This plugin will launch a unix command upon indigo shutdown signal.
You define the unix command.
How is it done:
The plugin method "shutdown()" is called by indigo during plugin shutdown
The method then checks if the string "Quitting Indigo Server - stopping plugins" is found in indigo log ( in the last 150 lines) to confirm that indigo is shutting down.
Then, as a cross check, also if there is NO string "Loading plugin" after the"Quitting Indigo..." string in indigo log to avoid any old string used as trigger.
Then with
subprocess(<your command>, shell =True)
your unix command is launched.
You define the unix <your command> in config. It must be fully qualified = whole path to the executables etc.
There is also a variable "shutdown_action_enabled" created by the plugin.
setting that to 1 or yes or true (lower or upper case is fine) will enable <your command>
If there is any other string the plugin will not launch <your command>
shutdownAction. plugin
Jump to
- Indigo Help
- ↳ Announcements
- ↳ Basic Usage Questions
- ↳ Devices
- ↳ Schedules
- ↳ Conditions
- ↳ Action Groups and Actions
- ↳ Variables
- ↳ Control Pages
- ↳ Feature Requests
- ↳ Z-Wave
- ↳ INSTEON
- ↳ Indigo Virtual Devices
- ↳ X10 - Legacy
- ↳ Supported Hardware
- ↳ Interfaces
- ↳ IR and A/V Devices
- ↳ Switches
- ↳ Thermostats
- ↳ Miscellaneous Devices
- ↳ Built-in Plugins
- ↳ Airfoil Pro
- ↳ Old Airfoil Discussions
- ↳ Alexa
- ↳ EasyDAQ Relay Card
- ↳ Email+
- ↳ Global Property Manager
- ↳ iTunes (Discontinued)
- ↳ NOAA Weather
- ↳ SQL Logger
- ↳ Timers and Pesters
- ↳ WeatherSnoop
- ↳ Growl (Discontinued)
- ↳ Indigo Server Software
- ↳ Indigo Mac Client App
- ↳ Indigo Touch for iOS
- ↳ Indigo Touch for the Web
- ↳ Extending Indigo
- ↳ AI Coding Agents
- ↳ Python Scripting
- ↳ Client APIs
- ↳ Hacking
- ↳ AppleScript Scripting
- ↳ Archived Posts
- ↳ Plugin Lists
- ↳ AaronLionsheep’s Plugins
- ↳ ShellyMQTT
- ↳ ShellyNGMQTT
- ↳ AB's Plugins
- ↳ AD2USB Alarm Interface
- ↳ Anyone's Plugins
- ↳ Autolog's Plugins
- ↳ AWTRIX
- ↳ Dynamic View Controller
- ↳ Foscam HD Controller
- ↳ Hubitat
- ↳ LIFX Controller
- ↳ nanoleaf Controller
- ↳ Roon Controller
- ↳ SMAPPEE Controller
- ↳ Squeezebox Controller
- ↳ Starling Bridge
- ↳ Touch Portal
- ↳ TRV Controller
- ↳ Z-Wave Interpreter
- ↳ Zigbee2mqtt
- ↳ Berkinet's Plugins
- ↳ Bill's Plugins
- ↳ Bouncing Ball LTD
- ↳ Dave's Plugins
- ↳ Announcements Plugin
- ↳ Bike Share Plugin
- ↳ Dave's Scripts
- ↳ GhostXML Plugin
- ↳ Indigo Log Viewer
- ↳ Matplotlib Plugin
- ↳ Multitool Plugin
- ↳ OWServer Plugin
- ↳ Z-Wave Node Matrix Plugin
- ↳ Deprecated Plugins
- ↳ Thingspeak Plugin
- ↳ WUnderstation Plugin
- ↳ WUnderground Plugin
- ↳ Fantastic Weather Plugin
- ↳ Duncan’s Plugins
- ↳ FlyingDiver's Plugins
- ↳ Ecobee
- ↳ Harmony Hub
- ↳ Home Assistant Agent
- ↳ LIFX Bridge
- ↳ Lutron
- ↳ miniUniFi
- ↳ MQTT
- ↳ Spy Connect
- ↳ Trane Nexia
- ↳ Twilio
- ↳ Other Plugins
- ↳ Discontinued Plugins
- ↳ RFPlayer
- ↳ MyQ
- ↳ Better Email
- ↳ GlennNZ's Plugins
- ↳ Actron QUE AC Plugin
- ↳ AppleTV Plugin
- ↳ BlueIris
- ↳ DeepState AI Plugin
- ↳ Deluxe Graphing
- ↳ Device Timer
- ↳ Dreame Vacuum Plugin
- ↳ Emby Plugin
- ↳ Enphase Envoy Solar
- ↳ ESPHome4Indigo
- ↳ FindFriendsMini Plugin
- ↳ Gecko Spa Plugin
- ↳ Holiday Plugin
- ↳ HomeKitLink Siri
- ↳ iMessage
- ↳ iRoomba iRobot Plugin
- ↳ Kiosk Home iOS App
- ↳ LedSimple Effects Plugin
- ↳ Mammotion Robot
- ↳ Paradox Alarm Plugin
- ↳ Sipura SPA VOIP Plugin
- ↳ Solar Smart
- ↳ Sunrise Plugin
- ↳ Tesla Battery
- ↳ Windows PC Remote Plugin
- ↳ Greg Glockner's Plugins
- ↳ Greg's Plugins
- ↳ Honeywell TC2 Security
- ↳ howartp's Plugins
- ↳ Clock Display
- ↳ EnergyLink
- ↳ Font Awesome
- ↳ Honeywell Evohome
- ↳ MyEnergi Hub
- ↳ Neo Smart Blinds
- ↳ Pulse Counter
- ↳ Sense Home Energy
- ↳ Sensibo
- ↳ Somfy Manager
- ↳ Tesla EV Control
- ↳ Variable Devices
- ↳ Verisure Alarm
- ↳ Volvo On Call
- ↳ Wakeup Scheduler
- ↳ ZWave Lock Manager
- ↳ ZWave Sensor Logger
- ↳ ZWave Scene Controller
- ↳ ZWave Watcher
- ↳ Zwave Window Controller
- ↳ Jason's Plugins
- ↳ GitHub Plugin Updater
- ↳ Network Devices
- ↳ Power Source
- ↳ Prometheus Client
- ↳ Prowl Notify
- ↳ RToggle
- ↳ Webcam
- ↳ XMPP Client
- ↳ Bouncie OBD Plugin
- ↳ On-Screen Keyboard Plugin
- ↳ AppleTV Plugin
- ↳ ARDUINO Plugin
- ↳ Devices and Variables
- ↳ FINGSCAN
- ↳ Homematic Plugin
- ↳ homeAway - presence
- ↳ Hue Lights
- ↳ Archives
- ↳ Indigo Utilities
- ↳ INDIGOplotD
- ↳ Mother Plugin
- ↳ Network Scanner
- ↳ piBeacon
- ↳ Shelly Plugin
- ↳ startupAction Plugin
- ↳ uniFi-WiFi-AP
- ↳ VoiceReceiver
- ↳ kmarkley's plugins
- ↳ Korey’s Plugins
- ↳ Anthem-Rs232
- ↳ Apple Music Control
- ↳ Music Manager
- ↳ Spotify Control
- ↳ Viewsonic Projector Rs232
- ↳ VLC Control
- ↳ Kwijibo007’s Plugins
- ↳ Doorbird
- ↳ Monoprice 6 Zone Amp
- ↳ SSH Switch
- ↳ Samsung TV
- ↳ Mpoulson’s Plugins
- ↳ Ring Doorbell
- ↳ Mr.Slim Heat Pump
- ↳ NuHeat Heated Floors
- ↳ PurpleAir
- ↳ Nathan Williams' Plugins
- ↳ Nick's Plugins
- ↳ Autelis Jandy
- ↳ Autelis Somfy
- ↳ Hikvision Camera Alerts
- ↳ Honeywell Thermostat
- ↳ TED 5000
- ↳ Neil's Plugins
- ↳ Daikin Wifi Controller
- ↳ Solcast Solar Forecast
- ↳ Velux Active
- ↳ WLED LED Controller
- ↳ papamac’s plugins
- ↳ Virtual Garage Door
- ↳ Pi GPIO
- ↳ Perry the Cynic
- ↳ racarter's plugins
- ↳ Blink
- ↳ Heatmiser Neo
- ↳ Hive
- ↳ Netatmo Multi
- ↳ Sunsynk
- ↳ Tapo
- ↳ Texecom
- ↳ Tuya
- ↳ Watchdog
- ↳ raneil's corner
- ↳ rbdubz3's Plugins
- ↳ Smart Setpoints
- ↳ Sylvania Lightify
- ↳ Light Scenes
- ↳ RFXCOM
- ↳ TiVo Network Remote
- ↳ Roku Network Remote
- ↳ Niles Audio Zone Receiver
- ↳ Sharp TV Network Remote
- ↳ DomoPad Android Client
- ↳ Onkyo Receiver
- ↳ Plex Media Server Manager
- ↳ Google Assistant
- ↳ Ryan Buckner's Plugins
- ↳ Tomorrow.io Plugin
- ↳ SearchCz's Plugins
- ↳ Roomify
- ↳ Securify
- ↳ Simon’s Plug-ins
- ↳ Claude Skill
- ↳ Domio
- ↳ Home Intelligence
- ↳ MCP Lite
- ↳ Netro Irrigation
- ↳ Sofabaton
- ↳ UK Trains
- ↳ Broadlink Devices
- ↳ APC Metered Rack PDU
- ↳ Captain’s Recapitulation
- ↳ VTMikeL's plugins
- ↳ Auto Fan
- ↳ Auto Lights
- ↳ Security Spy Helper
- ↳ August Home
- ↳ Google Vision
- ↳ Just Add Power
- ↳ MCP Server
- ↳ WeatherSnoop
- ↳ WebDeck Software
- ↳ BAFControl
- ↳ WonderSlug's Plugins
- ↳ Bert's Plugins
- ↳ Indify
- ↳ Chameleon Plugins
- ↳ NEST Home
- ↳ iTravel
- ↳ LED Device Manager
- ↳ iFindStuff
- ↳ Bip's Plugins
- ↳ Homebridge Buddy
- ↳ Device Extensions Plugin
- ↳ HomeKit Bridge
- ↳ LCD Creator
- ↳ Room-O-Matic
- ↳ Scene Toggle
- ↳ Firstnibble
- ↳ indilinq
- ↳ Jacob Lindehoff's Plugins
- ↳ Kristian's Plugins
- ↳ Mission Machines' Plugins
- ↳ Nathan Sheldon Software
- ↳ Proxidyne
- ↳ Sean's Plugins
- ↳ Spencer's Plugins
- ↳ thechad.io
- ↳ Travis' Plugins
- ↳ Smartphone Radar
- ↳ DSC Alarm Plugin
- ↳ Yergey's Forum
- ↳ ZachBenz's Plugins
- ↳ RingForIndigo
- User Contributions
- ↳ User Plugins
- ↳ Open Source Plugins
- ↳ Adapters
- ↳ Alexa-Hue Bridge
- ↳ DIRECTV DVR Control
- ↳ Dynamic Control
- ↳ HassBridge
- ↳ Photo Frame
- ↳ Pushover
- ↳ Archives
- ↳ Rachio
- ↳ Security Camera
- ↳ Sonos
- ↳ Vera Bridge
- ↳ Yamaha RX
- ↳ 8 Channel Network Relay
- ↳ Python Scripts
- ↳ Apple Shortcuts
- ↳ Other Scripts
- ↳ Miscellaneous
- ↳ AppleScripts
- ↳ Archived Posts
- ↳ Switching to Indigo
- ↳ Vendor Announcements
- ↳ Help Wanted & Bounties
- ↳ How Do I...
- ↳ User Modifications
- ↳ Classifieds
- ↳ General Home Automation
- ↳ General Chat
- ↳ Finding Installers
- ↳ Installer Discussions
