Domio gets widgets and a Watch complication
siclark
Post by siclark »
Version 1.2 should be released overnight which adds
Widgets - There are standard single widgets for devices and variables for display, a 2x2 grid and a large detailed widget that is good for thermostats etc. Some more work to be done on look and feel but a good starting point. Control from widgets is harder, and will be in a future release.
Watch complication - Now it's easy to have a button on the watch that immediately starts the watch to Domio listen mode for voice control.
AI key improvements - Now possible to have API Keys for Anthropic and Open AI setup at the same time to change between the 2.
Thermostat UI improvements - introduce a flame icon for showing when the thermostat is calling for heat.
Australia and New Zealand App Store release.
plus all the usual performance and bug fixes.
durosity
Re: Domio gets widgets and a Watch complication
Post by durosity »
Does anything in this require watchOS 26 as the minimum, or is there any way you can release this to allow for older watchOS installs?
siclark
Post by siclark »
durosity wrote:Does anything in this require watchOS 26 as the minimum, or is there any way you can release this to allow for older watchOS installs?
Probably not. Watch is literally only a voice controller for now. It’s not as slick a control as I want but that’s apples limitations. Don’t be expecting great things.
I’ll try and remember to change in next release. A GitHub issue will help my memory.
durosity
Post by durosity »
I have logged it for you. I'll probably be logging a lot more. :D
Return to “Domio”
