Any advice about getting the plugin back into its happy place ? Help greatly appreciated!
Initial Error reported:
2026-05-17 09:17:02.356 HomeKitLink Siri Error (plugin.py: Function: deviceDeleted line: 1751): Error : Message : Device: vRoom.Laundry Room ,just deleted published and has active accessory within Homekit currently (!)
2026-05-17 09:17:02.356 HomeKitLink Siri Deleted Device appears to be running of Bridge 595688. Attempting to restart Bridge and reset all Accessories.
2026-05-17 09:17:03.459 HomeKitLink Siri Stopping accessory HomeKitLink Bridge 595688 on addresses ['192.168.68.65'], port 51829.
2026-05-17 09:17:03.462 HomeKitLink Siri Closed the flux capacitor loop.
2026-05-17 09:17:03.463 HomeKitLink Siri HK Virtual Rooms has completed full Bridge, Driver and Bridge Thread Shutdown.
2026-05-17 09:17:03.861 HomeKitLink Siri Starting accessory HomeKitLink Bridge 595688 Code: Select all
HomeKitLink Siri Error (hap_handler.py: Function: dispatch line: 246): Exception : Message : ('192.168.68.86', 49736): Failed to process request for: /characteristics
HomeKitLink Siri Error Traceback:
File "/Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/pyhap/hap_handler.py", line 240, in dispatch
getattr(self, self.HANDLERS[self.command][path])()
File "/Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/pyhap/hap_handler.py", line 672, in handle_set_characteristics
response = self.accessory_handler.set_characteristics(
requested_chars, self.client_address
File "/Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/pyhap/accessory_driver.py", line 958, in set_characteristics
char = acc.get_characteristic(aid, iid)
HomeKitLink Siri Error Error in plugin execution:
AttributeError: 'NoneType' object has no attribute 'get_characteristic'
Exc_info: (<class 'AttributeError'>, AttributeError("'NoneType' object has no attribute 'get_characteristic'"), <traceback object at 0x110cbe540>)
Exc_Text: Traceback (most recent call last):
Stack_info: None
HomeKitLink Siri Error (hap_handler.py: Function: dispatch line: 246): Exception : Message : ('192.168.68.86', 49737): Failed to process request for: /characteristics
Exc_info: (<class 'AttributeError'>, AttributeError("'NoneType' object has no attribute 'get_characteristic'"), <traceback object at 0x112b230c0>)
Stack_info: None
Action Group BackYardMotionEnded
Virtual Devices sent "vMotion.BackYard" off
Roomify Extending automation occupancy expiration for room 'Lounge' due to vacancy indicator 'Lounge Motion Detector (v2)' being ON
Roomify Setting watchdog cutoff for room 'Lounge'
HomeKitLink Siri Error (hap_handler.py: Function: dispatch line: 246): Exception : Message : ('192.168.68.86', 49738): Failed to process request for: /characteristics
Exc_info: (<class 'AttributeError'>, AttributeError("'NoneType' object has no attribute 'get_characteristic'"), <traceback object at 0x112a43a40>)
Stack_info: None
HomeKitLink Siri Error (hap_handler.py: Function: dispatch line: 246): Exception : Message : ('192.168.68.86', 49739): Failed to process request for: /characteristics
Exc_info: (<class 'AttributeError'>, AttributeError("'NoneType' object has no attribute 'get_characteristic'"), <traceback object at 0x112b02dc0>)
Stack_info: None
