in _update_device
File "plugin.py", line 590, in _build_states
type: int() argument must be a string, a bytes-like object or a real number, not 'NoneType'Re: Cyberpower UPS Panel & PowerPanel Personal for Mac v2.7.1.1
Thanks for the info/logging.
Sorry about that. It is because your device has a different set of states.
Should be fixed in 1.1.4
At github releases now
Glenn
Glenn
Hi Glenn,
Many thanks for that! Version 1.1.4 is operating correctly, now it is time for me to discover all capabilities...
And, absolutely no reason to say sorry, as said, happily using several of your plugins now, appreceate all your efforts...
