Set Point into a variable
SMUSEBY
Post by SMUSEBY »
I am attempting to extract the heater set point and assign it to a variable. None of the three labels found with "print device detail to event log work".
setpointHeat, setpointHeat.ui, and heatSetpoint.
Plugin ver 2025.0.1.
Script Error trigger "Heater setpoint to Var" script error in file htr setPt to Var.py:
Script Error 'key Heat Setpoint: not found in dict'
htr setPt to Var.py, line 3, at top level
KeyError: 'key Heat Setpoint: not found in dict'
Re: Set Point into a variable
Can't really help without seeing the script, but just looking at the error message I expect you have a space in the name of the state you're trying to extract.
SMUSEBY
Post by SMUSEBY »
It was the space. Thanks.
Return to “Ecobee”
