Sensor Logging
SearchCz
Sensor Logging
Post by SearchCz »
I'm getting repeating entries like this in my event log:
   Hue Lights                      v1 other sensor type: hue outdoor motion sensor
   Hue Lights                      v1 other sensor type: hue outdoor light sensor
   Hue Lights                      v1 other sensor type: hue outdoor temp. sensor
Almost like it is being polled, or reporting at regular intervals. I dont seem to be able to turn this reporting off. Am I missing something?
Re: Sensor Logging
"outdoor" is not recognized.
now:
									tt = dev['productname'].lower()
									if   tt.find("dimmer switch") > -1: 			Hue_dimmer_switch += 1
									elif tt.find("smart button") > -1: 				Hue_smart_button += 1
									elif tt.find("tap dial switch") > -1: 			Hue_tap_dial_switch += 1
									elif tt.find("works with") > -1: 				Works_with_Hue_Switch += 1
									elif tt.find("motion sensor") > -1: 			Hue_motion_sensor += 1
									elif tt.find("wall switch module") > -1: 		Hue_wall_switch += 1
									elif tt.find("temperature sensor") > -1: 		pass
									elif tt.find("temp. sensor") > -1: 				pass <<<<
									elif tt.find("light sensor") > -1:				pass
									elif tt.find("outdoor") > -1:					pass <<<<
									else :
																					sensorOther += 1
fixed at https://github.com/kw123/Hue-Lights-Ind ... 2022.32.84
will push to indigo server if it works
SearchCz
Re: Sensor Logging
Post by SearchCz »
Thank you! New version is installed and running quietly now. I'll holler if I notice any hiccups.
SearchCz
Re: Sensor Logging
Post by SearchCz »
Probably unrelated, but I just noticed that the "long alert" method appears to be gone?
Return to “Hue Lights”
